Software Archive
Read-only legacy content
Crosswalk 15 Multiple APK Issue
Nick_B_2
I'm currently having an issue with uploading multiple APKs with Crosswalk 15 and Cordova CLI 5.1.1. When I try to upload the x86 apk it shows the same architecture as its ARM counterpart: arm64-v8aarmeabiarmeabi-v7ax86x86_64 which causes an error.
I'm wondering if there is a solution for this?
Nick
PaulF_IntelCorp
Nick that issue should be resolved. Are you still seeing this error? I am unable to reproduce it.
Hamilton_Tenório_da_
Valued Contributor I
@Paul> I just test again with my APP: same problem. I attached here the APK info of both.
good news!
I removed the SQL Plugin (version 0.7.10) and reinsert the same with version 0.7.11 (the change of version does not work; it is necessary to remove and  to insert).
After rebuild with this change and... it works! Google Play accept the 2 APKs normally.
PaulF_IntelCorp
Hamilton, thanks for that workaround. It makes absolutely no sense to me why that procedure fixes the problem, but it is good to know!
Paul> another news, good one but very odd. Building the same app for iOS with sqlite 0.7.11 occurs an error. Then I downgrade to 0.7.9 and build OK.
In short:
- to have 2 valid APK to Android I need to use sqlite 0.7.11
- to build successfuly to iOS I need to use sqlite 0.7.9
PaulF_IntelCorp
Hamilton, that plugin author has made several new releases. You might try using the third-party plugin dialog to add the latest version. You can do that this way (best to first uninstall the existing version):
Paul> Thank you!
