Software Archive
Read-only legacy content
17060 Discussions
Crosswalk build problem
Spiros_N_
I have an application created with XDK.
Includes a strophe.js xmpp client connecting with a openfire xmpp server.
It is working as expected XDK Emulate/Debug/Test. (build 1912)
It is also working when build with Android.
I get a problem when build with crosswalk android (my favored option).
It can't connect to xmpp server. When login I get only a disconnected status.
No other errors even with Android Debug Monitor.The application was working with crosswalk build few days ago.
I had an apk file with the working version at 04/09/2015 so I decompiled that version and revert all changes done.
All plugins and sources are the same versions as the working version (04/09/2014) but when build with crosswalk I get the same problem.
So after about 20-25 builds and tests I used winmerge and compare the two decompiled apk's  and I noticed this changes in APPMOBI.SF :
New -not working (04/19/2015) crosswalk build :
Signature-Version: 1.0
SHA1-Digest-Manifest-Main-Attributes: v8q3lNaWtIt5aiWjl+oF90VvtwE=
Created-By: 1.7.0_75 (Oracle Corporation)
SHA1-Digest-Manifest: sGt6lO6JeIWzIu6En9MXx0RxjrM=
Old -working  (04/09/2015) crosswalk build :
SHA1-Digest-Manifest-Main-Attributes: mmYJRdD17nwFWNKqE/wjlp1x79E=
Created-By: 1.7.0_76 (Oracle Corporation)
SHA1-Digest-Manifest: RkqOZn3iGKIyZ4fScQngcOmkKwU=
The new version of of build server has an older java version ?
Amrita_C_Intel
Are you still facing this problem?  Try this in newer version of XDK (1995). let me know if it does not work.
Spiros_N_
Hi Amrita. This problems source was a missing cordova plugin from the "included plugins" list it is now solved.
Haven't try 1995 version yet
Amrita_C_Intel
Great!!
