Software Archive
Read-only legacy content
17060 Discussions
Crosswalk for Android Build Failed
Evan_H_
Hello. I made an app the other day using the IntelXDK, and today I went in and did some updating. Everything worked fine. I was able to build, but i forgot to change the app version in the build settings. I changed it, and removed a plugin that i didnt need, and after that, it keeps telling me the build fails (no matter what i build it for). Here is my log below:
Generating config.xml from defaults for platform "android"
Calling plugman.prepare for platform "android"
Preparing android project
Processing configuration changes for plugins.
Iterating over installed plugins: []
Writing out cordova_plugins.js...
Wrote out Android application name to "Kemper's Chemistry Tools"
deleted: .../EvansST/platforms/android/res/drawable-land-hdpi/screen.png
deleted: .../EvansST/platforms/android/res/drawable-land-ldpi/screen.png
deleted: .../EvansST/platforms/android/res/drawable-land-mdpi/screen.png
deleted: .../EvansST/platforms/android/res/drawable-land-xhdpi/screen.png
deleted: .../EvansST/platforms/android/res/drawable-port-hdpi/screen.png
deleted: .../EvansST/platforms/android/res/drawable-port-ldpi/screen.png
deleted: .../EvansST/platforms/android/res/drawable-port-mdpi/screen.png
deleted: .../EvansST/platforms/android/res/drawable-port-xhdpi/screen.png
splash screens: [{"src":"images/splash/splash_xhdpi.png","density":"xhdpi","platform":null,"width":"720","height":"960"},{"src":"images/splash/splash_hdpi.png","density":"hdpi","platform":null,"width":"480","height":"640"},{"src":"images/splash/splash_mdpi.png","density":"mdpi","platform":null,"width":"320","height":"470"},{"src":"images/splash/splash_ldpi.png","density":"ldpi","platform":null,"width":"320","height":"426"}]
copying image from .../EvansST/images/splash/splash_xhdpi.png to .../EvansST/platforms/android/res/drawable-xhdpi/screen.png
cp: no such file or directory: .../EvansST/images/splash/splash_xhdpi.png
copying image from .../EvansST/images/splash/splash_hdpi.png to .../EvansST/platforms/android/res/drawable-hdpi/screen.png
cp: no such file or directory: .../EvansST/images/splash/splash_hdpi.png
copying image from .../EvansST/images/splash/splash_mdpi.png to .../EvansST/platforms/android/res/drawable-mdpi/screen.png
cp: no such file or directory: .../EvansST/images/splash/splash_mdpi.png
copying image from .../EvansST/images/splash/splash_ldpi.png to .../EvansST/platforms/android/res/drawable-ldpi/screen.png
cp: no such file or directory: .../EvansST/images/splash/splash_ldpi.png
deleted: .../EvansST/platforms/android/res/drawable-hdpi/icon.png
deleted: .../EvansST/platforms/android/res/drawable-ldpi/icon.png
deleted: .../EvansST/platforms/android/res/drawable-mdpi/icon.png
deleted: .../EvansST/platforms/android/res/drawable-xhdpi/icon.png
copying image from .../EvansST/images/icons/xhdpi.png to .../EvansST/platforms/android/res/drawable-xhdpi/icon.png
cp: no such file or directory: .../EvansST/images/icons/xhdpi.png
copying image from .../EvansST/images/icons/hdpi.png to .../EvansST/platforms/android/res/drawable-hdpi/icon.png
cp: no such file or directory: .../EvansST/images/icons/hdpi.png
copying image from .../EvansST/images/icons/mdpi.png to .../EvansST/platforms/android/res/drawable-mdpi/icon.png
cp: no such file or directory: .../EvansST/images/icons/mdpi.png
copying image from .../EvansST/images/icons/Untitled-9.png to .../EvansST/platforms/android/res/drawable-ldpi/icon.png
cp: no such file or directory: .../EvansST/images/icons/Untitled-9.png
Wrote out Android package name to "com.horsleysoftware.kemperchemtools"
************* Processing the main config.xml file (after_prepare)  *****************
App Directory = [.../EvansST]
Will process and update the following config files:
    Config.xml = [.../EvansST/config.xml]
Namespaces:
    prefix/uri ''/'http://www.w3.org/ns/widgets'
    prefix/uri 'intelxdk'/'http://xdk.intel.com/ns/v1'
Android Manifest Namespaces:
    prefix/uri 'android'/'http://schemas.android.com/apk/res/android'
Name of the app is [Kemper's Chemistry Tools]
Updating full app name to [Kemper's Chemistry Tools]
Processing preference android-minSdkVersion [10]
Processing preference android-targetSdkVersion [19]
Processing preference android-installLocation [auto]
Processing preference Orientation [portrait]
    Added [{http://schemas.android.com/apk/res/android}screenOrientation] with [portrait]
Processing preference permissions
Updating the versionCode
Updating the versionName
Added [{http://schemas.android.com/apk/res/android}debuggable] with [false]
Processing config file values
Copying xhdpi launch icons...
Copying hdpi launch icons...
Copying mdpi launch icons...
Copying ldpi launch icons...
Copying [.../EvansST/www/images/splash/splash_xhdpi.png] to [.../EvansST/platforms/android/res/drawable-port-xhdpi/splash.png]
Copying [.../EvansST/www/images/splash/splash_hdpi.png] to [.../EvansST/platforms/android/res/drawable-port-hdpi/splash.png]
Copying [.../EvansST/www/images/splash/splash_mdpi.png] to [.../EvansST/platforms/android/res/drawable-port-mdpi/splash.png]
Copying [.../EvansST/www/images/splash/splash_ldpi.png] to [.../EvansST/platforms/android/res/drawable-port-ldpi/splash.png]
No splash screen supplied for drawable-land-mdpi.  Cleaning up.
Removing unused density: .../EvansST/platforms/android/res/drawable-land-mdpi
No splash screen supplied for drawable-land-ldpi.  Cleaning up.
Removing unused density: .../EvansST/platforms/android/res/drawable-land-ldpi
No splash screen supplied for drawable-land-xhdpi.  Cleaning up.
Removing unused density: .../EvansST/platforms/android/res/drawable-land-xhdpi
No splash screen supplied for drawable-land-hdpi.  Cleaning up.
Removing unused density: .../EvansST/platforms/android/res/drawable-land-hdpi
Saving config.xml to [.../EvansST/config.xml]
************* Completed processing the main config.xml file (after_prepare)  *****************
Running command: .../EvansST/platforms/android/cordova/build --release
Buildfile: .../EvansST/platforms/android/build.xml
-set-mode-check:
-set-release-mode:
-release-obfuscation-check:
     [echo] proguard.config is ${proguard.config}
-pre-build:
-check-env:
 [checkenv] Android SDK Tools Revision 22.3.0
 [checkenv] Installed at /Developer/android-sdk-linux
-setup:
     [echo] Project Name: CordovaApp
  [gettype] Project Type: Application
-build-setup:
[getbuildtools] Using latest Build Tools: 19.0.0
     [echo] Resolving Build Target for CordovaApp...
[gettarget] Project Target:   Android 4.4
[gettarget] API level:        19
     [echo] ----------
     [echo] Creating output directories if needed...
    [mkdir] Created dir: .../EvansST/platforms/android/ant-build
    [mkdir] Created dir: .../EvansST/platforms/android/ant-build/res
    [mkdir] Created dir: .../EvansST/platforms/android/ant-build/rsObj
    [mkdir] Created dir: .../EvansST/platforms/android/ant-build/rsLibs
    [mkdir] Created dir: .../EvansST/platforms/android/ant-gen
    [mkdir] Created dir: .../EvansST/platforms/android/ant-build/classes
    [mkdir] Created dir: .../EvansST/platforms/android/ant-build/dexedLibs
     [echo] ----------
     [echo] Resolving Dependencies for CordovaApp...
[dependency] Library dependencies:
[dependency]
[dependency] ------------------
[dependency] Ordered libraries:
[dependency]
     [echo] ----------
     [echo] Building Libraries with 'release'...
nodeps:
-set-mode-check:
-set-release-mode:
-pre-build:
-check-env:
-setup:
  [gettype] Project Type: Android Library
-build-setup:
     [echo] ----------
    [mkdir] Created dir: .../EvansST/platforms/android/CordovaLib/res
    [mkdir] Created dir: .../EvansST/platforms/android/CordovaLib/libs
    [mkdir] Created dir: .../EvansST/platforms/android/CordovaLib/ant-build
    [mkdir] Created dir: .../EvansST/platforms/android/CordovaLib/ant-build/res
    [mkdir] Created dir: .../EvansST/platforms/android/CordovaLib/ant-build/rsObj
    [mkdir] Created dir: .../EvansST/platforms/android/CordovaLib/ant-build/rsLibs
    [mkdir] Created dir: .../EvansST/platforms/android/CordovaLib/ant-gen
    [mkdir] Created dir: .../EvansST/platforms/android/CordovaLib/ant-build/classes
    [mkdir] Created dir: .../EvansST/platforms/android/CordovaLib/ant-build/dexedLibs
     [echo] ----------
[dependency] No Libraries
[dependency]
-code-gen:
[mergemanifest] Merging AndroidManifest files into one.
[mergemanifest] Manifest merger disabled. Using project manifest only.
     [echo] Handling aidl files...
     [aidl] No AIDL files to compile.
     [echo] ----------
     [echo] Handling RenderScript files...
     [echo] ----------
     [echo] Handling Resources...
     [aapt] Generating resource IDs...
     [echo] ----------
     [echo] Handling BuildConfig class...
[buildconfig] Generating BuildConfig class.
-pre-compile:
-compile:
    [javac] Compiling 93 source files to .../EvansST/platforms/android/CordovaLib/ant-build/classes
    [javac] Note: Some input files use or override a deprecated API.
    [javac] Note: Recompile with -Xlint:deprecation for details.
     [echo] Creating library output jar file...
      [jar] Building jar: .../EvansST/platforms/android/CordovaLib/ant-build/classes.jar
-post-compile:
-obfuscate:
-dex:
     [echo] Library project: do not convert bytecode...
-crunch:
   [crunch] Crunching PNG Files in source dir: .../EvansST/platforms/android/CordovaLib/res
   [crunch] To destination dir: .../EvansST/platforms/android/CordovaLib/ant-build/res
   [crunch] Crunched 0 PNG files to update cache
-package-resources:
     [echo] Library project: do not package resources...
-package:
     [echo] Library project: do not package apk...
-post-package:
-release-prompt-for-password:
-release-nosign:
     [echo]
[propertyfile] Creating new property file: .../EvansST/platforms/android/CordovaLib/ant-build/build.prop
[propertyfile] Updating property file: .../EvansST/platforms/android/CordovaLib/ant-build/build.prop
-release-sign:
-post-build:
release:
-code-gen:
     [echo] ----------
     [echo] ----------
     [aapt] .../EvansST/platforms/android/ant-build/AndroidManifest.xml:2: error: Error: Float types not allowed (at 'versionCode' with value '1.5').
BUILD FAILED
/Developer/android-sdk-linux/tools/ant/build.xml:653: The following error occurred while executing this line:
/Developer/android-sdk-linux/tools/ant/build.xml:698: null returned: 1
Total time: 3 seconds
.../EvansST/platforms/android/cordova/node_modules/q/q.js:126
                    throw e;
Error code 1 for command: ant with args: release,-f,.../EvansST/platforms/android/build.xml,-Dout.dir=ant-build,-Dgen.absolute.dir=ant-gen
Command finished with error code 8: .../EvansST/platforms/android/cordova/build --release
Error: .../EvansST/platforms/android/cordova/build: Command failed with exit code 8
    at ChildProcess.whenDone (/Developer/cordova/4.1.2/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:135:23)
    at ChildProcess.EventEmitter.emit (events.js:98:17)
    at maybeClose (child_process.js:743:16)
    at Process.ChildProcess._handle.onexit (child_process.js:810:5)
Amrita_C_Intel
 Which XDK version are you using?
Are you building for android or android crosswalk?
If you can send me your code I can look in to that with more details.
