Software Archive
Read-only legacy content
17060 Discussions
The problem of access
Amin_A_
Greetings
I access:
- find accounts on the device
- delete all app cache data
I have written with HTML5 app for Android got out.
How can I remove this access?
Help me please thanks
Brandon_K_Intel
Will you please give me more details on the issue you are attempting to solve?
Amin_A_
I use xdk the language HTML.
I have written books and Android apps in the market my own country.
Market Support says: the following access necessary programs and should not be removed.
I do not find the plugins have been xdk
Barry_Johnson
It is very difficult for me to be certain, but I believe what you are saying is that the Android marketplace has rejected your application because it is requesting the permissions android.permission.CLEAR_APP_CACHE and android.permission.USE_CREDENTIALS. I am guessing these are coming from a plugin you have enabled - likely one you aren't using. As a first step, I would recommend disabling any plugins that aren't actually necessary. You could also do a file search of your project directory for the above mentioned permissions to find where they are being referenced in your project.
