Software Archive
Read-only legacy content
17060 Discussions
Current software dev kit for Edison has a problem
samontab
Valued Contributor II
Hi guys,
Just wanted to let you know that as of 13/Feb/2015, the digital signature for the USB drivers from Intel is expired.
This means that any new install of the software dev kit for the Intel Edison in Windows 8 from that day onwards will not correctly install CDC serial and RNDIS.
On the practical side, this means that the user is not able to upload any sketch to the Edison using the Arduino IDE, which uses the usb driver. Since the installer silently ignores this error, and the rest of the Edison works fine, many developers will tear their hair out trying to upload their sketch to the Edison after correctly following the installation steps.
The current workaround is to remove the check for signatures for new drivers, as explained here:
https://learn.sparkfun.com/tutorials/disabling-driver-signature-on-windows-8/disabling-signed-driver-enforcement-on-windows-8
But, this is clearly not ideal. Hopefully Intel will provide a new installer soon.
Matthias_H_Intel
thanks - we are already aware of this and have fixed it internally. New driver should be available soon
Matthias_H_Intel
the new driver v1.2.1 is available for download at Intel® Edison Boards and Compute Modules — Software Downloads
samontab
Nice!, it now even comes with the Intel icon :)
donghwan_l_
wow, i experienced too, i just can find only serial port, there are no intel com port.....
i am disappointed at Intel.... again...
samontab
Why are you disappointed?
The new drivers are working fine. There should be a COM port named Intel Edison Virtual Com Port. I just uploaded a sketch using the arduino IDE with that COM port and it worked fine.
Jayesh_K
Please specify your host setup, specific issue, and the steps followed so that forum member can help you out.
Dan_S_1
Even with this helpful tip, I can install the drivers but the "Getting Started" fails to operate on Windows 8.1 when downloading the Windows 64 bit version.  It just hangs on the splash screen at Loading xdk.xml forever with no error message.  I'm new to this platform but I am out of ideas.  I even tried putty via the COM port and hit Enter twice with no response.  New board.  Ideas?  This is far from newbie friendly.
Addendum: this is what happens when you use the wrong COM port.  Don't be fooled by the one labeled "Intel Edison Virtual Com Port" - that's not it.  Works fine once you figure that out.
samontab
Well, it depends on the tool that you are using.
For the Arduino IDE, that's actually the one you need to use.
NagaVenkat_K_Intel
Hi Dan,
Can you please specify your host setup configuration. In order to connect using putty you need to use the USB Serial Port.
Kevin_B_2
drivers not working.......was before I was able to update to ubanix trying to go back to stock distro
last windows update seems to have broken it.....have one com port that it
does not show up as drive in explorer
I have tried on 3 diff machines.....8.1  Surface 8.1 and a old xp pc also
I have spent more that 16 hours on this......
Sad part it worked before
Kevin_L_1
I agree. The 1.2.1 standalone driver installs an expired certificate on windows 8.1.
ricky_j_
i agree
Thoriq_S_
NagaVenkat_K_Intel
I will try to raise a bug on this issue.
