Software Archive
Read-only legacy content
17060 Discussions
Custom Project templates to be listed in Intel XDK
GN__Lohith
Hi
I am new to Intel XDK tool. I have been playing around XDK tool after i installed it.
I have been looking at HTML5 Hybrid Mobile UI Framework called Kendo UI. Kendo UI Mobile provides a complete Mobile framework for Hybrid Apps. Kendo UI Mobile demos are available online here: http://demos.telerik.com/kendo-ui/m
When i start XDK and go to Start A New Project > Templates > Layout & User Interface - I see many ready made templates listed there. I am interested to know if i can list a Kendo UI project templates here in the default template list ?
Is this possible ?
Looking forward to some pointers/direction?
Pamela_H_Intel
We don't directly support Kendo UI, so you won't be able to select a Kendo UI template when creating a project.
You can, however, use the Kendo UI Framwork by adding the Framework to your source manually after creating a project in one of the two following ways:
  • Create the project with App Designer with a some framework choice. Then, after adding the Kendo Framework, you will need to make adjustments in the code to access the Kendo UI Framework functionality, or
  • If you are comfortable with HTML5 and don't need App Designer, start with no framework and after adding the Kendo Framework add whatever code you need.
