Software Archive
Read-only legacy content
17060 Discussions
DCM 1.4 installer reports no Free Disk Space
RBang
New Contributor II
For all those who have a similar issue while installing DCM 1.4,  Brain H. (https://software.intel.com/en-us/user/1185821), came up with a Nifty Solution for the same!
  1. Run intel_rs_dcm_f200_1.4.27.32425.exe
  2. The installer will extract it's contents to your temporary files folder.  The path for mine was:
    C:\Users\Rishabh\AppData\Local\Temp\{91d07afa-21fa-4833-8f8f-38f014d1d35f}
    The last part of the path is random, so just find it by sorting by the Last Modified column.
  3. Inside that directory, navigate to /Plugins/FWUpdateF200.
  4. Open an administrative command prompt window and run the following:
    FWUpdateF200.exe /oemId:0
    This will update your camera's firmware.
  5. Now enter the following command to go to the installations directory:
    cd ../../installs
  6. For every .msi file in that directory that starts with "intel_rs_sdk_runtime", run the following command:
    [FILE].msi EXTERNALUI=PSET
