Software Archive
Read-only legacy content
17060 Discussions
DFWIN PROBLEM V6.6
Intel_C_Intel
I am having problems compiling/linking SETWINDOWTEXT and LOADIMAGE together in the same routine. Therein lies the workaround. This is the only problem which occured going from V6.5a to V6.6 which is not bad considering the size of the program.
Bill Buchholz
PROGRAM TESTREAD
USE DFLIB
USE DFWIN
CALL SETWINDOWTEXT (GETHWNDQQ(QWIN$FRAMEWINDOW),'TEST'C)
IRES = LOADIMAGE ('FRED.BMP'C,1,1)
END
! WITH DFWIN
!--------------------Configuration: TESTREAD - Win32 Debug--------------------
!Compiling Fortran...
!D:TESTREADTESTREAD.F90
!D:TESTREADTESTREAD.F90(8) : Error: There is no matching specific function for this generic function reference. [LOADIMAGE]
! IRES = LOADIMAGE ('FRED.BMP'C,1,1)
!Error executing df.exe.
!TESTREAD.OBJ - 1 error(s), 0 warning(s)
! WITHOUT DFWIN
!Linking...
!TESTREAD.OBJ : error LNK2001: unresolved external symbol _SETWINDOWTEXT@12
!Debug/TESTREAD.exe : fatal error LNK1120: 1 unresolved externals
!Error executing link.exe.
!TESTREAD.exe - 2 error(s), 0 warning(s)
Steven_L_Intel1
Bill,
I think I see what happened here... LoadImage exists in both DFLIB and USER32 (implied by DFWIN). In V6.5, there was no conflict becuse the declaration in USER32 was non-generic and the compiler could resolve between them based on the different signatures. But in 6.6, the USER32 version of LoadImage became a generic (to accomodate an "ease of use" improvement in the interface), and that means that it hides the version in DFLIB (I'm not sure if the compiler is supposed to give an error for this - I'll check.)
The easy fix is to say instead:
USE DFWIN, IGNORE => LOADIMAGE
This renames the LOADIMAGE you don't want.
There may be other cases like this - we'll check it out. I would ask that in the future you send problems like this (used to work but doesn't now) to vf-support@compaq.com instead of posting here.
Steve
Steven_L_Intel1
Oh, by the way, your sample program wouldn't compile at all in 6.5A because of the two different LoadImage declarations.
Steve
Intel_C_Intel
Steve,
Attached is a fragment of the program that did compile and link ok under
v6.5 and not under v6.6. The MAKEBMP routine that contained the
LOADIMAGE statement was not actually called. In the release version,
the linker output information that the routine would not be included
in the executable. I can only assume that it was included in the debug
version and thus satisfied the externals since it was part of the main
program file and not a separate program file in a library.
Bill
PROGRAM WMSVPROG
! Purpose : Minsurv menu program.
USE DFLIB
USE DFWIN
! CALL MAKEBMP
CALL SETWINDOWTEXT (GETHWNDQQ(QWIN$FRAMEWINDOW),IOSTR)
! EXIT PROGRAM
STOP
CONTAINS
SUBROUTINE MAKEBMP
KBSTR = 'D:WMSV01MDDIALWMSVPROG.BMP'C
IRES = LOADIMAGE (KBSTR,1,1)
END SUBROUTINE MAKEBMP
END PROGRAM WMSVPROG
