Software Archive
Read-only legacy content
17060 Discussions
HElp - ANIMATE_PLAY macros
isn-removed200637
I found a nice example of playing an AVI clip in a dialog box on the MSDN/Visual Studio/ cd rom. It is a C program , animate.c, which I want to convert to a Fortran version using the GENERIC example as a basis.
I have got as far as getting the dialog box to open ok. I now find that I am unable to satisfy references to the WIndows macros ANIMATE_OPEN, ANIMATE_PLAY, ANIMATE_SEEK etc. From the infoviewer, I am referred to COMMCTRL.H as the place to find them. I do not have Visual C on my machine. Can anyone please point me to where they might exist within the Visual Fortran resources? TIA
Jugoslav_Dujic
Valued Contributor II
Most of "helper macros" are not implemented by Compaq. "Helper macros" are actually various wrappers for SendMessage intended to make code more readable. So, you could either use SendMessage instead (with ACM_OPEN, ACM_PLAY, ACM_SEEK) or write your own wrappers.
Jugoslav
isn-removed200637
Yes, thanks Jugoslav. I downloaded the SDK and found the macros in COMMCTRL.H and figured out the SendMessage
link. However, When I used Resource Editor to include an animation control in the dialog box, the dialog refuses to load
(DialogBoxParam returns -1). If I replace it with another control,such as an edit box, the dialog loads OK.
The resource script created for the control is as follows:
ANIMATEDLG DIALOG DISCARDABLE  50, 50, 304, 146
STYLE DS_MODALFRAME | WS_POPUP | WS_VISIBLE | WS_CAPTION | WS_SYSMENU
CAPTION "Animation Demo"
FONT 8, "MS Sans Serif"
BEGIN
    DEFPUSHBUTTON   "Quit",IDOK,223,122,50,14
    PUSHBUTTON      "Play",IDC_PLAY,22,122,49,14
    PUSHBUTTON      "Stop",IDC_STOP,89,122,49,14
    PUSHBUTTON      "Seek",IDC_SEEK,156,122,49,14
    CONTROL         "Animate1",IDC_EDIT1,"SysAnimate32",ACS_CENTER |
                    WS_BORDER | WS_TABSTOP,18,7,266,102
END
Any Ideas?
Jugoslav_Dujic
You have to call InitCommonControls or maybe even
InitCommonControlsEx(T_INITCOMMONCONTROLSEX(8, ICC_ANIMATE_CLASS))
somewhere at the start.
isn-removed200637
Many thanks again, Jugoslav, for your tip which worked.
I added the following to WinMain:
interface
subroutine InitCommonControls ()
!DEC$ IF DEFINED(_X86_)
!DEC$ ATTRIBUTES STDCALL, ALIAS : '_InitCommonControls@0' :: InitCommonControls
!DEC$ ELSE
!DEC$ ATTRIBUTES STDCALL, ALIAS :  'InitCommonControls'    :: InitCommonControls
!DEC$ ENDIF
end subroutine InitCommonControls
end interface
call InitCommonControls()
and added comctl32.lib to the library search step in the project Link settings
(I added Fullapi.f90 to the project, but that is missing comctl32.lib - maybe I will add
the appropriate !dec$objcomment lib:"comctl32.lib" comment to it for future reference). Again, many thanks.
isn-removed200637
By the way Jugoslav, while programming in a call to GetOpenFileNAme to select files to be played in the animation control, I have discovered GetOpenFilenamePreview which, when
set up with an .AVI filter opens a preview pane in the Explorer dialog. It has succeded in previewing/playing every .AVI file I found on my PC, wheras only three of them were playable in the animate control.
