Software Archive
Read-only legacy content
DLL for ASPs
rahzan
Has anyone produced a DLL for use in an ASP?
I understand that the functions return types must be Variants. Since I have not done this before, If anyone has a template for doing this I will much appreciate getting it.
Thanks, Tim H
Intel_C_Intel
Hi Tim,
ASP pages use VBScript (which is a subset of the full VB language). I'm not a VBScript expert, but as far as I can tell VBScript does not support calling a routine in a DLL. If anyone knows better..., please respond.
Leo
rahzan
Have a Look at :
http://p2p.wrox.com/archive/beginning_asp/2001-05/13.asp
Which amounts to the following code:
ASP Code (generic class works fine through a sub)
set Generic = Server.CreateObject("MYOBJ.Generic")
Generic.UserID = Request.Form("userid")
Generic.Password = Request.Form("pwd")
Generic.LogIn
session("agency_id") = Generic.AgencyID
session("access_level") = Generic.AccessLevel
set Client = Server.CreateObject("MYOBJ.Client")
Client.UserID = Request.Form("userid")
Client.Password = Request.Form("pwd")
Client.AgencyID = cint(session("agency_id"))
myagency = cint(session("agency_id"))
session("mycontract") = Client.FetchContractor(myagency)
VB DLL:
Public Function FetchContractor(intAgencyID As Integer) As Variant
On Error GoTo ErrorHandler
'Open connection to database
ConnectRstToDatabase
With rst
.Open "Exec SP_ContractorFetchByAgency " & intAgencyID & " "
If .EOF = False Then
FetchContractor = .GetRows
End If
End With
'Clean up and exit
CleanUpResources
Exit Function
ErrorHandler:
Call RaiseError(Err.Number, "FetchContractor", Err.Description)
End Function
Intel_C_Intel
AFAIK, Leo is correct, ASP doesn't support classic DLLs, just COM objects. The reponses posted at the link Tim gave all seem to be focused on VB ActiveX DLLs (the hint is the Server.CreateObject calls) which are not which are not plain old DLLs.
With CVF, create a COM object using a dual interface and only VARIANT args. That should get you going where you want.
John
