Software Archive
Read-only legacy content
Data Path not set
Mwesigwa_E_
Am a newbie to Intel xdk, however i have been using Appery.io platform and everything seems familiar, I have a problem binding a webservice response to any componet,easch time i choose Multiple, the data path shows "not set".i have watched video tutorials and the data path sets it's self automatically..eg movies[].
Giselle_G_Intel
What happens when you change the controller type to single instead of multiple?
Mwesigwa_E_
This is what happens when i choose single. When i bind the objects to the list component, the looping does not happen. Infact even the single list item does not get the data.for example it will remain  as  {{entry.["resource"]["0"]["Description"]}} when previewed in the simulator.
Giselle_G_Intel
We are currently looking into this problem - it is a bug with the data binding. Once there is new information on a workaround or it is fixed, we will post information about it. See this thread for the similar issue > https://software.intel.com/en-us/forums/intel-xdk/topic/703233 < they are doing single data bindings, but it seems to be the same root cause.
Kiriakos_T_
I have exactly the same problem while using RSS reader from web services. Is there any solution, yet?
PaulF_IntelCorp
There is no resolution, yet. A bug has been issued for engineering.
Odyssefs_E_
Same here. None of my services works. I am running build 3759 and the new one makes things even worse. It crashes every time I am trying to save the binding.
