Software Archive
Read-only legacy content
17060 Discussions
Data alignment problem
Nick_L_1
Hi there
I was trying to offload some computation to MIC using "pragma", sending data addressed by a pointer p, then how to ensure the alignment of data on MIC after MIC recieved it? Does" __assume(p, 64)" work?I was trying to use instrinsics to load data to the vector RF, which requires the alignment of data.
Another problem, that I was trying to active lots of threads for the calculation using "#pragma omp parallel for", and some arrays inside the loop must be thread private while also 64-byte aligned.
I was using "_mm_malloc()" inside the loop to ensure these, but this leads to reduplicated and unnecessary allocation.
Frances_R_Intel
Could you possibly post a small sample code? Thanks.
Nick_L_1
In the main function:
double * p;
p = (double * )malloc(sizeof(double)*1024);
#pragma offload target(mic:0) in(p:length(128)
          foo(p);
The data addressed by p is transfered into MIC And the function foo is defined like this:
__attribute__((target(mic)))void foo( double * p)
#ifdef __MIC__
long long iter;
#pragma omp parallel for private(iter)
        for(iter = 0 ; iter < N ; iter ++)
                __m512d _A, _B;
                double * p1;
                p1 = (double * )_mm_malloc(sizeof(double)*1024, 512);      //p1 has to be thread-private
                _A = _mm512_load_pd((void*)p);                                                //p has to be aligned
                _B = _mm512_load_pd((void*)p1);                                             //p1 has to be aligned
                /* Calculations */
                _mm_free(p1);
#endif
Thus p1 is allocated repeatedly inside the loop to make sure it's thread-private, while p1 has to be aligned.
James_C_Intel2
At the very least you should structure that more like this (which allocates once per thread, rather than once per iteration)
    long long iter;     // Though does it *really* need to be 64 bits!? How many iterations do you have?
                        // 64bit indexes are likely inefficient.
    double * p1 = (double *) _mm_malloc (sizeof(double)*1024, 512);
#pragma omp for
    for (iter=0; iter<N; iter++)
        _mm_512d _A;
       ... etc ...
    _mm_free (p1);
Nick_L_1
#pragma omp for
        _mm_512d _A;
       ... etc ...
    _mm_free (p1);
I really have that many iterations. Reconstructing the code helps ,thanks~
