Software Archive
Read-only legacy content
17060 Discussions
Dear intel, please fix your iOS build, this has been going on for this and your previous build.
Bracer_J_
Error code 65 for command: xcodebuild with args: -xcconfig,.../testf/platforms/ios/cordova/build-release.xcconfig,-project,testf.xcodeproj,ARCHS=armv7 arm64,-target,testf,-configuration,Release,-sdk,iphoneos,build,VALID_ARCHS=armv7 arm64,CONFIGURATION_BUILD_DIR=.../testf/platforms/ios/build/device,SHARED_PRECOMPS_DIR=.../testf/platforms/ios/build/sharedpch
Command finished with error code 2: .../testf/platforms/ios/cordova/build --release,--device
ERROR building one of the platforms: Error: .../testf/platforms/ios/cordova/build: Command failed with exit code 2
You may not have the required environment or OS to build this project
    at ChildProcess.whenDone (.../cordova/cordova-cli/5.1.1/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:134:23)
    at emitTwo (events.js:87:13)
    at ChildProcess.emit (events.js:172:7)
    at maybeClose (internal/child_process.js:821:16)
    at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
It works on build 2866, but no further.
Because of this, I am still using this old build because it is the only one that works,
Please, fix this, thank you very much.
Swati_S_Intel1
