Software Archive
Read-only legacy content
17060 Discussions
Debugger unstable on emulator
David_K_6
Is anyone else getting serious instability on the debugger for the Emulate tab on XDK?
In my case, there are two things that happen erratically:
(1) The Sources window stops letting me set breakpoints
(2) The Network window contents disappear, when I'm not doing anything in particular
Both are fixed by restarting XDK. But they're happening increasingly often, enough so that it's beginning to be a serious problem, but with no pattern that I can make out. It's conceivable that this all got worse when I did an OS X El Capitan upgrade, but I'm not really sure.
Set-up: OS X 10.11, XDK 2611, emulating an Apple iPhone 6, my app uses Cordova and jQuery Mobile but not much else in the way of external libraries. I *am* making a bunch of XmlHttpRequests to my local dev server.
Any ideas appreciated
David
PaulF_IntelCorp
I'll ask the engineer in charge of the Emulate tab to take a look. In the meantime, have you tried using the Debug tab?
