Software Archive
Read-only legacy content
17060 Discussions
[Delay and error]
Kidda_S_
Boa noite, eu estou tentando fazer um crosswalk android e quando estou no uploading project demora entre 10 a 20 minutos não completa e aparece uma mensagem dizendo que não conseguiu completar o processo sendo necessário reiniciar o programa.
xdk:client (1446515851468): memlim: 767557632
xdk:client (1446515851512): Setting NW crash dump to: C:\Users\Kidda\AppData\Local\XDK
xdk:client (1446515852202): Intel XDK: 2611
xdk:client (1446515852203): Platform: win32-ia32 (6.3.9600)
xdk:client (1446515852203): NW: 0.11.7-rc7
xdk:client (1446515852404): Created new theme: base
xdk:client (1446515852404): Registered new theme: base
xdk:client (1446515852406): Current theme is now: base
xdk:client (1446515852406): Loading theme from: ../../public/themes/xdk.json
xdk:client (1446515852407): Failed to load theme: xdk { [Error: Cannot find module '../../public/themes/xdk.json'] code: 'MODULE_NOT_FOUND' }
xdk:client (1446515852915): Error SyntaxError: Unexpected token ' loading components\client\upload-manager\locale\root\text-content.json
xdk:client (1446515853004): Starting client process initialization
xdk:client (1446515853049): NW Cache is up-to-date.
xdk:client (1446515856471): memmrk:    14267848    34302336
xdk:server (1446515853511): memlim: 767557632
xdk:server (1446515853515): Setting NW crash dump to: C:\Users\Kidda\AppData\Local\XDK
xdk:server (1446515853765): Starting server process initialization
xdk:server (1446515854336): Http server started on the standard port 58889
xdk:server (1446515855476): Component "core:assert" starting import
xdk:server (1446515855477): Component "core:assert" finished initialization
xdk:server (1446515855477): Component "core:component-error" starting import
xdk:server (1446515855478): Component "core:component-error" finished initialization
xdk:server (1446515855478): Component "core:command-line-options" starting import
xdk:server (1446515855478): Component "core:command-line-options" finished initialization
xdk:server (1446515855478): Component "core:service-error" starting import
xdk:server (1446515855478): Component "core:service-error" finished initialization
xdk:server (1446515855478): Component "core:buffer" starting import
xdk:server (1446515855478): Component "core:buffer" finished initialization
xdk:server (1446515855478): Component "core:signaler" starting import
xdk:server (1446515855483): Component "core:signaler" finished initialization
xdk:server (1446515855483): Component "core:signaler-group" starting import
xdk:server (1446515855490): Component "core:signaler-group" finished initialization
xdk:server (1446515855490): Component "core:logger" starting import
xdk:server (1446515855493): Component "core:logger" finished initialization
xdk:server (1446515855495): Component "core:http-request" starting import
xdk:server (1446515855497): Component "core:http-request" finished initialization
xdk:server (1446515855497): Component "core:database" starting import
xdk:server (1446515855501): Component "core:database" finished initialization
xdk:server (1446515855501): Component "core:version" starting import
xdk:server (1446515855501): Component "core:version" finished initialization
xdk:server (1446515855501): Component "core:userfs-name-converter" starting import
xdk:server (1446515855506): Component "core:userfs-name-converter" finished initialization
xdk:server (1446515855506): Component "core:crash-handler" starting import
xdk:server (1446515855509): Component "core:crash-handler" finished initialization
xdk:server (1446515855509): Component "core:i18n-support" starting import
xdk:server (1446515855509): Component "core:i18n-support" finished initialization
xdk:server (1446515855509): Component "core:theme" starting import
xdk:server (1446515855556): Component "core:theme" finished initialization
xdk:server (1446515855557): Component "server:userfs" starting import
xdk:server (1446515855588): Component "server:userfs" calling init()
xdk:server (1446515855711): Component "server:userfs" finished initialization
xdk:server (1446515855711): Component "server:user-profile" starting import
xdk:server (1446515855728): Component "server:user-profile" calling init()
xdk:server (1446515855728): Component "server:user-profile" finished initialization
xdk:server (1446515855728): Component "server:ui-builder" starting import
xdk:server (1446515856174): Component "server:ui-builder" calling init()
xdk:server (1446515856176): Component "server:ui-builder" finished initialization
xdk:server (1446515856176): Component "server:emulator-notification" starting import
xdk:server (1446515856204): Component "server:emulator-notification" calling init()
xdk:server (1446515856205): Component "server:emulator-notification" finished initialization
xdk:server (1446515856205): Component "server:emulator-webserver" starting import
xdk:server (1446515856217): Component "server:emulator-webserver" calling init()
xdk:server (1446515856219): Component "server:emulator-webserver" finished initialization
xdk:server (1446515856219): Component "server:new-project-creator" starting import
xdk:server (1446515856247): Component "server:new-project-creator" calling init()
xdk:server (1446515856247): Component "server:new-project-creator" finished initialization
xdk:server (1446515856247): Component "server:zip-util" starting import
xdk:server (1446515856261): Component "server:zip-util" calling init()
xdk:server (1446515856261): Component "server:zip-util" finished initialization
xdk:server (1446515856261): Component "server:uuid-server" starting import
xdk:server (1446515856271): Component "server:uuid-server" calling init()
xdk:server (1446515856272): Component "server:uuid-server" finished initialization
xdk:server (1446515856272): Component "server:app-starter" starting import
xdk:server (1446515856294): Component "server:app-starter" calling init()
xdk:server (1446515856297): Component "server:app-starter" finished initialization
xdk:server (1446515856297): Component "server:force-download" starting import
xdk:server (1446515856304): Component "server:force-download" calling init()
xdk:server (1446515856304): Component "server:force-download" finished initialization
xdk:server (1446515856304): Component "server:updater" starting import
xdk:server (1446515856321): Component "server:updater" calling init()
server:updater (1446515856321): config.base-auto
server:updater (1446515856321): url=auto
xdk:server (1446515856322): Component "server:updater" finished initialization
xdk:server (1446515856322): Component "server:editor-node" starting import
xdk:server (1446515856498): Component "server:editor-node" calling init()
xdk:server (1446515856499): Component "server:editor-node" waiting for delayed initialization
xdk:server (1446515856499): Component "server:cordova-lib" starting import
xdk:server (1446515858744): Component "server:cordova-lib" calling init()
xdk:server (1446515859153): Component "server:cordova-lib" finished initialization
xdk:server (1446515859153): Component "server:api-explorer" starting import
xdk:server (1446515859170): Component "server:api-explorer" calling init()
xdk:server (1446515859421): Component "server:api-explorer" finished initialization
xdk:server (1446515859421): Component "server:plugin-listener" starting import
xdk:server (1446515859440): Component "server:plugin-listener" calling init()
xdk:server (1446515859440): Component "server:plugin-listener" finished initialization
xdk:server (1446515859440): Component "server:git-runner" starting import
xdk:server (1446515859454): Component "server:git-runner" calling init()
xdk:server (1446515859455): Component "server:git-runner" finished initialization
server:editor-node (1446515859456): Starting Brackets node process C:\Users\Kidda\AppData\Local\Intel\XDK\bin\node.exe C:\Users\Kidda\AppData\Local\Intel\XDK\bin\node-core
xdk:server (1446515859471): memmrk:    24351480    42415616
xdk:server (1446515859473): NW Cache is up-to-date.
server:editor-node (1446515859571): Brackets node is running on port 53133
xdk:server (1446515859572): Component "server:editor-node" finished delayed initialization
xdk:server (1446515859572): Component "server:ui-builder" calling start()
xdk:server (1446515859576): Component "server:ui-builder" finished start()
xdk:server (1446515859576): Component "server:emulator-webserver" calling start()
xdk:server (1446515859576): Component "server:emulator-webserver" finished start()
xdk:server (1446515859576): Component "server:editor-node" calling start()
xdk:server (1446515859576): Component "server:editor-node" finished start()
xdk:server (1446515859578): Intel XDK is initialized now
xdk:server (1446515859579): Writing to the server data file
xdk:server (1446515859583): Wrote server data to "C:\Users\Kidda\AppData\Local\XDK\server-data.txt"
xdk:client (1446515859808): Successfully read server data file
xdk:client (1446515860040): Component "core:assert" starting import
xdk:client (1446515860041): Component "core:assert" finished initialization
xdk:client (1446515860041): Component "core:component-error" starting import
xdk:client (1446515860041): Component "core:component-error" finished initialization
xdk:client (1446515860041): Component "core:command-line-options" starting import
xdk:client (1446515860041): Component "core:command-line-options" finished initialization
xdk:client (1446515860041): Component "core:service-error" starting import
xdk:client (1446515860041): Component "core:service-error" finished initialization
xdk:client (1446515860041): Component "core:buffer" starting import
xdk:client (1446515860042): Component "core:buffer" finished initialization
xdk:client (1446515860042): Component "core:signaler" starting import
xdk:client (1446515860042): Component "core:signaler" finished initialization
xdk:client (1446515860042): Component "core:signaler-group" starting import
xdk:client (1446515860044): Component "core:signaler-group" finished initialization
xdk:client (1446515860044): Component "core:logger" starting import
xdk:client (1446515860045): Component "core:logger" finished initialization
xdk:client (1446515860045): Component "core:http-request" starting import
xdk:client (1446515860046): Component "core:http-request" finished initialization
xdk:client (1446515860046): Component "core:version" starting import
xdk:client (1446515860046): Component "core:version" finished initialization
xdk:client (1446515860046): Component "core:exit-notifier" starting import
xdk:client (1446515860046): Component "core:exit-notifier" finished initialization
xdk:client (1446515860046): Component "core:userfs-name-converter" starting import
xdk:client (1446515860046): Component "core:userfs-name-converter" finished initialization
xdk:client (1446515860046): Component "core:crash-handler" starting import
xdk:client (1446515860047): Component "core:crash-handler" finished initialization
xdk:client (1446515860047): Component "core:analytics" starting import
xdk:client (1446515860047): Component "core:analytics" finished initialization
xdk:client (1446515860047): Component "core:i18n-support" starting import
xdk:client (1446515860047): Component "core:i18n-support" finished initialization
xdk:client (1446515860047): Component "core:theme" starting import
xdk:client (1446515860047): Component "core:theme" finished initialization
xdk:client (1446515860055): Analytics ID: c95391a4-cd08-49e7-b13b-4145382aeda5
xdk:client (1446515860087): Component "client:app" starting import
xdk:client (1446515860087): Component "client:help-helper" starting import
xdk:client (1446515860087): Component "client:nativefs" starting import
xdk:client (1446515860087): Component "client:document-manager" starting import
xdk:client (1446515860087): Component "client:project-manager" starting import
xdk:client (1446515860087): Component "client:aa-controller" starting import
xdk:client (1446515860088): Component "client:projects-renderers" starting import
xdk:client (1446515860088): Component "client:projects-renderers-jsapp" starting import
xdk:client (1446515860088): Component "client:projects-renderers-webapp" starting import
xdk:client (1446515860088): Component "client:projects-renderers-iotapp" starting import
xdk:client (1446515860088): Component "client:active-sync" starting import
xdk:client (1446515860088): Component "client:apk-installer" starting import
xdk:client (1446515860088): Component "client:appcenter-options" starting import
xdk:client (1446515860088): Component "client:resource-manager" starting import
xdk:client (1446515860088): Component "client:resource-cocos2d" starting import
xdk:client (1446515860088): Component "client:resource-cocos2djs" starting import
xdk:client (1446515860088): Component "client:resource-phaser" starting import
xdk:client (1446515860088): Component "client:resource-pixi" starting import
xdk:client (1446515860088): Component "client:resource-easeljs" starting import
xdk:client (1446515860088): Component "client:resource-plain" starting import
xdk:client (1446515860088): Component "client:resource-render-frame" starting import
xdk:client (1446515860088): Component "client:resource-util" starting import
xdk:client (1446515860088): Component "client:services-tab" starting import
xdk:client (1446515860088): Component "client:editor" starting import
xdk:client (1446515860088): Component "client:live-preview" starting import
xdk:client (1446515860088): Component "client:backend-services" starting import
xdk:client (1446515860088): Component "client:backend-feeds" starting import
xdk:client (1446515860088): Component "client:merged-feed" starting import
xdk:client (1446515860088): Component "client:backend-services-ext" starting import
xdk:client (1446515860088): Component "client:backend-service-utils" starting import
xdk:client (1446515860088): Component "client:app-starter" starting import
xdk:client (1446515860088): Component "client:ui-builder-client" starting import
xdk:client (1446515860088): Component "client:project-meta" starting import
xdk:client (1446515860088): Component "client:contenttype-registry" starting import
xdk:client (1446515860088): Component "client:editor-registry" starting import
xdk:client (1446515860088): Component "client:platform-registry" starting import
xdk:client (1446515860088): Component "client:projecttype-registry" starting import
xdk:client (1446515860088): Component "client:library-registry" starting import
xdk:client (1446515860088): Component "client:cordova-registry" starting import
xdk:client (1446515860088): Component "client:service-method" starting import
xdk:client (1446515860088): Component "client:settings-db" starting import
xdk:client (1446515860088): Component "client:adb" starting import
xdk:client (1446515860088): Component "client:iosdb" starting import
xdk:client (1446515860089): Component "client:device" starting import
xdk:client (1446515860089): Component "client:device-discovery" starting import
xdk:client (1446515860089): Component "client:dialog-box" starting import
xdk:client (1446515860089): Component "client:test-local-server" starting import
xdk:client (1446515860089): Component "client:quick-tour" starting import
xdk:client (1446515860089): Component "client:hot-keys" starting import
xdk:client (1446515860089): Component "client:persistance" starting import
xdk:client (1446515860089): Component "client:tabs" starting import
xdk:client (1446515860089): Component "client:hash-utils" starting import
xdk:client (1446515860089): Component "client:file-watcher" starting import
xdk:client (1446515860089): Component "client:tool-tip" starting import
xdk:client (1446515860089): Component "client:cordova" starting import
xdk:client (1446515860089): Component "client:settings-ui" starting import
xdk:client (1446515860089): Component "client:external-links" starting import
xdk:client (1446515860089): Component "client:external-editors-runner" starting import
xdk:client (1446515860089): Component "client:project-list-load" starting import
xdk:client (1446515860089): Component "client:upload-manager" starting import
xdk:client (1446515860089): Component "client:git-manager" starting import
xdk:client (1446515860119): Component "client:help-helper" finished initialization
xdk:client (1446515860131): Component "client:nativefs" finished initialization
xdk:client (1446515860225): Component "client:active-sync" calling init()
xdk:client (1446515860225): Component "client:active-sync" finished initialization
xdk:client (1446515860230): Component "client:apk-installer" calling init()
xdk:client (1446515860230): Component "client:apk-installer" finished initialization
xdk:client (1446515860330): Component "client:resource-render-frame" calling init()
xdk:client (1446515860330): Component "client:resource-render-frame" waiting for delayed initialization
xdk:client (1446515860331): Component "client:resource-util" calling init()
xdk:client (1446515860331): Component "client:resource-util" finished initialization
xdk:client (1446515860332): Component "client:resource-render-frame" finished delayed initialization
xdk:client (1446515860357): Component "client:backend-services" calling init()
xdk:client (1446515860358): Component "client:backend-services" finished initialization
xdk:client (1446515860365): Component "client:backend-feeds" calling init()
xdk:client (1446515860365): Component "client:backend-feeds" finished initialization
xdk:client (1446515860366): Component "client:backend-services-ext" calling init()
xdk:client (1446515860366): Component "client:backend-services-ext" finished initialization
xdk:client (1446515860367): Component "client:merged-feed" finished initialization
xdk:client (1446515860368): Component "client:backend-service-utils" finished initialization
xdk:client (1446515860383): Component "client:project-meta" calling init()
xdk:client (1446515860383): Component "client:project-meta" finished initialization
xdk:client (1446515860479): Component "client:service-method" finished initialization
xdk:client (1446515860508): Component "client:settings-db" calling init()
xdk:client (1446515860510): Component "client:settings-db" waiting for delayed initialization
xdk:client (1446515860522): Component "client:adb" calling init()
xdk:client (1446515860535): Component "client:adb" waiting for delayed initialization
xdk:client (1446515860537): Component "client:iosdb" calling init()
xdk:client (1446515860537): Component "client:iosdb" finished initialization
xdk:client (1446515860543): Component "client:device" finished initialization
xdk:client (1446515860624): Component "client:persistance" calling init()
xdk:client (1446515860624): Component "client:persistance" waiting for delayed initialization
xdk:client (1446515860687): Component "client:file-watcher" calling init()
xdk:client (1446515860687): Component "client:file-watcher" finished initialization
xdk:client (1446515860712): Component "client:external-links" finished initialization
xdk:client (1446515860714): Component "client:external-editors-runner" calling init()
xdk:client (1446515860714): Component "client:external-editors-runner" finished initialization
xdk:client (1446515860727): Component "client:upload-manager" calling init()
xdk:client (1446515860727): Component "client:upload-manager" finished initialization
xdk:client (1446515860740): Component "client:project-list-load" calling init()
xdk:client (1446515860740): Component "client:project-list-load" waiting for delayed initialization
xdk:client (1446515860754): Component "client:git-manager" calling init()
client:git-manager (1446515860754): git path =  C:\Users\Kidda\AppData\Local\Intel\XDK\bin\git\bin\git.exe
xdk:client (1446515860754): Component "client:git-manager" waiting for delayed initialization
xdk:client (1446515860757): Component "client:app-starter" finished initialization
xdk:client (1446515860759): Component "client:hot-keys" calling init()
xdk:client (1446515860759): Component "client:hot-keys" finished initialization
client:adb (1446515860789): Using existing adb at "C:\Users\Kidda\AppData\Local\Intel\XDK\bin\adb\adb.exe"
xdk:client (1446515860816): Component "client:test-local-server" calling init()
xdk:client (1446515860847): Component "client:test-local-server" finished initialization
xdk:client (1446515860848): Component "client:adb" finished delayed initialization
xdk:client (1446515860849): Component "client:document-manager" calling init()
xdk:client (1446515860849): Component "client:document-manager" finished initialization
xdk:client (1446515860856): Component "client:aa-controller" calling init()
xdk:client (1446515860856): Component "client:aa-controller" finished initialization
xdk:client (1446515860992): Component "client:appcenter-options" calling init()
xdk:client (1446515860993): Component "client:appcenter-options" waiting for delayed initialization
xdk:client (1446515861145): Component "client:services-tab" calling init()
xdk:client (1446515861146): Component "client:services-tab" finished initialization
xdk:client (1446515861173): Component "client:ui-builder-client" calling init()
xdk:client (1446515861173): Component "client:ui-builder-client" finished initialization
xdk:client (1446515861203): Component "client:contenttype-registry" calling init()
xdk:client (1446515861204): Component "client:contenttype-registry" finished initialization
xdk:client (1446515861205): Component "client:editor-registry" finished initialization
xdk:client (1446515861218): Component "client:library-registry" calling init()
xdk:client (1446515861218): Component "client:library-registry" finished initialization
xdk:client (1446515861275): Component "client:device-discovery" calling init()
xdk:client (1446515861275): Component "client:device-discovery" waiting for delayed initialization
xdk:client (1446515861276): Component "client:device-discovery" finished delayed initialization
xdk:client (1446515861287): Component "client:dialog-box" finished initialization
xdk:client (1446515861299): Component "client:tabs" finished initialization
xdk:client (1446515861302): Component "client:hash-utils" finished initialization
xdk:client (1446515861309): Component "client:quick-tour" calling init()
xdk:client (1446515861309): Component "client:quick-tour" finished initialization
xdk:client (1446515861311): Component "client:settings-db" finished delayed initialization
xdk:client (1446515861314): Component "client:tool-tip" finished initialization
xdk:client (1446515861319): Component "client:app" calling init()
xdk:client (1446515861329): Component "client:app" finished initialization
xdk:client (1446515861330): Component "client:settings-ui" finished initialization
xdk:client (1446515861330): Component "client:navbar" starting import
xdk:client (1446515861330): Component "client:tweets" starting import
xdk:client (1446515861330): Component "client:projects-tab" starting import
xdk:client (1446515861331): Component "client:test-tab" starting import
xdk:client (1446515861331): Component "client:profilingTab" starting import
xdk:client (1446515861331): Component "client:emulator" starting import
xdk:client (1446515861331): Component "client:remote-tab" starting import
xdk:client (1446515861331): Component "client:build-tab" starting import
xdk:client (1446515861331): Component "client:editor-tab" starting import
xdk:client (1446515861331): Component "client:account" starting import
xdk:client (1446515861331): Component "client:project-selector" starting import
xdk:client (1446515861333): Component "client:git-manager" finished delayed initialization
xdk:client (1446515861462): Component "client:cordova" calling init()
xdk:client (1446515861463): Component "client:cordova" waiting for delayed initialization
xdk:client (1446515861476): memmrk:    19902288    37337216
xdk:client (1446515861481): Component "client:projects-renderers" calling init()
xdk:client (1446515861481): Component "client:projects-renderers" waiting for delayed initialization
xdk:client (1446515861481): Component "client:projects-renderers-iotapp" calling init()
xdk:client (1446515861482): Component "client:projects-renderers-iotapp" finished initialization
xdk:client (1446515861495): Component "client:project-manager" calling init()
xdk:client (1446515861495): Component "client:project-manager" waiting for delayed initialization
xdk:client (1446515861505): Component "client:cordova" finished delayed initialization
xdk:client (1446515861520): Component "client:resource-cocos2d" calling init()
xdk:client (1446515861520): Component "client:resource-cocos2d" waiting for delayed initialization
xdk:client (1446515861521): Component "client:resource-cocos2d" finished delayed initialization
xdk:client (1446515861606): Component "client:resource-cocos2djs" calling init()
xdk:client (1446515861607): Component "client:resource-cocos2djs" finished initialization
xdk:client (1446515861706): Component "client:resource-manager" calling init()
xdk:client (1446515861707): Component "client:resource-manager" waiting for delayed initialization
xdk:client (1446515861751): Component "client:resource-phaser" calling init()
xdk:client (1446515861751): Component "client:resource-phaser" finished initialization
xdk:client (1446515861753): Component "client:resource-easeljs" calling init()
xdk:client (1446515861753): Component "client:resource-easeljs" finished initialization
xdk:client (1446515861778): Component "client:resource-pixi" calling init()
xdk:client (1446515861778): Component "client:resource-pixi" finished initialization
xdk:client (1446515861787): Component "client:resource-plain" calling init()
xdk:client (1446515861787): Component "client:resource-plain" finished initialization
xdk:client (1446515861856): Component "client:platform-registry" calling init()
xdk:client (1446515861857): Component "client:platform-registry" finished initialization
xdk:client (1446515861875): Component "client:projecttype-registry" calling init()
xdk:client (1446515861875): Component "client:projecttype-registry" finished initialization
xdk:client (1446515861909): Component "client:cordova-registry" calling init()
xdk:client (1446515861909): Component "client:cordova-registry" waiting for delayed initialization
client:appcenter-options (1446515861926): Fetch Status: 1, Message: Feched latest appcenter-options info because network is available.
xdk:client (1446515861927): Component "client:appcenter-options" finished delayed initialization
xdk:client (1446515862082): Component "client:projects-renderers-webapp" calling init()
xdk:client (1446515862082): Component "client:projects-renderers-webapp" finished initialization
xdk:client (1446515862088): Component "client:projects-renderers-jsapp" calling init()
xdk:client (1446515862088): Component "client:projects-renderers-jsapp" finished initialization
xdk:client (1446515862090): Component "client:projects-renderers" finished delayed initialization
xdk:client (1446515862131): Component "client:tweets" finished initialization
xdk:client (1446515862224): Component "client:cordova-registry" finished delayed initialization
xdk:client (1446515862256): Component "client:projects-tab" getting UI region for "project"
xdk:client (1446515862257): Component "client:projects-tab" calling init()
xdk:client (1446515862258): Component "client:projects-tab" waiting for delayed initialization
xdk:client (1446515862285): Component "client:test-tab" getting UI region for "test"
xdk:client (1446515862285): Component "client:test-tab" calling init()
xdk:client (1446515862285): Component "client:test-tab" waiting for delayed initialization
xdk:client (1446515862287): Component "client:test-tab" finished delayed initialization
xdk:client (1446515862356): Component "client:account" getting UI region for "account"
xdk:client (1446515862356): Component "client:account" calling init()
xdk:client (1446515862361): Component "client:account" finished initialization
xdk:client (1446515862403): Component "client:emulator" getting UI region for "emulate"
xdk:client (1446515862403): Component "client:emulator" calling init()
xdk:client (1446515862405): Component "client:emulator" finished initialization
xdk:client (1446515862425): Component "client:build-tab" getting UI region for "build"
xdk:client (1446515862425): Component "client:build-tab" calling init()
xdk:client (1446515862430): Component "client:build-tab" finished initialization
xdk:client (1446515862431): Component "client:project-selector" getting UI region for "project-selector"
xdk:client (1446515862431): Component "client:project-selector" calling init()
xdk:client (1446515862431): Component "client:project-selector" finished initialization
xdk:client (1446515862548): Component "client:navbar" getting UI region for "navbar-common"
xdk:client (1446515862548): Component "client:navbar" calling init()
client:navbar (1446515862549): navbar options: {"common":{"servicesVersion":"release-2015-ww38","xdkVariant":"xdk"},"updatePollingInterval":1800,"forceUpdate":false}
xdk:client (1446515862549): Component "client:navbar" finished initialization
xdk:client (1446515862557): Component "client:live-preview" calling init()
xdk:client (1446515862557): Component "client:live-preview" finished initialization
xdk:client (1446515862557): Component "client:editor" calling init()
xdk:client (1446515862557): Component "client:editor" finished initialization
xdk:client (1446515862557): Component "client:editor-tab" getting UI region for "develop"
xdk:client (1446515862557): Component "client:editor-tab" calling init()
xdk:client (1446515862568): Component "client:editor-tab" waiting for delayed initialization
xdk:client (1446515862607): Component "client:remote-tab" getting UI region for "debug"
xdk:client (1446515862607): Component "client:remote-tab" calling init()
xdk:client (1446515862933): Component "client:remote-tab" waiting for delayed initialization
xdk:client (1446515862934): Component "client:remote-tab" finished delayed initialization
xdk:client (1446515864028): Component "client:profilingTab" getting UI region for "profile"
xdk:client (1446515864028): Component "client:profilingTab" calling init()
xdk:client (1446515864029): Component "client:profilingTab" finished initialization
xdk:server (1446515864474): memmrk:    44997840    59657856
xdk:client (1446515866474): memmrk:    36799360    70830336
xdk:server (1446515869475): memmrk:    43038456    95182336
xdk:client (1446515870548): Component "client:project-manager" finished delayed initialization
xdk:client (1446515870576): Component "client:project-list-load" finished delayed initialization
xdk:client (1446515870638): Component "client:resource-manager" finished delayed initialization
xdk:client (1446515870638): Component "client:projects-tab" finished delayed initialization
xdk:client (1446515870638): Component "client:projects-list" starting import
xdk:client (1446515870639): Component "client:projects-info" starting import
xdk:client (1446515870639): Component "client:projects-create-list" starting import
xdk:client (1446515870639): Component "client:projects-create-info" starting import
xdk:client (1446515870715): Component "client:projects-list" getting UI region for "existing-list"
xdk:client (1446515870715): Component "client:projects-list" calling init()
xdk:client (1446515870716): Component "client:projects-list" finished initialization
xdk:client (1446515870723): Component "client:projects-info" getting UI region for "existing-info"
xdk:client (1446515870723): Component "client:projects-info" calling init()
xdk:client (1446515870724): Component "client:projects-info" finished initialization
xdk:client (1446515870821): Component "client:projects-create-info" getting UI region for "create-info"
xdk:client (1446515870822): Component "client:projects-create-info" calling init()
xdk:client (1446515870822): Component "client:projects-create-info" finished initialization
xdk:client (1446515870990): Component "client:projects-create-list" getting UI region for "create-list"
xdk:client (1446515870990): Component "client:projects-create-list" calling init()
xdk:client (1446515870990): Component "client:projects-create-list" finished initialization
xdk:client (1446515871526): memmrk:    29759460    57732736
client:services-tab (1446515873460): component:services-tab : Container provided by brackets :
client:services-tab (1446515873461): component:services-tab : mainContainer_ = XDKMiniServices-main
client:services-tab (1446515873461): component:services-tab : sidebarContainer = XDKMiniServices-list
client:services-tab (1446515873461): component:services-tab : Iframes inserted by services-tab : .
client:services-tab (1446515873461): component:services-tab : $mainContainer_ = mini-api-explorer
client:services-tab (1446515873461): component:services-tab : $sidebarContainer_ = api-sidebar
xdk:client (1446515873543): Component "client:editor-tab" finished delayed initialization
xdk:client (1446515875112): Component "client:persistance" finished delayed initialization
xdk:client (1446515875114): Component "client:app" calling start()
xdk:client (1446515875127): Component "client:app" finished start()
xdk:client (1446515875128): Component "client:navbar" calling start()
xdk:client (1446515875144): Component "client:navbar" finished start()
xdk:client (1446515875144): Component "client:project-manager" calling start()
xdk:client (1446515875144): Component "client:project-manager" finished start()
xdk:client (1446515875144): Component "client:aa-controller" calling start()
xdk:client (1446515875144): Component "client:aa-controller" finished start()
xdk:client (1446515875145): Component "client:projects-tab" calling start()
xdk:client (1446515875154): Component "client:projects-tab" finished start()
xdk:client (1446515875154): Component "client:projects-list" calling start()
xdk:client (1446515875157): Component "client:projects-list" finished start()
xdk:client (1446515875157): Component "client:projects-info" calling start()
xdk:client (1446515875159): Component "client:projects-info" finished start()
xdk:client (1446515875159): Component "client:projects-create-list" calling start()
xdk:client (1446515875199): Component "client:projects-create-list" finished start()
xdk:client (1446515875199): Component "client:projects-create-info" calling start()
xdk:client (1446515875209): Component "client:projects-create-info" finished start()
xdk:client (1446515875209): Component "client:test-tab" calling start()
xdk:client (1446515875212): Component "client:test-tab" finished start()
xdk:client (1446515875212): Component "client:profilingTab" calling start()
xdk:client (1446515875271): Component "client:profilingTab" finished start()
xdk:client (1446515875271): Component "client:emulator" calling start()
xdk:client (1446515875271): Component "client:emulator" finished start()
xdk:client (1446515875272): Component "client:remote-tab" calling start()
xdk:client (1446515875278): Component "client:remote-tab" finished start()
xdk:client (1446515875278): Component "client:build-tab" calling start()
xdk:client (1446515875281): Component "client:build-tab" finished start()
xdk:client (1446515875281): Component "client:active-sync" calling start()
xdk:client (1446515875281): Component "client:active-sync" finished start()
xdk:client (1446515875281): Component "client:apk-installer" calling start()
xdk:client (1446515875282): Component "client:apk-installer" finished start()
xdk:client (1446515875282): Component "client:resource-manager" calling start()
xdk:client (1446515875282): Component "client:resource-manager" finished start()
xdk:client (1446515875282): Component "client:resource-cocos2d" calling start()
xdk:client (1446515875282): Component "client:resource-cocos2d" finished start()
xdk:client (1446515875282): Component "client:resource-cocos2djs" calling start()
xdk:client (1446515875282): Component "client:resource-cocos2djs" finished start()
xdk:client (1446515875282): Component "client:resource-phaser" calling start()
xdk:client (1446515875282): Component "client:resource-phaser" finished start()
xdk:client (1446515875282): Component "client:resource-pixi" calling start()
xdk:client (1446515875282): Component "client:resource-pixi" finished start()
xdk:client (1446515875282): Component "client:resource-easeljs" calling start()
xdk:client (1446515875282): Component "client:resource-easeljs" finished start()
xdk:client (1446515875282): Component "client:resource-plain" calling start()
xdk:client (1446515875283): Component "client:resource-plain" finished start()
xdk:client (1446515875283): Component "client:resource-render-frame" calling start()
xdk:client (1446515875283): Component "client:resource-render-frame" finished start()
xdk:client (1446515875283): Component "client:resource-util" calling start()
xdk:client (1446515875283): Component "client:resource-util" finished start()
xdk:client (1446515875283): Component "client:editor" calling start()
xdk:client (1446515875283): Component "client:editor" finished start()
xdk:client (1446515875283): Component "client:editor-tab" calling start()
xdk:client (1446515875302): Component "client:editor-tab" finished start()
xdk:client (1446515875302): Component "client:live-preview" calling start()
xdk:client (1446515875302): Component "client:live-preview" finished start()
xdk:client (1446515875302): Component "client:account" calling start()
xdk:client (1446515875303): Component "client:account" finished start()
xdk:client (1446515875303): Component "client:project-selector" calling start()
xdk:client (1446515875305): Component "client:project-selector" finished start()
xdk:client (1446515875305): Component "client:app-starter" calling start()
xdk:client (1446515875305): Component "client:app-starter" finished start()
xdk:client (1446515875305): Component "client:ui-builder-client" calling start()
xdk:client (1446515875307): Component "client:ui-builder-client" finished start()
xdk:client (1446515875307): Component "client:project-meta" calling start()
xdk:client (1446515875307): Component "client:project-meta" finished start()
xdk:client (1446515875307): Component "client:cordova-registry" calling start()
xdk:client (1446515875307): Component "client:cordova-registry" finished start()
xdk:client (1446515875308): Component "client:adb" calling start()
xdk:client (1446515875308): Component "client:adb" finished start()
xdk:client (1446515875308): Component "client:iosdb" calling start()
xdk:client (1446515875311): Component "client:iosdb" finished start()
xdk:client (1446515875311): Component "client:device-discovery" calling start()
xdk:client (1446515875314): Component "client:device-discovery" finished start()
xdk:client (1446515875314): Component "client:test-local-server" calling start()
xdk:client (1446515875314): Component "client:test-local-server" finished start()
xdk:client (1446515875314): Component "client:quick-tour" calling start()
xdk:client (1446515875315): Component "client:quick-tour" finished start()
xdk:client (1446515875315): Component "client:hot-keys" calling start()
xdk:client (1446515875316): Component "client:hot-keys" finished start()
xdk:client (1446515875316): Component "client:persistance" calling start()
xdk:client (1446515875317): Component "client:persistance" finished start()
xdk:client (1446515875317): Component "client:file-watcher" calling start()
xdk:client (1446515875317): Component "client:file-watcher" finished start()
xdk:client (1446515875317): Component "client:cordova" calling start()
xdk:client (1446515875318): Component "client:cordova" finished start()
xdk:client (1446515875318): Component "client:external-editors-runner" calling start()
xdk:client (1446515875319): Component "client:external-editors-runner" finished start()
xdk:client (1446515875319): Component "client:upload-manager" calling start()
xdk:client (1446515875319): Component "client:upload-manager" finished start()
xdk:client (1446515875333): Intel XDK is initialized now
xdk:server (1446515876096): memmrk:    69787092    97201536
client:navbar (1446515876375): pollForUpdates called
client:services-tab (1446515876489): Iframe onLoad resolved for : http://127.0.0.1:58889/http-services/api-explorer/iodocs/index?
client:services-tab (1446515876491): Iframe onLoad resolved for : http://127.0.0.1:58889/http-services/api-explorer/iodocs/sidebar?
client:services-tab (1446515876492): Both iframes loaded promise resolved.
client:services-tab (1446515876495): Calling postmessage for project refresh.
client:services-tab (1446515876495): sidebar container window : true
client:services-tab (1446515876495): sidebar container document : true
client:services-tab (1446515876495): main container window : true
client:services-tab (1446515876495): main container document : true
client:services-tab (1446515876495): component:services-tab:postMessageToWindow target = project
xdk:client (1446515877323): memmrk:    46598112    81020416
client:navbar (1446515877894): polling up-to-date
xdk:server (1446515881096): memmrk:    82658124    104311296
xdk:client (1446515882320): memmrk:    47518008    81020416
xdk:server (1446515886096): memmrk:    37896304    104311296
xdk:client (1446515887320): memmrk:    48616552    81020416
xdk:server (1446515891097): memmrk:    23003764    65258496
xdk:client (1446515892321): memmrk:    49759892    81020416
xdk:server (1446515896098): memmrk:    23014368    65258496
xdk:client (1446515897322): memmrk:    51941952    81020416
xdk:server (1446515901098): memmrk:    22727948    45997056
xdk:client (1446515902323): memmrk:    52512204    81020416
xdk:server (1446515906099): memmrk:    21618212    29758336
xdk:client (1446515907323): memmrk:    47648820    81020416
xdk:server (1446515911099): memmrk:    21663028    29758336
xdk:client (1446515912322): memmrk:    47827888    81020416
xdk:server (1446515916099): memmrk:    21209372    29758336
xdk:client (1446515917322): memmrk:    47967656    81020416
xdk:server (1446515921099): memmrk:    21227676    30806912
xdk:client (1446515922322): memmrk:    48448928    81020416
xdk:server (1446515926100): memmrk:    20555884    29791232
xdk:client (1446515927323): memmrk:    49947196    81020416
xdk:server (1446515931101): memmrk:    20927024    29791232
xdk:client (1446515932325): memmrk:    50127076    81020416
xdk:server (1446515936102): memmrk:    20933724    29791232
xdk:client (1446515937325): memmrk:    50231016    81020416
xdk:server (1446515941103): memmrk:    20940100    29791232
xdk:client (1446515942326): memmrk:    50453840    81020416
xdk:server (1446515946103): memmrk:    20946476    29791232
xdk:client (1446515947327): memmrk:    42264192    81020416
xdk:server (1446515951103): memmrk:    20952852    29791232
xdk:client (1446515952327): memmrk:    42583460    81020416
xdk:server (1446515956104): memmrk:    20959228    29791232
xdk:client (1446515957329): memmrk:    42703584    81020416
xdk:server (1446515961104): memmrk:    20965600    29791232
xdk:client (1446515962330): memmrk:    41079320    59222016
xdk:server (1446515966105): memmrk:    20971976    29791232
xdk:client (1446515968323): memmrk:    37151784    57202816
xdk:server (1446515971105): memmrk:    20978352    29791232
xdk:client (1446515973321): memmrk:    36197776    53176576
xdk:server (1446515976105): memmrk:    20988756    29791232
xdk:client (1446515979316): memmrk:    36169212    54225152
xdk:server (1446515981108): memmrk:    20995132    29791232
xdk:client (1446515984316): memmrk:    34865432    54225152
xdk:server (1446515986108): memmrk:    21001508    29791232
xdk:client (1446515989316): memmrk:    35019980    54225152
xdk:server (1446515991108): memmrk:    21006964    29791232
xdk:client (1446515994315): memmrk:    35120212    54225152
xdk:server (1446515996108): memmrk:    21013324    29791232
xdk:client (1446515999315): memmrk:    35271944    54225152
xdk:server (1446516001108): memmrk:    21019700    29791232
xdk:client (1446516004316): memmrk:    35371312    54225152
xdk:server (1446516006108): memmrk:    21028308    29791232
xdk:client (1446516009315): memmrk:    35540924    54225152
xdk:server (1446516011108): memmrk:    21038096    29791232
xdk:client (1446516014315): memmrk:    35650720    54225152
xdk:server (1446516016110): memmrk:    21044472    29791232
xdk:client (1446516019316): memmrk:    35798772    54225152
xdk:server (1446516021111): memmrk:    21061416    29791232
xdk:client (1446516024315): memmrk:    35903264    54225152
xdk:server (1446516026111): memmrk:    21067776    29791232
xdk:client (1446516029315): memmrk:    35329152    54225152
xdk:server (1446516031111): memmrk:    21074120    29791232
xdk:client (1446516034317): memmrk:    35430176    54225152
xdk:server (1446516036112): memmrk:    21084756    29791232
xdk:client (1446516039317): memmrk:    35578228    54225152
xdk:server (1446516041112): memmrk:    21093704    29791232
xdk:client (1446516044316): memmrk:    35704120    54225152
xdk:server (1446516046112): memmrk:    21100048    29791232
xdk:client (1446516049316): memmrk:    35857108    54225152
xdk:server (1446516051113): memmrk:    21106376    29791232
xdk:client (1446516054318): memmrk:    35959064    54225152
xdk:server (1446516056114): memmrk:    21112720    29791232
xdk:client (1446516059316): memmrk:    35579812    54225152
xdk:server (1446516061115): memmrk:    21119048    29791232
xdk:client (1446516064316): memmrk:    35688580    54225152
xdk:server (1446516066115): memmrk:    21125392    29791232
xdk:client (1446516069316): memmrk:    35838700    54225152
xdk:server (1446516071115): memmrk:    21131736    29791232
xdk:client (1446516074316): memmrk:    35951816    54225152
xdk:server (1446516076116): memmrk:    21138080    29791232
xdk:client (1446516079316): memmrk:    36099632    54225152
xdk:server (1446516081117): memmrk:    21144424    29791232
xdk:client (1446516084316): memmrk:    36198680    54225152
xdk:server (1446516086117): memmrk:    21150768    29791232
xdk:client (1446516089318): memmrk:    36346372    54225152
xdk:server (1446516091117): memmrk:    21157112    29791232
xdk:client (1446516094317): memmrk:    36445420    54225152
xdk:server (1446516096118): memmrk:    21163456    29791232
xdk:client (1446516099316): memmrk:    35995104    54225152
xdk:server (1446516101119): memmrk:    21169800    29791232
xdk:client (1446516104316): memmrk:    36094152    54225152
xdk:server (1446516106119): memmrk:    21176144    29791232
xdk:client (1446516109316): memmrk:    36244284    54225152
xdk:server (1446516111120): memmrk:    21182488    29791232
xdk:client (1446516114316): memmrk:    36343332    54225152
xdk:server (1446516116120): memmrk:    21188832    29791232
xdk:client (1446516119318): memmrk:    36619616    54225152
xdk:server (1446516121121): memmrk:    21538512    29791232
xdk:client (1446516124320): memmrk:    38027156    56322304
xdk:server (1446516126122): memmrk:    21544856    29791232
xdk:client (1446516129321): memmrk:    38179320    56322304
xdk:server (1446516131122): memmrk:    21551200    29791232
xdk:client (1446516134322): memmrk:    41301768    56322304
xdk:server (1446516136124): memmrk:    21560772    29791232
xdk:client (1446516139323): memmrk:    41257196    56322304
xdk:server (1446516141124): memmrk:    21567116    29791232
xdk:client (1446516144324): memmrk:    38154864    60516608
xdk:server (1446516146125): memmrk:    21573460    29791232
xdk:client (1446516149326): memmrk:    39070860    60516608
xdk:server (1446516151126): memmrk:    21579804    29791232
xdk:client (1446516154333): memmrk:    39673024    60516608
xdk:server (1446516156127): memmrk:    22527688    38101888
uib-client (1446516156424): gradeHTMLFile 1 /C/Users/Kidda/Documents/Arthoria/www/index.html
client:services-tab (1446516158664): Calling postmessage for project refresh.
client:services-tab (1446516158664): sidebar container window : true
client:services-tab (1446516158664): sidebar container document : true
client:services-tab (1446516158664): main container window : true
client:services-tab (1446516158664): main container document : true
client:services-tab (1446516158664): component:services-tab:postMessageToWindow target = project
xdk:client (1446516159335): memmrk:    52992072    78460800
xdk:server (1446516161127): memmrk:    57862596    73206912
xdk:client (1446516165322): memmrk:    63622552    82998912
xdk:server (1446516166128): memmrk:    58499656    73206912
xdk:client (1446516170316): memmrk:    50320436    82998912
xdk:server (1446516171129): memmrk:    58512532    73206912
xdk:client (1446516175327): memmrk:    43403532    59234176
xdk:server (1446516176130): memmrk:    26083652    62717056
xdk:client (1446516180318): memmrk:    43267316    58218496
xdk:server (1446516181131): memmrk:    23079804    32781056
xdk:client (1446516185315): memmrk:    40579580    57214976
xdk:server (1446516186131): memmrk:    23090588    32781056
xdk:client (1446516190316): memmrk:    40432360    53188736
xdk:server (1446516191132): memmrk:    22679600    30761856
xdk:client (1446516195317): memmrk:    40394716    53221632
xdk:server (1446516196132): memmrk:    21727512    28742656
xdk:client (1446516200316): memmrk:    39080788    53221632
xdk:server (1446516201132): memmrk:    21735232    28742656
xdk:client (1446516205316): memmrk:    39184360    53221632
xdk:server (1446516206132): memmrk:    21502216    28775552
xdk:client (1446516210316): memmrk:    39339276    53221632
xdk:server (1446516211133): memmrk:    21075172    28775552
xdk:client (1446516215315): memmrk:    39441304    53221632
xdk:server (1446516216134): memmrk:    21082352    28775552
xdk:client (1446516220317): memmrk:    39593592    53221632
xdk:server (1446516221134): memmrk:    21088712    28775552
xdk:client (1446516225316): memmrk:    39709708    53221632
xdk:server (1446516226135): memmrk:    21095096    28775552
xdk:client (1446516230316): memmrk:    39877324    53221632
xdk:server (1446516231136): memmrk:    21101456    28775552
xdk:client (1446516235315): memmrk:    39987732    53221632
xdk:server (1446516236136): memmrk:    21107816    28775552
xdk:client (1446516240315): memmrk:    40140488    53221632
xdk:server (1446516241136): memmrk:    21114176    28775552
xdk:client (1446516245316): memmrk:    39559980    53221632
xdk:server (1446516246136): memmrk:    21122944    28775552
xdk:client (1446516250316): memmrk:    39711660    53221632
xdk:server (1446516251136): memmrk:    21129304    28775552
xdk:client (1446516255316): memmrk:    39826784    53221632
xdk:server (1446516256137): memmrk:    21135664    28775552
xdk:client (1446516260315): memmrk:    39974204    53221632
xdk:server (1446516261137): memmrk:    21142024    28775552
xdk:client (1446516265315): memmrk:    40075432    53221632
xdk:server (1446516266137): memmrk:    21148384    28775552
xdk:client (1446516270315): memmrk:    40222852    53221632
xdk:server (1446516271137): memmrk:    21154744    28775552
xdk:client (1446516275315): memmrk:    39789700    53221632
xdk:server (1446516276137): memmrk:    21161104    28775552
xdk:client (1446516280315): memmrk:    39937120    53221632
xdk:server (1446516281137): memmrk:    21167464    28775552
xdk:client (1446516285317): memmrk:    40035992    53221632
xdk:server (1446516286138): memmrk:    21173824    28775552
xdk:client (1446516290316): memmrk:    40200944    53221632
xdk:server (1446516291139): memmrk:    21180184    28775552
xdk:client (1446516295317): memmrk:    40299816    53221632
xdk:server (1446516296139): memmrk:    21186544    28775552
xdk:client (1446516300317): memmrk:    40451176    53221632
xdk:server (1446516301139): memmrk:    21192904    28775552
xdk:client (1446516305317): memmrk:    40550048    53221632
xdk:server (1446516306139): memmrk:    21199264    28775552
xdk:client (1446516310317): memmrk:    40700616    53221632
xdk:server (1446516311141): memmrk:    21212144    28775552
xdk:client (1446516315318): memmrk:    40199660    53221632
xdk:server (1446516316141): memmrk:    21218488    28775552
xdk:client (1446516320316): memmrk:    40346984    53221632
xdk:server (1446516321141): memmrk:    21224832    28775552
xdk:client (1446516325316): memmrk:    40445792    53221632
xdk:server (1446516326142): memmrk:    21231176    28775552
xdk:client (1446516330317): memmrk:    40594792    53221632
xdk:server (1446516331143): memmrk:    21237520    28775552
xdk:client (1446516335317): memmrk:    40696648    53221632
xdk:server (1446516336144): memmrk:    21243864    28775552
xdk:client (1446516340316): memmrk:    40859588    53221632
xdk:server (1446516341144): memmrk:    21250208    28775552
xdk:client (1446516345316): memmrk:    40958396    53221632
xdk:server (1446516346145): memmrk:    21256552    28775552
xdk:client (1446516350315): memmrk:    40528972    55318784
xdk:server (1446516351146): memmrk:    21262896    28775552
xdk:client (1446516355315): memmrk:    40627800    55318784
xdk:server (1446516356148): memmrk:    21269240    28775552
xdk:client (1446516360316): memmrk:    40775656    55318784
xdk:server (1446516361148): memmrk:    21275584    28775552
xdk:client (1446516365316): memmrk:    40876284    55318784
xdk:server (1446516366149): memmrk:    21281928    28775552
xdk:client (1446516370316): memmrk:    41026036    55318784
xdk:server (1446516371149): memmrk:    21288272    28775552
xdk:client (1446516375316): memmrk:    41124844    55318784
xdk:server (1446516376150): memmrk:    21294616    28775552
xdk:client (1446516380317): memmrk:    41276156    55318784
xdk:server (1446516381150): memmrk:    21300960    28775552
xdk:client (1446516385316): memmrk:    41375116    55318784
xdk:server (1446516386151): memmrk:    21307304    28775552
xdk:client (1446516390316): memmrk:    41531212    55318784
xdk:server (1446516391151): memmrk:    21313648    28775552
xdk:client (1446516395315): memmrk:    41627484    55318784
xdk:server (1446516396151): memmrk:    21319992    28775552
xdk:client (1446516400315): memmrk:    41772340    55318784
xdk:server (1446516401152): memmrk:    21326336    28775552
xdk:client (1446516405317): memmrk:    41900788    55318784
xdk:server (1446516406152): memmrk:    21332680    28775552
xdk:client (1446516410316): memmrk:    42044308    55318784
xdk:server (1446516411153): memmrk:    21339024    28775552
xdk:client (1446516415317): memmrk:    42143524    55318784
xdk:server (1446516416153): memmrk:    21345368    28775552
xdk:client (1446516420317): memmrk:    42309228    55318784
xdk:server (1446516421154): memmrk:    21351712    28775552
xdk:client (1446516425319): memmrk:    42439448    55318784
xdk:server (1446516426154): memmrk:    21358056    28775552
xdk:client (1446516430317): memmrk:    42442852    56322304
xdk:server (1446516431155): memmrk:    21364400    28775552
xdk:client (1446516435319): memmrk:    42845524    56322304
xdk:server (1446516436156): memmrk:    21370744    28775552
xdk:client (1446516440321): memmrk:    42992560    56322304
xdk:server (1446516441156): memmrk:    21377088    28775552
xdk:client (1446516445322): memmrk:    43092056    56322304
xdk:server (1446516446157): memmrk:    21383432    28775552
xdk:client (1446516450324): memmrk:    44736664    56322304
xdk:server (1446516451157): memmrk:    21389776    28775552
xdk:client (1446516455326): memmrk:    44839516    56322304
xdk:server (1446516456158): memmrk:    21396120    28775552
xdk:client (1446516460326): memmrk:    45021104    56322304
xdk:server (1446516461158): memmrk:    21468944    28775552
xdk:client (1446516465326): memmrk:    45121396    56322304
xdk:server (1446516466159): memmrk:    21476640    28775552
xdk:client (1446516470328): memmrk:    41651592    56322304
xdk:server (1446516471159): memmrk:    21482984    28775552
xdk:client (1446516475334): memmrk:    41925528    57325824
xdk:server (1446516476159): memmrk:    21491664    28775552
xdk:client (1446516480331): memmrk:    42105580    57325824
xdk:server (1446516481159): memmrk:    21499072    28775552
xdk:client (1446516485331): memmrk:    41295744    54192256
xdk:server (1446516486160): memmrk:    21506632    28775552
xdk:client (1446516490332): memmrk:    41484264    54192256
xdk:server (1446516491160): memmrk:    21514656    28775552
xdk:client (1446516495332): memmrk:    41229492    54192256
xdk:server (1446516496161): memmrk:    21528788    28775552
xdk:client (1446516500333): memmrk:    41418448    54192256
xdk:server (1446516501161): memmrk:    21535932    28775552
xdk:client (1446516505334): memmrk:    41520456    54192256
xdk:server (1446516506161): memmrk:    21542252    28775552
xdk:client (1446516510335): memmrk:    40752716    54192256
xdk:server (1446516511161): memmrk:    21550856    28775552
xdk:server (1446516516161): memmrk:    21572912    28775552
xdk:client (1446516516317): memmrk:    39037312    53221632
xdk:server (1446516521162): memmrk:    21579072    28775552
xdk:client (1446516521317): memmrk:    39271852    53221632
xdk:server (1446516526163): memmrk:    21585232    28775552
xdk:client (1446516526318): memmrk:    39373800    53221632
xdk:server (1446516531164): memmrk:    21591392    28775552
xdk:client (1446516531316): memmrk:    39523788    53221632
xdk:server (1446516536164): memmrk:    21609444    28775552
xdk:client (1446516536316): memmrk:    39625172    53221632
xdk:server (1446516541165): memmrk:    21621776    28775552
xdk:client (1446516541317): memmrk:    39772712    53221632
xdk:server (1446516546165): memmrk:    21627936    28775552
xdk:client (1446516546316): memmrk:    39873028    53221632
xdk:server (1446516551165): memmrk:    21634096    28775552
xdk:client (1446516551315): memmrk:    40042540    53221632
xdk:server (1446516556165): memmrk:    21640256    28775552
xdk:client (1446516556316): memmrk:    40144960    53221632
xdk:server (1446516561165): memmrk:    21646416    28775552
xdk:client (1446516561316): memmrk:    39570336    53221632
xdk:server (1446516566165): memmrk:    21654048    28775552
xdk:client (1446516566317): memmrk:    40511924    54225152
xdk:server (1446516571166): memmrk:    21663488    28775552
xdk:client (1446516571318): memmrk:    40673256    54225152
xdk:server (1446516576166): memmrk:    21669648    28775552
xdk:client (1446516576319): memmrk:    44335556    57337984
xdk:server (1446516581167): memmrk:    21675808    28775552
xdk:client (1446516581319): memmrk:    45500160    59357184
xdk:server (1446516586167): memmrk:    21684468    28775552
xdk:client (1446516586320): memmrk:    45623280    59357184
xdk:server (1446516591167): memmrk:    22246356    28775552
xdk:client (1446516591323): memmrk:    46832568    63551488
xdk:server (1446516596191): memmrk:    34418720    52584576
xdk:client (1446516596323): memmrk:    44765176    64555008
xdk:server (1446516601191): memmrk:    41364036    59682176
xdk:client (1446516601324): memmrk:    44959228    64555008
xdk:server (1446516606216): memmrk:    26527376    60697856
xdk:client (1446516606325): memmrk:    45061120    64555008
xdk:server (1446516611224): memmrk:    29555360    60697856
xdk:client (1446516611327): memmrk:    45209044    64555008
xdk:server (1446516616229): memmrk:    33362380    60697856
xdk:client (1446516616327): memmrk:    45314532    64555008
xdk:server (1446516621230): memmrk:    32761292    60697856
xdk:client (1446516621334): memmrk:    46958104    64555008
xdk:server (1446516626231): memmrk:    33344604    60697856
xdk:client (1446516626339): memmrk:    47057808    64555008
xdk:server (1446516631231): memmrk:    26424332    60697856
xdk:client (1446516631344): memmrk:    47205672    64555008
xdk:server (1446516636231): memmrk:    24235676    60697856
xdk:client (1446516636356): memmrk:    47306404    64555008
xdk:server (1446516641231): memmrk:    23945072    31777536
xdk:client (1446516641375): memmrk:    47455516    64555008
xdk:server (1446516646231): memmrk:    23952772    31777536
xdk:client (1446516646381): memmrk:    47561952    64555008
xdk:server (1446516651231): memmrk:    23850696    30774016
xdk:client (1446516651389): memmrk:    47709816    64555008
xdk:server (1446516656232): memmrk:    23858700    30774016
xdk:client (1446516656393): memmrk:    47810880    64555008
xdk:server (1446516661232): memmrk:    23400812    30774016
xdk:client (1446516661407): memmrk:    47974100    64555008
xdk:server (1446516666232): memmrk:    23410608    30774016
xdk:client (1446516666422): memmrk:    48086584    64555008
xdk:server (1446516671233): memmrk:    23398904    30774016
xdk:client (1446516671424): memmrk:    48233848    64555008
xdk:server (1446516676234): memmrk:    23488692    31822592
xdk:client (1446516676430): memmrk:    48334168    64555008
xdk:server (1446516681234): memmrk:    23021148    31822592
xdk:client (1446516681448): memmrk:    48482284    64555008
xdk:server (1446516686234): memmrk:    23027344    31822592
xdk:client (1446516686463): memmrk:    48581044    64555008
xdk:server (1446516691234): memmrk:    23033520    31822592
xdk:client (1446516691480): memmrk:    48730704    64555008
xdk:server (1446516696235): memmrk:    23039696    31822592
xdk:client (1446516696495): memmrk:    48829464    64555008
xdk:server (1446516701235): memmrk:    23045872    31822592
xdk:client (1446516701504): memmrk:    48976728    64555008
xdk:server (1446516706235): memmrk:    23052048    31822592
xdk:client (1446516706509): memmrk:    49076700    64555008
xdk:server (1446516711236): memmrk:    23058224    31822592
xdk:client (1446516711511): memmrk:    49226568    64555008
xdk:server (1446516716236): memmrk:    23064400    31822592
xdk:client (1446516716521): memmrk:    49325328    64555008
xdk:server (1446516721236): memmrk:    23070576    31822592
xdk:client (1446516721527): memmrk:    49473204    64555008
xdk:server (1446516726237): memmrk:    23076752    31822592
xdk:client (1446516726530): memmrk:    49576944    64555008
xdk:server (1446516731237): memmrk:    23082928    31822592
xdk:client (1446516731542): memmrk:    49727688    64555008
xdk:server (1446516736237): memmrk:    23089104    31822592
xdk:client (1446516736558): memmrk:    47492420    64555008
xdk:server (1446516741238): memmrk:    23095280    31822592
xdk:client (1446516741566): memmrk:    47639668    64555008
xdk:server (1446516746239): memmrk:    23101456    31822592
xdk:client (1446516746581): memmrk:    47738412    64555008
xdk:server (1446516751239): memmrk:    23107632    31822592
xdk:client (1446516751591): memmrk:    47885688    64555008
xdk:server (1446516756238): memmrk:    23113808    31822592
xdk:client (1446516756603): memmrk:    47986184    64555008
xdk:server (1446516761238): memmrk:    23119984    31822592
xdk:client (1446516761615): memmrk:    48133432    64555008
xdk:server (1446516766238): memmrk:    23126160    31822592
xdk:client (1446516766624): memmrk:    48232176    64555008
xdk:server (1446516771239): memmrk:    23135868    31822592
xdk:client (1446516771630): memmrk:    48380124    64555008
xdk:server (1446516776240): memmrk:    23142044    31822592
xdk:client (1446516776643): memmrk:    48583976    64555008
xdk:server (1446516781241): memmrk:    23148220    31822592
xdk:client (1446516781650): memmrk:    48731888    64555008
xdk:server (1446516786242): memmrk:    23154396    31822592
xdk:client (1446516786663): memmrk:    48834468    64555008
xdk:server (1446516791242): memmrk:    23161796    31822592
xdk:client (1446516791688): memmrk:    48981716    64555008
xdk:server (1446516796242): memmrk:    23169648    31822592
xdk:client (1446516796689): memmrk:    49080500    64555008
xdk:server (1446516801243): memmrk:    23175824    31822592
xdk:client (1446516801702): memmrk:    49227748    64555008
xdk:server (1446516806243): memmrk:    23182000    31822592
xdk:client (1446516806713): memmrk:    49326492    64555008
xdk:server (1446516811244): memmrk:    23188176    31822592
xdk:client (1446516811725): memmrk:    49473740    64555008
xdk:server (1446516816244): memmrk:    23194352    31822592
xdk:client (1446516816727): memmrk:    49572484    64555008
xdk:server (1446516821245): memmrk:    23200528    31822592
xdk:client (1446516821736): memmrk:    49719732    64555008
xdk:server (1446516826245): memmrk:    23206704    31822592
xdk:client (1446516826748): memmrk:    49822464    64555008
xdk:server (1446516831245): memmrk:    23212880    31822592
xdk:client (1446516831762): memmrk:    49972776    64555008
xdk:server (1446516836245): memmrk:    23219056    31822592
xdk:client (1446516836768): memmrk:    50071520    64555008
xdk:server (1446516841245): memmrk:    23225232    31822592
xdk:client (1446516841785): memmrk:    50247684    64555008
xdk:server (1446516846246): memmrk:    23231408    31822592
xdk:client (1446516846796): memmrk:    50343500    64555008
xdk:server (1446516851246): memmrk:    23237584    31822592
xdk:client (1446516851806): memmrk:    50486356    64555008
xdk:server (1446516856246): memmrk:    23243760    31822592
xdk:client (1446516856823): memmrk:    50582172    64555008
xdk:server (1446516861246): memmrk:    23249948    31822592
xdk:client (1446516861829): memmrk:    50725028    64555008
xdk:server (1446516866246): memmrk:    23256184    31822592
xdk:client (1446516866837): memmrk:    50831680    64555008
xdk:server (1446516871246): memmrk:    23262420    31822592
xdk:client (1446516871852): memmrk:    50974536    64555008
xdk:server (1446516876247): memmrk:    23268656    31822592
xdk:client (1446516876864): memmrk:    51070352    64555008
xdk:server (1446516881248): memmrk:    23274916    31822592
xdk:client (1446516881882): memmrk:    51213208    64555008
xdk:server (1446516886249): memmrk:    23281152    31822592
xdk:client (1446516886899): memmrk:    51309024    64555008
xdk:server (1446516891249): memmrk:    23287388    31822592
xdk:client (1446516891906): memmrk:    49059048    64555008
xdk:server (1446516896249): memmrk:    23293624    31822592
xdk:client (1446516896914): memmrk:    49155072    64555008
xdk:server (1446516901249): memmrk:    23299860    31822592
xdk:client (1446516901920): memmrk:    49299340    64555008
xdk:server (1446516906249): memmrk:    23306096    31822592
xdk:client (1446516906936): memmrk:    49395156    64555008
xdk:server (1446516911249): memmrk:    23312332    31822592
xdk:client (1446516911941): memmrk:    49545236    64555008
xdk:server (1446516916250): memmrk:    23318568    31822592
xdk:client (1446516916960): memmrk:    49641052    64555008
xdk:server (1446516921251): memmrk:    23324804    31822592
xdk:client (1446516921966): memmrk:    49783908    64555008
xdk:server (1446516926251): memmrk:    23404996    31822592
xdk:client (1446516926972): memmrk:    49880448    64555008
xdk:server (1446516931251): memmrk:    23412584    31822592
xdk:client (1446516931978): memmrk:    50029252    64555008
xdk:server (1446516936251): memmrk:    23418820    31822592
xdk:client (1446516936990): memmrk:    50126888    64555008
xdk:server (1446516941251): memmrk:    23425056    31822592
xdk:client (1446516941998): memmrk:    50271088    64555008
xdk:server (1446516946252): memmrk:    23431292    31822592
xdk:client (1446516947009): memmrk:    50374308    64555008
xdk:server (1446516951253): memmrk:    23441496    31822592
xdk:client (1446516952020): memmrk:    50517752    64555008
xdk:server (1446516956254): memmrk:    23447732    31822592
xdk:client (1446516957033): memmrk:    50613960    64555008
xdk:server (1446516961254): memmrk:    23453968    31822592
xdk:client (1446516962041): memmrk:    50757404    64555008
xdk:server (1446516966254): memmrk:    23460204    31822592
xdk:client (1446516967058): memmrk:    50853612    64555008
xdk:server (1446516971255): memmrk:    23466440    31822592
xdk:client (1446516972065): memmrk:    50971948    64555008
xdk:server (1446516976256): memmrk:    23472676    31822592
xdk:client (1446516977066): memmrk:    51104480    64555008
xdk:server (1446516981256): memmrk:    23483664    31822592
xdk:client (1446516982072): memmrk:    51221584    64555008
xdk:server (1446516986257): memmrk:    23489900    31822592
xdk:client (1446516987069): memmrk:    51344636    64555008
xdk:server (1446516991258): memmrk:    23496136    31822592
xdk:client (1446516992070): memmrk:    51441144    64555008
xdk:server (1446516996258): memmrk:    23502372    31822592
xdk:client (1446516997087): memmrk:    51588888    64555008
xdk:server (1446517001259): memmrk:    23508608    31822592
xdk:client (1446517002103): memmrk:    51685096    64555008
xdk:server (1446517006259): memmrk:    23514844    31822592
xdk:client (1446517007117): memmrk:    51829752    64555008
xdk:server (1446517011259): memmrk:    23521080    31822592
xdk:client (1446517012133): memmrk:    51932052    64555008
xdk:server (1446517016260): memmrk:    23527316    31822592
xdk:client (1446517017145): memmrk:    52075624    64555008
xdk:server (1446517021260): memmrk:    23533552    31822592
xdk:client (1446517022154): memmrk:    52179792    64555008
xdk:server (1446517026261): memmrk:    23539788    31822592
xdk:client (1446517027169): memmrk:    52329444    64555008
xdk:server (1446517031261): memmrk:    23546024    31822592
xdk:client (1446517032171): memmrk:    52425652    64555008
xdk:server (1446517036261): memmrk:    23552260    31822592
xdk:client (1446517037175): memmrk:    52569096    64555008
xdk:server (1446517041262): memmrk:    23558496    31822592
xdk:client (1446517042176): memmrk:    50396280    72943616
xdk:server (1446517046262): memmrk:    23564732    31822592
xdk:client (1446517047176): memmrk:    50539748    72943616
xdk:server (1446517051263): memmrk:    23570968    31822592
xdk:client (1446517052192): memmrk:    50635956    72943616
xdk:server (1446517056263): memmrk:    23579296    31822592
xdk:client (1446517057207): memmrk:    50779400    72943616
xdk:server (1446517061263): memmrk:    23585532    31822592
xdk:client (1446517062217): memmrk:    50875940    72943616
xdk:server (1446517066263): memmrk:    23593240    31822592
xdk:client (1446517067225): memmrk:    51019384    72943616
xdk:server (1446517071263): memmrk:    23599476    31822592
xdk:client (1446517072242): memmrk:    51122744    72943616
xdk:server (1446517076263): memmrk:    23605712    31822592
xdk:client (1446517077258): memmrk:    51308836    72943616
xdk:server (1446517081263): memmrk:    23611948    31822592
xdk:client (1446517082273): memmrk:    51405044    72943616
xdk:server (1446517086263): memmrk:    23618184    31822592
xdk:client (1446517087280): memmrk:    51548488    72943616
xdk:server (1446517091264): memmrk:    23624420    31822592
xdk:client (1446517092299): memmrk:    51644696    72943616
xdk:server (1446517096265): memmrk:    23630656    31822592
xdk:client (1446517097313): memmrk:    51791636    72943616
xdk:server (1446517101266): memmrk:    23636892    31822592
xdk:client (1446517102319): memmrk:    51887844    72943616
xdk:server (1446517106267): memmrk:    23643128    31822592
xdk:client (1446517107338): memmrk:    52031288    72943616
xdk:server (1446517111267): memmrk:    23649364    31822592
xdk:client (1446517112353): memmrk:    52127496    72943616
xdk:server (1446517116268): memmrk:    23655600    31822592
xdk:client (1446517117353): memmrk:    52270940    72943616
xdk:server (1446517121269): memmrk:    23661836    31822592
xdk:client (1446517122366): memmrk:    52367148    72943616
xdk:server (1446517126270): memmrk:    23668072    31822592
xdk:client (1446517127368): memmrk:    52510592    72943616
xdk:server (1446517131270): memmrk:    23674308    31822592
xdk:client (1446517132372): memmrk:    52606800    72943616
xdk:server (1446517136271): memmrk:    23680544    31822592
xdk:client (1446517137384): memmrk:    52750244    72943616
xdk:server (1446517141272): memmrk:    23686780    31822592
xdk:client (1446517142387): memmrk:    52846472    72943616
xdk:server (1446517146272): memmrk:    23693016    31822592
xdk:client (1446517147397): memmrk:    52989916    72943616
xdk:server (1446517151272): memmrk:    23699252    31822592
xdk:client (1446517152412): memmrk:    53086124    72943616
xdk:server (1446517156273): memmrk:    23705488    31822592
xdk:client (1446517157416): memmrk:    53229568    72943616
xdk:server (1446517161273): memmrk:    23711724    31822592
xdk:client (1446517162419): memmrk:    53325776    72943616
xdk:server (1446517166274): memmrk:    23717960    31822592
xdk:client (1446517167438): memmrk:    53469220    72943616
xdk:server (1446517171274): memmrk:    23724196    31822592
xdk:client (1446517172442): memmrk:    53568692    72943616
xdk:server (1446517176275): memmrk:    23730432    31822592
xdk:client (1446517177443): memmrk:    53712136    72943616
xdk:server (1446517181275): memmrk:    23736668    31822592
xdk:client (1446517182456): memmrk:    53808344    72943616
xdk:server (1446517186275): memmrk:    23742904    31822592
xdk:client (1446517187458): memmrk:    53951788    72943616
xdk:server (1446517191276): memmrk:    23749140    31822592
xdk:client (1446517192463): memmrk:    54048020    72943616
xdk:server (1446517196276): memmrk:    23755376    31822592
xdk:client (1446517197470): memmrk:    54226692    72943616
xdk:server (1446517201276): memmrk:    23761612    31822592
xdk:client (1446517202486): memmrk:    54330032    72943616
xdk:server (1446517206276): memmrk:    23767848    31822592
xdk:client (1446517207487): memmrk:    54473208    72943616
xdk:server (1446517211276): memmrk:    23774084    31822592
xdk:client (1446517212489): memmrk:    54568992    72943616
xdk:server (1446517216276): memmrk:    23780320    31822592
xdk:client (1446517217508): memmrk:    54711800    72943616
xdk:server (1446517221276): memmrk:    23786556    31822592
xdk:client (1446517222514): memmrk:    54807664    72943616
xdk:server (1446517226276): memmrk:    23792792    31822592
xdk:client (1446517227517): memmrk:    54950472    72943616
xdk:server (1446517231277): memmrk:    23799028    31822592
xdk:client (1446517232519): memmrk:    55046256    72943616
xdk:server (1446517236277): memmrk:    23805264    31822592
xdk:client (1446517237520): memmrk:    55189064    72943616
xdk:server (1446517241277): memmrk:    23811500    31822592
xdk:client (1446517242532): memmrk:    55284872    72943616
xdk:server (1446517246278): memmrk:    23829868    31822592
xdk:client (1446517247547): memmrk:    55430380    72943616
xdk:server (1446517251278): memmrk:    23836104    31822592
xdk:client (1446517252560): memmrk:    55526244    72943616
xdk:server (1446517256279): memmrk:    23842340    31822592
xdk:client (1446517257565): memmrk:    55669052    72943616
xdk:server (1446517261279): memmrk:    23848576    31822592
xdk:client (1446517262571): memmrk:    55771820    72943616
xdk:server (1446517266279): memmrk:    23855928    31822592
xdk:client (1446517267589): memmrk:    55915312    72943616
xdk:server (1446517271279): memmrk:    23862164    31822592
xdk:client (1446517272590): memmrk:    56011096    72943616
xdk:server (1446517276279): memmrk:    23868400    31822592
xdk:client (1446517277600): memmrk:    56153904    73959296
xdk:server (1446517281280): memmrk:    23874636    31822592
xdk:client (1446517282614): memmrk:    56249708    73959296
xdk:server (1446517286281): memmrk:    23880872    31822592
xdk:client (1446517287629): memmrk:    56392532    73959296
xdk:server (1446517291281): memmrk:    23887108    31822592
xdk:client (1446517292637): memmrk:    56488316    73959296
xdk:server (1446517296281): memmrk:    23903192    31822592
xdk:client (1446517297643): memmrk:    56606032    73959296
xdk:server (1446517301282): memmrk:    23909428    31822592
xdk:client (1446517302654): memmrk:    56730860    73959296
xdk:server (1446517306283): memmrk:    23927552    31822592
xdk:client (1446517307660): memmrk:    56846840    73959296
xdk:server (1446517311283): memmrk:    23933788    31822592
xdk:client (1446517312668): memmrk:    56969452    73959296
xdk:server (1446517316283): memmrk:    23940024    31822592
xdk:client (1446517317683): memmrk:    57065236    73959296
xdk:server (1446517321283): memmrk:    23946260    31822592
xdk:client (1446517322697): memmrk:    57208044    73959296
xdk:server (1446517326283): memmrk:    23952496    31822592
xdk:client (1446517327705): memmrk:    57305696    73959296
xdk:server (1446517331284): memmrk:    23958732    31822592
xdk:client (1446517332716): memmrk:    57448504    73959296
xdk:server (1446517336284): memmrk:    23965944    31822592
xdk:client (1446517337731): memmrk:    57546336    73959296
xdk:server (1446517341284): memmrk:    23972180    31822592
xdk:client (1446517342749): memmrk:    57689576    73959296
xdk:server (1446517346284): memmrk:    23978416    31822592
xdk:client (1446517347762): memmrk:    57786912    73959296
xdk:server (1446517351284): memmrk:    23984652    31822592
xdk:client (1446517352765): memmrk:    57929720    73959296
xdk:server (1446517356285): memmrk:    23990888    31822592
xdk:client (1446517357768): memmrk:    58025504    73959296
xdk:server (1446517361285): memmrk:    23997124    31822592
xdk:client (1446517362774): memmrk:    58169616    73959296
xdk:server (1446517366286): memmrk:    24003360    31822592
xdk:client (1446517367778): memmrk:    58267056    73959296
xdk:server (1446517371287): memmrk:    24009596    31822592
xdk:client (1446517372786): memmrk:    58410152    73959296
xdk:server (1446517376287): memmrk:    24015832    31822592
xdk:client (1446517377802): memmrk:    58556396    73959296
xdk:server (1446517381288): memmrk:    24022068    31822592
xdk:client (1446517382805): memmrk:    58699204    73959296
xdk:server (1446517386288): memmrk:    24028304    31822592
xdk:client (1446517387808): memmrk:    53592392    74974976
xdk:server (1446517391289): memmrk:    24034540    31822592
xdk:client (1446517392810): memmrk:    53735220    74974976
xdk:server (1446517396289): memmrk:    24040776    31822592
xdk:client (1446517397817): memmrk:    53831004    74974976
xdk:server (1446517401290): memmrk:    24047012    31822592
xdk:client (1446517402821): memmrk:    53973812    74974976
xdk:server (1446517406290): memmrk:    24053248    31822592
xdk:client (1446517407828): memmrk:    54069596    74974976
xdk:server (1446517411290): memmrk:    24059484    31822592
xdk:client (1446517412830): memmrk:    54212404    74974976
xdk:server (1446517416291): memmrk:    24065720    31822592
xdk:client (1446517417846): memmrk:    54308188    74974976
xdk:server (1446517421291): memmrk:    24071956    31822592
xdk:client (1446517422850): memmrk:    54450996    74974976
xdk:server (1446517426292): memmrk:    24078192    31822592
xdk:client (1446517427856): memmrk:    54546780    74974976
xdk:server (1446517431293): memmrk:    24084428    31822592
xdk:client (1446517432859): memmrk:    54689588    74974976
xdk:server (1446517436294): memmrk:    24090664    31822592
xdk:client (1446517437860): memmrk:    54786404    74974976
xdk:server (1446517441294): memmrk:    24096900    31822592
xdk:client (1446517441459): Uncaught top-level browser exception at file:///C:/Users/Kidda/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:126:27: Uncaught TypeError: Failed to set the 'value' property on 'HTMLProgressElement': The provided double value is non-finite.
Stack trace from browser: TypeError: Failed to set the 'value' property on 'HTMLProgressElement': The provided double value is non-finite.
    at TypeError (native)
    at HTMLProgressElement.<anonymous> (file:///C:/Users/Kidda/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:4277:16)
    at Function.jQuery.extend.each (file:///C:/Users/Kidda/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:2668:23)
    at jQuery.fn.jQuery.each (file:///C:/Users/Kidda/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:2290:17)
    at jQuery.fn.extend.val (file:///C:/Users/Kidda/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:4248:15)
    at file:///C:/Users/Kidda/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:16840
    at _progressed (file:///C:/Users/Kidda/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:816:51)
    at file:///C:/Users/Kidda/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:842:24
    at file:///C:/Users/Kidda/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:611:17
    at flush (file:///C:/Users/Kidda/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:108:17)
[Log closed from xdk:client]
xdk:server (1446517446308): memmrk:    24103136    31822592
xdk:server (1446517451313): memmrk:    24109372    31822592
PaulF_IntelCorp
Good evening , I'm trying to make a crosswalk android and when I'm uploading project takes 10 to 20 minutes not complete and a message saying it was unable to complete the process and restart the program.
Are you still experiencing this issue? Do you get different results if you go try from a different network? (e.g., home, work, friend's house) How many plugins are in your application?
In the future, please attach logs to the post, to not paste them into your post. It makes it more difficult to help you.
