Software Archive
Read-only legacy content
17060 Discussions
Depth stream To 3D position
Jian_l_2
I wanto use the every Pixel of Depth stream to get 3D position which include Dist x,y,z and Degrees X,Y,Z. Dose the SDK include this algorithm?
Pubudu-Silva_Intel
Yes, you can access depth data of all pixels. Please refer to the background segmentation tutorial, and specially the sample code at
https://software.intel.com/sites/default/files/managed/66/9c/Background_Segmentation.pdf
Jonathan_M_Intel
Hi, I apologize, I think the link Pudubu shared is not helpful.  To transform the depth image values to 3D coordinates, check the documentation for the PXCProjection interface:
https://software.intel.com/sites/landingpage/realsense/camera-sdk/2014gold/documentation/html/index.html?pxcprojection.html
Try this (pseudocode):
PXCProjection * projection = sensemanager->QueryCaptureManager()->QueryDevice()->CreateProjection();
PXCPoint3DF32 depthCoords[width * height * 3];
while(loop) {
sensemanager->AcquireFrame();
PXCCapture::Sample * sample = sensemanger->QuerySample();
PXCImage * depthMap = sample->depth;
projection->QueryVertices(depthMap,(PXCPoint3DF32 *) depthCoords);
//Do something with your coordinates//
sensemanager->ReleaseFrame();
Your 3D points will be in the depthCoords array, packed as [x,y,z] in millimeters, with one set of 3 floats for each of the original depth map pixels, in "raster order", and using the coordinate system described here:
https://software.intel.com/sites/landingpage/realsense/camera-sdk/2014gold/documentation/html/index.html?manuals_coordinate_systems.html
Note:  many of the resulting coordinates will be zeros, but that only means that those pixels were either saturated or too far for detection.  There will be usable depth points deeper into the array.
Hope this helps.
