In my application, I load a lot of information into a large array, when the array is full I write further information to file.
With different PC's I sould be able to make the array bigger and so my application should run faster.
I therefore need to determine the amount of system memory so I can decide how big I can make my array.
Is there a call that will give me this?
David
David
Here's how I find available physical memory with CVF 6.6:
use dfwin
use dflogm
use dfcom
(not sure which one of these is required)
type(T_MEMORYSTATUS) lpMstMemStat
call GlobalMemoryStatus ( lpMstMemStat )
ipmem_start = lpMstMemStat.dwAvailPhys
The last integer variable (ipmem_start) will have the amount of memory in bytes.
Harry Bell
use dfwin
use dflogm
use dfcom
Harry Bell
Note that physical memory is not the same as virtual memory. The dwTotalVirtual and dwAvailVirtiual fields are more interesting here.
Steve
Steve
