I have been having issues with dialog dismissed functions running before the dialog response.
Here is a simple example
<div class="upage view" id="mainpage" data-footer="none" data-header="none"> <div class="upage-outer"> <div class="upage-content ac0" id="page_48_3"> <div class="grid grid-pad urow uib_row_1 row-height-1" data-uib="layout/row" data-ver="0"> <div class="col uib_col_1 col-0_12-12" data-uib="layout/col" data-ver="0"> <div class="widget-container content-area vertical-col"> <a class="button widget uib_w_9 d-margins" data-uib="app_framework/button" data-ver="2" onclick="javascript:popme()">Get Dialog</a><span class="uib_shim"></span> </div> </div> <span class="uib_shim"></span> </div> </div> </div> <div name="dismissedtext" id="dismissedtext"></div> </div>
Here is the Javascript
function popme(){ navigator.notification.alert("Dialog dismissed test", dialogdismissed,"Dialog"); } function dialogdismissed(){ $("#dismissedtext").text("This shoud appear after dismissing the dialog."); }
The dismissed text appears at the same time as the dialog box rather than after the dialog response, navigator.notification.confirm seems to work as expected.
- Tags:
- HTML5
- Intel® XDK
