Software Archive
Read-only legacy content
Difference Performance Datatype dependency
eric_p_
Hi all and thanks to help,
I write in Fortran a stupid program that implements a dot product between two arrays , one in double precision and the other changing the datatype.
PROGRAM datatype
USE omp_lib
implicit none
double precision, allocatable,dimension(:,:,:) :: A,B,C
integer(kind=1), allocatable,dimension(:,:,:) :: D
integer(kind=4), allocatable,dimension(:,:,:) :: E
integer(kind=8), allocatable,dimension(:,:,:) :: F
real, allocatable,dimension(:,:,:) :: G
LOGICAL, allocatable,dimension(:,:,:) :: H
integer :: t,i,j,k,size = 500,repetition=40
double precision :: time,time1
ALLOCATE(A(size,size,size),B(size,size,size),C(size,size,size))
A = 4.
B = 1.
time = omp_get_wtime()
do t = 1,repetition
	do i=1,size
		do j=1,size
			do k=1,size
			!dir$ vector aligned
			c(k,j,i) = a(k,j,i) * b(k,j,i) +5.2
			enddo
		enddo
	enddo
enddo
time = omp_get_wtime() - time
print *,"TIME double",time/DBLE(repetition)
DEALLOCATE(B)
ALLOCATE(G(size,size,size))
G = 240.
do t = 1,repetition
	do i=1,size
		do j=1,size
			do k=1,size
			c(k,j,i) = a(k,j,i) * g(k,j,i) +5.2
			enddo
		enddo
	enddo
enddo
print *,"TIME float",time/DBLE(repetition)
DEALLOCATE(G)
ALLOCATE(D(size,size,size))
D = 240
do t = 1,repetition
	do i=1,size
		do j=1,size
			do k=1,size
			c(k,j,i) = a(k,j,i) * d(k,j,i) +5.2
			enddo
		enddo
	enddo
enddo
print *,"TIME int8",time/DBLE(repetition)
DEALLOCATE(D)
ALLOCATE(E(size,size,size))
e = 240
do t = 1,repetition
	do i=1,size
		do j=1,size
			do k=1,size
			c(k,j,i) = a(k,j,i) * e(k,j,i) +5.2
			enddo
		enddo
	enddo
enddo
print *,"TIME int32",time/DBLE(repetition)
DEALLOCATE(E)
ALLOCATE(F(size,size,size))
f = 240
do t = 1,repetition
	do i=1,size
		do j=1,size
			do k=1,size
			c(k,j,i) = a(k,j,i) * f(k,j,i) +5.2
			enddo
		enddo
	enddo
enddo
print *,"TIME int64",time/DBLE(repetition)
DEALLOCATE(F)
ALLOCATE(H(size,size,size))
h = .True.
do t = 1,repetition
	do i=1,size
		do j=1,size
			do k=1,size
			c(k,j,i) = a(k,j,i) * h(k,j,i) +5.2
			enddo
		enddo
	enddo
enddo
print *,"TIME logical",time/DBLE(repetition)
END PROGRAM
I try this code on Broadwell Intel(R) Xeon(R) E5-2697 v4 @ 2.30GHz and Intel Xeon Phi 7250 KNL.
BROADWELL (1 core)
 TIME double  0.314651775360107
 TIME float  0.256021851301193
 TIME int8  0.218752950429916
 TIME int32  0.245272749662399
 TIME int64  0.319928669929504
 TIME logical  0.245576351881027
KNL (1 core)
 TIME double  0.545190346240997
 TIME float  0.608061379194260
 TIME int8  0.749213725328445
 TIME int32  0.718595725297928
 TIME int64  0.730906349420547
 TIME logical  0.544638276100159
On the broadwell architecture the best performance was obtained with  double * int 8 and the worst was double * double . I think the better performance on int8 is due to better use of cache that mask the time of cast from int8 to double, is it right?
I don't understand because on KNL the behavour is opposite. I analyzed compiler opt report but in both case the double precision decide the vector lengh so the operation per clock cycle.
Someone can help me to understand this behaviour?
Best regards
Eric
TimP
Those vector aligned directives presumably have no effect when placed after the DO.  Did you include -align array64byte -xHost in your compiler option line, and check with -opt-report=4 ?
The logical promotion to double precision isn't valid Fortran and should be rejected by ifort if you set appropriate options, such as -standard-semantics.
I don't see how integer(8) could imply different cache behavior from real(8) unless you have alignment issues.
I think your characterization of this as a dot product is misleading.
eric_p_
Hi Tim,
 ifort  -align array64byte -xAVX2 -qopt-report4 -qopenmp -O1 ./datatype_3d.f90 -o ./dt.x
TIME double  0.333785974979401
TIME float  0.284216976165771
TIME int1  0.262497049570084
TIME int32  0.265798276662827
TIME int64  0.316275727748871
TIME logical  0.246519052982330
and with -O2
ifort  -align array64byte -xAVX2 -qopt-report4 -qopenmp -O2 ./datatype_3d.f90 -o ./dt.x
 TIME double  0.297000402212143
 TIME float  0.246595245599747
 TIME int1  0.217311549186707
 TIME int32  0.247010648250580
 TIME int64  0.294282549619675
 TIME logical  0.253364574909210
for -O2 the opt report :
Intel(R) Advisor can now assist with vectorization and show optimization
  report messages with your source code.
See "https://software.intel.com/en-us/intel-advisor-xe" for details.
Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.1.132 Build 20161005
Compiler options: -align array64byte -xAVX2 -qopt-report4 -qopenmp -O2 -o ./dt.x
    Report from: Interprocedural optimizations [ipo]
  WHOLE PROGRAM (SAFE) [EITHER METHOD]: false
  WHOLE PROGRAM (SEEN) [TABLE METHOD]: false
  WHOLE PROGRAM (READ) [OBJECT READER METHOD]: false
INLINING OPTION VALUES:
  -inline-factor: 100
  -inline-min-size: 30
  -inline-max-size: 230
  -inline-max-total-size: 2000
  -inline-max-per-routine: 10000
  -inline-max-per-compile: 500000
In the inlining report below:
   "sz" refers to the "size" of the routine. The smaller a routine's size,
      the more likely it is to be inlined.
   "isz" refers to the "inlined size" of the routine. This is the amount
      the calling routine will grow if the called routine is inlined into it.
      The compiler generally limits the amount a routine can grow by having
      routines inlined into it.
Begin optimization report for: DATATYPE
INLINE REPORT: (DATATYPE) [1/1=100.0%] ./datatype_3d.f90(1,9)
  -> EXTERN: (1,9) for_set_reentrancy
  -> EXTERN: (17,1) for_alloc_allocatable
  -> EXTERN: (17,1) for_check_mult_overflow64
  -> EXTERN: (23,8) omp_get_wtime
  -> EXTERN: (34,8) omp_get_wtime
  -> EXTERN: (36,1) for_write_seq_lis_xmit
  -> EXTERN: (38,1) for_dealloc_allocatable
  -> EXTERN: (40,1) for_alloc_allocatable
  -> EXTERN: (40,1) for_check_mult_overflow64
  -> EXTERN: (43,8) omp_get_wtime
  -> EXTERN: (54,8) omp_get_wtime
  -> EXTERN: (56,1) for_write_seq_lis_xmit
  -> EXTERN: (59,1) for_dealloc_allocatable
  -> EXTERN: (64,1) for_alloc_allocatable
  -> EXTERN: (64,1) for_check_mult_overflow64
  -> EXTERN: (67,8) omp_get_wtime
  -> EXTERN: (78,8) omp_get_wtime
  -> EXTERN: (80,1) for_write_seq_lis_xmit
  -> EXTERN: (83,1) for_dealloc_allocatable
  -> EXTERN: (85,1) for_alloc_allocatable
  -> EXTERN: (85,1) for_check_mult_overflow64
  -> EXTERN: (88,8) omp_get_wtime
  -> EXTERN: (99,8) omp_get_wtime
  -> EXTERN: (101,1) for_write_seq_lis_xmit
  -> EXTERN: (103,1) for_dealloc_allocatable
  -> EXTERN: (105,1) for_alloc_allocatable
  -> EXTERN: (105,1) for_check_mult_overflow64
  -> EXTERN: (108,8) omp_get_wtime
  -> EXTERN: (119,8) omp_get_wtime
  -> EXTERN: (121,1) for_write_seq_lis_xmit
  -> EXTERN: (123,1) for_dealloc_allocatable
  -> EXTERN: (125,1) for_alloc_allocatable
  -> EXTERN: (125,1) for_check_mult_overflow64
  -> EXTERN: (128,8) omp_get_wtime
  -> EXTERN: (139,8) omp_get_wtime
  -> EXTERN: (141,1) for_write_seq_lis_xmit
    Report from: Loop nest, Vector & Auto-parallelization optimizations [loop, vec, par]
LOOP BEGIN at ./datatype_3d.f90(19,1)
   remark #25101: Loop Interchange not done due to: Original Order seems proper
   remark #25452: Original Order found to be proper, but by a close margin
   remark #15542: loop was not vectorized: inner loop was already vectorized
      <Peeled loop for vectorization>
         remark #25015: Estimate of max trip count of loop=3
      LOOP END
         remark #15388: vectorization support: reference A(:,:,:) has aligned access
         remark #15305: vectorization support: vector length 4
         remark #15399: vectorization support: unroll factor set to 4
         remark #15309: vectorization support: normalized vectorization overhead 0.833
         remark #15300: LOOP WAS VECTORIZED
         remark #15442: entire loop may be executed in remainder
         remark #15449: unmasked aligned unit stride stores: 1
         remark #15475: --- begin vector cost summary ---
         remark #15476: scalar cost: 3
         remark #15477: vector cost: 0.750
         remark #15478: estimated potential speedup: 3.430
         remark #15488: --- end vector cost summary ---
      LOOP END
      <Remainder loop for vectorization>
         remark #15389: vectorization support: reference A(:,:,:) has unaligned access
         remark #15381: vectorization support: unaligned access used inside loop body
         remark #15309: vectorization support: normalized vectorization overhead 2.600
         remark #15301: REMAINDER LOOP WAS VECTORIZED
      LOOP END
      LOOP END
   LOOP END
LOOP END
LOOP BEGIN at ./datatype_3d.f90(20,1)
      LOOP END
         remark #15388: vectorization support: reference B(:,:,:) has aligned access
      LOOP END
         remark #15389: vectorization support: reference B(:,:,:) has unaligned access
      LOOP END
      LOOP END
   LOOP END
LOOP END
LOOP BEGIN at ./datatype_3d.f90(29,35)
   LOOP BEGIN at ./datatype_3d.f90(25,2)
      LOOP BEGIN at ./datatype_3d.f90(26,3)
         LOOP BEGIN at ./datatype_3d.f90(28,4)
            remark #15388: vectorization support: reference C(k,j,i) has aligned access   [ ./datatype_3d.f90(29,4) ]
            remark #15388: vectorization support: reference A(k,j,i) has aligned access   [ ./datatype_3d.f90(29,15) ]
            remark #15388: vectorization support: reference B(k,j,i) has aligned access   [ ./datatype_3d.f90(29,26) ]
            remark #15448: unmasked aligned unit stride loads: 2
            remark #15476: scalar cost: 8
            remark #15477: vector cost: 1.750
            remark #15478: estimated potential speedup: 4.440
            remark #25015: Estimate of max trip count of loop=31
         LOOP END
            remark #15427: loop was completely unrolled
         LOOP END
      LOOP END
   LOOP END
LOOP END
LOOP BEGIN at ./datatype_3d.f90(41,1)
         remark #25015: Estimate of max trip count of loop=7
      LOOP END
         remark #15389: vectorization support: reference G(:,:,:) has unaligned access
         remark #15305: vectorization support: vector length 8
         remark #15399: vectorization support: unroll factor set to 2
         remark #15309: vectorization support: normalized vectorization overhead 1.667
         remark #15451: unmasked unaligned unit stride stores: 1
         remark #15477: vector cost: 0.370
         remark #15478: estimated potential speedup: 5.840
      LOOP END
         remark #15335: remainder loop was not vectorized: vectorization possible but seems inefficient. Use vector always directive or -vec-threshold0 to override
         remark #15309: vectorization support: normalized vectorization overhead 2.167
      LOOP END
   LOOP END
LOOP END
LOOP BEGIN at ./datatype_3d.f90(49,15)
   LOOP BEGIN at ./datatype_3d.f90(45,2)
      LOOP BEGIN at ./datatype_3d.f90(46,3)
         LOOP BEGIN at ./datatype_3d.f90(48,4)
            remark #15388: vectorization support: reference C(k,j,i) has aligned access   [ ./datatype_3d.f90(49,4) ]
            remark #15388: vectorization support: reference A(k,j,i) has aligned access   [ ./datatype_3d.f90(49,15) ]
            remark #15388: vectorization support: reference G(k,j,i) has aligned access   [ ./datatype_3d.f90(49,26) ]
            remark #15417: vectorization support: number of FP up converts: single precision to double precision 1   [ ./datatype_3d.f90(49,4) ]
            remark #15476: scalar cost: 9
            remark #15477: vector cost: 2.000
            remark #15478: estimated potential speedup: 4.370
            remark #15487: type converts: 1
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
LOOP BEGIN at ./datatype_3d.f90(65,1)
         remark #25408: memset generated
            remark #15389: vectorization support: reference D(:,:,:) has unaligned access
            remark #15305: vectorization support: vector length 32
            remark #15309: vectorization support: normalized vectorization overhead 0.600
            remark #15476: scalar cost: 2
            remark #15477: vector cost: 0.150
            remark #15478: estimated potential speedup: 10.660
         LOOP END
            remark #25015: Estimate of max trip count of loop=96
         LOOP END
      LOOP END
   LOOP END
LOOP END
LOOP BEGIN at ./datatype_3d.f90(73,15)
   LOOP BEGIN at ./datatype_3d.f90(69,2)
      LOOP BEGIN at ./datatype_3d.f90(70,3)
         LOOP BEGIN at ./datatype_3d.f90(72,4)
            remark #15388: vectorization support: reference C(k,j,i) has aligned access   [ ./datatype_3d.f90(73,4) ]
            remark #15388: vectorization support: reference A(k,j,i) has aligned access   [ ./datatype_3d.f90(73,15) ]
            remark #15388: vectorization support: reference D(k,j,i) has aligned access   [ ./datatype_3d.f90(73,26) ]
            remark #15448: unmasked aligned unit stride loads: 1
            remark #15450: unmasked unaligned unit stride loads: 1
            remark #15476: scalar cost: 10
            remark #15478: estimated potential speedup: 4.840
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
LOOP BEGIN at ./datatype_3d.f90(86,1)
      LOOP END
         remark #15389: vectorization support: reference E(:,:,:) has unaligned access
         remark #15309: vectorization support: normalized vectorization overhead 3.333
         remark #15478: estimated potential speedup: 4.220
      LOOP END
      LOOP END
   LOOP END
LOOP END
LOOP BEGIN at ./datatype_3d.f90(94,15)
   LOOP BEGIN at ./datatype_3d.f90(90,2)
      LOOP BEGIN at ./datatype_3d.f90(91,3)
         LOOP BEGIN at ./datatype_3d.f90(93,4)
            remark #15388: vectorization support: reference C(k,j,i) has aligned access   [ ./datatype_3d.f90(94,4) ]
            remark #15388: vectorization support: reference A(k,j,i) has aligned access   [ ./datatype_3d.f90(94,15) ]
            remark #15388: vectorization support: reference E(k,j,i) has aligned access   [ ./datatype_3d.f90(94,26) ]
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
LOOP BEGIN at ./datatype_3d.f90(106,1)
      LOOP END
         remark #15389: vectorization support: reference F(:,:,:) has unaligned access
         remark #15478: estimated potential speedup: 2.500
      LOOP END
      LOOP END
   LOOP END
LOOP END
LOOP BEGIN at ./datatype_3d.f90(114,15)
   LOOP BEGIN at ./datatype_3d.f90(110,2)
      LOOP BEGIN at ./datatype_3d.f90(111,3)
         LOOP BEGIN at ./datatype_3d.f90(113,4)
            remark #15388: vectorization support: reference C(k,j,i) has aligned access   [ ./datatype_3d.f90(114,4) ]
            remark #15388: vectorization support: reference A(k,j,i) has aligned access   [ ./datatype_3d.f90(114,15) ]
            remark #15388: vectorization support: reference F(k,j,i) has aligned access   [ ./datatype_3d.f90(114,26) ]
            remark #15410: vectorization support: conversion from int to float will be emulated   [ ./datatype_3d.f90(114,26) ]
            remark #15477: vector cost: 4.250
            remark #15478: estimated potential speedup: 2.320
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
LOOP BEGIN at ./datatype_3d.f90(126,1)
            remark #15389: vectorization support: reference H(:,:,:) has unaligned access
            remark #15477: vector cost: 0.620
            remark #15478: estimated potential speedup: 2.660
         LOOP END
            remark #25015: Estimate of max trip count of loop=24
         LOOP END
      LOOP END
   LOOP END
LOOP END
LOOP BEGIN at ./datatype_3d.f90(134,15)
   LOOP BEGIN at ./datatype_3d.f90(130,2)
      LOOP BEGIN at ./datatype_3d.f90(131,3)
         LOOP BEGIN at ./datatype_3d.f90(133,4)
            remark #15388: vectorization support: reference C(k,j,i) has aligned access   [ ./datatype_3d.f90(134,4) ]
            remark #15388: vectorization support: reference A(k,j,i) has aligned access   [ ./datatype_3d.f90(134,15) ]
            remark #15388: vectorization support: reference H(k,j,i) has aligned access   [ ./datatype_3d.f90(134,26) ]
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
    Report from: Code generation optimizations [cg]
./datatype_3d.f90(65,1):remark #34014: optimization advice for memset: increase the destination's alignment to 16 (and use __assume_aligned) to speed up library implementation
./datatype_3d.f90(65,1):remark #34026: call to memset implemented as a call to optimized library version
./datatype_3d.f90(126,1):remark #34014: optimization advice for memset: increase the destination's alignment to 16 (and use __assume_aligned) to speed up library implementation
./datatype_3d.f90(126,1):remark #34026: call to memset implemented as a call to optimized library version
./datatype_3d.f90(1,9):remark #34051: REGISTER ALLOCATION : [MAIN__] ./datatype_3d.f90:1
    Hardware registers
        Reserved     :    2[ rsp rip]
        Available    :   39[ rax rdx rcx rbx rbp rsi rdi r8-r15 mm0-mm7 zmm0-zmm15]
        Callee-save  :    6[ rbx rbp r12-r15]
        Assigned     :   30[ rax rdx rcx rbx rsi rdi r8-r15 zmm0-zmm15]
    Routine temporaries
        Total         :    1144
            Global    :     390
            Local     :     754
        Regenerable   :     193
        Spilled       :     171
    Routine stack
        Variables     :     276 bytes*
            Reads     :      10 [8.00e+00 ~ 0.0%]
            Writes    :      26 [2.40e+01 ~ 0.0%]
        Spills        :    1328 bytes*
            Reads     :     183 [5.44e+03 ~ 2.8%]
            Writes    :     175 [1.17e+03 ~ 0.6%]
    Notes
        *Non-overlapping variables and spills may share stack space,
         so the total stack size might be less than this.
Eric
eric_p_
Hi Tim,
I also try on KNL
 ifort  -align array64byte -axMIC-AVX512 -qopt-report4 -qopenmp -O2 ./datatype_3d.f90 -o ./dt.x
 TIME double  0.277145397663116
 TIME float  0.262126672267914
 TIME int1  0.287773197889328
 TIME int32  0.259244447946548
 TIME int64  0.570451277494431
 TIME logical  0.262114471197128
The results appears more raesonable, the floats have the better time. But on opt report the longest vector leght is for 8 bit integer even if it is mulptiply with double.
Compiler options: -align array64byte -axMIC-AVX512 -qopt-report4 -qopenmp -O2 -o ./dt.x
  -inline-factor: 100
         remark #15335: peel loop was not vectorized: vectorization possible but seems inefficient. Use vector always directive or -vec-threshold0 to override
         remark #15305: vectorization support: vector length 2
         remark #15309: vectorization support: normalized vectorization overhead 1.250
      LOOP END
         remark #15478: estimated potential speedup: 6.920
      LOOP END
         remark #15309: vectorization support: normalized vectorization overhead 1.364
      LOOP END
   LOOP END
LOOP END
      LOOP END
      LOOP END
      LOOP END
   LOOP END
LOOP END
            remark #15477: vector cost: 0.870
            remark #15478: estimated potential speedup: 8.920
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
         remark #15301: PEEL LOOP WAS VECTORIZED
         remark #25015: Estimate of max trip count of loop=1
      LOOP END
         remark #15305: vectorization support: vector length 16
         remark #15477: vector cost: 0.180
         remark #15478: estimated potential speedup: 11.840
      LOOP END
      LOOP END
   LOOP END
LOOP END
            remark #15477: vector cost: 1.000
            remark #15478: estimated potential speedup: 8.780
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
            remark #15309: vectorization support: normalized vectorization overhead 0.058
         LOOP END
            remark #15388: vectorization support: reference D(:,:,:) has aligned access
            remark #15477: vector cost: 0.090
            remark #15478: estimated potential speedup: 6.850
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
            remark #15478: estimated potential speedup: 9.760
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
         remark #15309: vectorization support: normalized vectorization overhead 0.938
         remark #25015: Estimate of max trip count of loop=15
      LOOP END
         remark #15478: estimated potential speedup: 8.210
      LOOP END
      LOOP END
   LOOP END
LOOP END
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
      LOOP END
         remark #15478: estimated potential speedup: 4.610
      LOOP END
      LOOP END
   LOOP END
LOOP END
            remark #15477: vector cost: 2.120
            remark #15478: estimated potential speedup: 4.590
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
            remark #15477: vector cost: 0.310
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
    Hardware registers
        Assigned     :    2[ rax rdx]
    Routine temporaries
        Total         :       9
            Global    :       7
            Local     :       2
        Regenerable   :       1
        Spilled       :       0
    Routine stack
        Variables     :       0 bytes*
            Reads     :       0 [0.00e+00 ~ -nan%]
            Writes    :       0 [0.00e+00 ~ -nan%]
        Spills        :       0 bytes*
    Notes
Begin optimization report for: DATATYPE [future_cpu_22]
      LOOP END
      LOOP END
      LOOP END
   LOOP END
LOOP END
      LOOP END
      LOOP END
      LOOP END
   LOOP END
LOOP END
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
      LOOP END
      LOOP END
      LOOP END
   LOOP END
LOOP END
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
         LOOP END
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
      LOOP END
      LOOP END
      LOOP END
   LOOP END
LOOP END
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
      LOOP END
      LOOP END
      LOOP END
   LOOP END
LOOP END
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
./datatype_3d.f90(1,9):remark #34051: REGISTER ALLOCATION : [MAIN__.Z] ./datatype_3d.f90:1
    Hardware registers
        Available    :   63[ rax rdx rcx rbx rbp rsi rdi r8-r15 mm0-mm7 zmm0-zmm31 k0-k7]
        Assigned     :   49[ rax rdx rcx rbx rsi rdi r8-r15 zmm0-zmm31 k1-k3]
    Routine temporaries
        Total         :    1283
            Global    :     448
            Local     :     835
        Regenerable   :     212
        Spilled       :     179
    Routine stack
        Spills        :    1432 bytes*
            Reads     :     223 [6.46e+03 ~ 3.1%]
            Writes    :     195 [2.18e+03 ~ 1.0%]
    Notes
Begin optimization report for: DATATYPE [generic]
      LOOP END
         remark #15476: scalar cost: 4
         remark #15477: vector cost: 1.500
         remark #15478: estimated potential speedup: 2.550
      LOOP END
      LOOP END
   LOOP END
LOOP END
      LOOP END
      LOOP END
      LOOP END
   LOOP END
LOOP END
            remark #15477: vector cost: 4.000
            remark #15478: estimated potential speedup: 2.220
            remark #25015: Estimate of max trip count of loop=62
         LOOP END
            remark #15309: vectorization support: normalized vectorization overhead 0.714
            remark #25436: completely unrolled by 4
         LOOP END
      LOOP END
   LOOP END
LOOP END
      LOOP END
         remark #15388: vectorization support: reference G(:,:,:) has aligned access
         remark #15478: estimated potential speedup: 3.680
      LOOP END
      LOOP END
   LOOP END
LOOP END
            remark #15477: vector cost: 4.500
            remark #15478: estimated potential speedup: 2.200
         LOOP END
            remark #15309: vectorization support: normalized vectorization overhead 0.667
         LOOP END
      LOOP END
   LOOP END
LOOP END
            remark #15309: vectorization support: normalized vectorization overhead 0.500
            remark #15478: estimated potential speedup: 4.920
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
            remark #15476: scalar cost: 11
            remark #15478: estimated potential speedup: 2.410
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
      LOOP END
         remark #15388: vectorization support: reference E(:,:,:) has aligned access
      LOOP END
      LOOP END
   LOOP END
LOOP END
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
      LOOP END
         remark #15388: vectorization support: reference F(:,:,:) has aligned access
         remark #15478: estimated potential speedup: 1.290
      LOOP END
      LOOP END
   LOOP END
LOOP END
            remark #15477: vector cost: 9.000
            remark #15478: estimated potential speedup: 1.220
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
         LOOP END
            remark #15388: vectorization support: reference H(:,:,:) has aligned access
            remark #15478: estimated potential speedup: 1.450
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
         LOOP END
         LOOP END
      LOOP END
   LOOP END
LOOP END
./datatype_3d.f90(1,9):remark #34051: REGISTER ALLOCATION : [MAIN__.A] ./datatype_3d.f90:1
    Hardware registers
        Assigned     :   28[ rax rdx rcx rbx rsi rdi r8-r15 zmm0-zmm13]
    Routine temporaries
        Total         :    1109
            Global    :     356
            Local     :     753
        Regenerable   :     194
        Spilled       :     137
    Routine stack
        Spills        :    1056 bytes*
            Reads     :     151 [3.22e+03 ~ 1.3%]
            Writes    :     139 [9.02e+02 ~ 0.4%]
    Notes
Eric
