I am new to Fortran, so I hope this question is not too simple.
I have a fortran dll, being called by vb 6.0, and in the dll, I am having a problem using automatic arrays.
For example, in the following line of code, NoComp=3, NoChain=1, but when I use quickwatch, InitInv is set up as an array with greter than 1000 elements (array expansion limited to 1000 nodes)
REAL(KIND=8), Dimension(NoComp*NoChain)::InitInv
Any help would be appreciated,
Ciara
Ciara
Are NoComp and NoChain arguments passed in? If so, it seems likely that they are not being passed correctly. Without seeing the actual code, and how it is called, it's difficult to say what is wrong.
Steve
Steve
NoComp and NoChain are passed in, but by checking with quick watch, the correct values have been passed in. I have included the call statements and declaration statements below,
Ciara
Ciara
SUBROUTINE COMA (NoChain, Decay, Conv,
& NoComp,InitTime, NoChgTran,
& ChgTranTime,NoChgSou,ChgSouTime,
& NoSou, NucSou, CompSou,
& InpSou, InitInvFlag,NoChgInv,
& ChgInvTime, NoOutTime, OutTime,
& OutOption,NoOut, OutComp,Idisc
& ,OutVal, Ifail,InpInitInv,
& CompFrom,CompTo,
& InpTranRate, SetInvToZero
& ,NoSetComp,SetToZeroComp, NoOutVal,InpNoTran)
!MS$ ATTRIBUTES DLLEXPORT :: COMA
!MS$ ATTRIBUTES ALIAS:'_COMA':: COMA
!MS$ ATTRIBUTES STDCALL :: COMA
!MS$ ATTRIBUTES REFERENCE :: CONV, NoComp
!MS$ ATTRIBUTES REFERENCE :: NoChain, Decay
!MS$ ATTRIBUTES REFERENCE :: InitTime, NoChgTran, ChgTranTime
!MS$ ATTRIBUTES REFERENCE :: NoChgSou,ChgSouTime, NoSou
!MS$ ATTRIBUTES REFERENCE :: NucSou, CompSou,InpSou, InitInvFlag
!MS$ ATTRIBUTES REFERENCE :: NoChgInv,ChgInvTime, NoOutTime
!MS$ ATTRIBUTES REFERENCE :: OutTime
!MS$ ATTRIBUTES REFERENCE :: OutOption,NoOut, OutComp,Idisc
!MS$ ATTRIBUTES REFERENCE :: OutVal,Ifail
!MS$ ATTRIBUTES REFERENCE :: InpInitInv,CompFrom,CompTo
!MS$ ATTRIBUTES REFERENCE :: InpTranRate, SetInvToZero
!MS$ ATTRIBUTES REFERENCE :: NoSetComp,SetToZeroComp, NoOutVal
!MS$ ATTRIBUTES REFERENCE :: InpNoTran
IMPLICIT NONE
* Declare and initialise variables
INTEGER(2):: Iyr, Imon, Iday, Ihr, Imin, Isec, I100th
INTEGER(4):: Conv, FirstOutTime, I, Ibx, Ich, Icm, Icomp, Id
INTEGER(4):: Idisc, Ifail, Ifind, Ineg, InitInvFlag
INTEGER(2):: InpNoTran
INTEGER(4):: Inv, Iop, Iot
INTEGER(4):: Irn,Iso, Isp, Itm, Itr, Jfind, Jtm, Kfind
INTEGER(4):: LastOutTime, LastRunTime,NoBox, NoChgInv, NoChgSou
INTEGER(4):: NoChgTran, NoComp, NoOut,NoChain,NoOutTime, NoOutVal
INTEGER(4):: NoRank, NoRun, NoRunTime, NoSetComp, NoSou,NoSpace
INTEGER(4):: NoTran, OutOption, SetInvToZero
Integer, Dimension(4*NoComp*NoChain)::BoxFrom
Integer, Dimension(NoChain)::BoxNoInv
Integer, Dimension(NoComp*NoChain)::BoxSou
Integer, Dimension(4*NoComp*NoChain)::BoxTo
Integer, Dimension(NoChgTran+1)::CompFrom
Integer, Dimension(NoSou)::CompSou
Integer, Dimension(NoChgTran+1)::CompTo
Integer, Dimension(3*NoChgTran+1)::FlagInv
Integer, Dimension(3*NoChgTran+1)::FlagTran
Integer, Dimension(3*NoChgTran+1)::IndInv
Integer, Dimension(3*NoChgTran+1)::IndSou
Integer, Dimension(3*NoChgTran+1)::IndTime
Integer, Dimension(3*NoChgTran+1)::IndOutTime
Integer, Dimension(3*NoChgTran+1)::IndTran
Integer, Dimension(NoSou)::NucSou
Integer, Dimension(2)::OutOpt
Integer, Dimension(NoComp*NoChain)::Rank
Integer, Dimension(NoChgTran+1*NoSetComp)::SetToZeroComp
Integer, Dimension(NoOut)::OutComp
REAL(KIND=4), Dimension(NoChgInv+1,NoComp*NoChain)::InpInitInv
REAL(KIND=4), Dimension(NoSou,NoChgSou+1)::InpSou
REAL(KIND=4), Dimension(InpNoTran,NoChain)::InpTranRate
REAL(KIND=8)::InitTime
REAL(KIND=8), Dimension(NoChgInv)::ChgInvTime
REAL(KIND=8), Dimension(NoChgSou)::ChgSouTime
REAL(KIND=8), Dimension(NoChgTran)::ChgTranTime
REAL(KIND=8), Dimension(NoChain)::Decay
REAL(KIND=8), Dimension(NoComp*NoChain)::InitInt
p*NoChain)::InitInv
REAL(KIND=8), Dimension(NoComp*NoChain,NoChgInv+1)::RINV
REAL(KIND=8), Dimension(NoComp*NoChain,NoChgInv+1)::RINT
REAL(KIND=8), Dimension(4*NoChgInv+1)::RunTime
REAL(KIND=8), Dimension(NoComp*NoChain)::Sou
REAL(KIND=8), Dimension(4*NoChgInv+1)::Times
REAL(KIND=8), Dimension(NoComp*NoChain*NoChain+1)::TranRate
REAL(KIND=8), Dimension(NoChain)::OutFac
REAL(KIND=8), Dimension(NoOutTime)::OutTime
RE
I suggest you send a reproducible example, including the calling VB code, to us at [email protected].
Steve
Steve
