Software Archive
Read-only legacy content
17060 Discussions
Does anyone get success using Facebook plugin?
Muhammad_Y_Efendi
I tried to use Facebook login plugin in Intel XDK, but I always failed when try to BUILD apps.
Does anyone get success build app using Facebook login plugin ?
PaulF_IntelCorp
Muhammad -- which version of that plugin are you using. Have you tried some other versions? Does your app build without the plugin?
Muhammad_Y_Efendi
Thanks for your respond.
I use latest version 1.7.4, my app build is good without facebook plugin.
I will tried the other version, do you have recomandation version?
Muhammad
PaulF_IntelCorp
No specific recommendation regarding the version; try other versions to see if you get the same or different results. Trying to focus in on the source of the problem, change some of the variables to see what changes. You might also have a conflict between that plugin and the others in your app. There could also be some clues in the detailed build log, check that, usually near the end.
Muhammad_Y_Efendi
Hi Paul,
I just installed the old version, and everything was good.
And after uninstall the old version, and install the latest version, it is good now.
I don't know what it was problem, but use the latest version is good now.
Thanks you so much for your help and advice.
