Software Archive
Read-only legacy content
17060 Discussions
Does not connect using facebook4 plugin
Ronaldo_M_
XDK Version: 3759
Facebook plugin version: 1.7.4
I am using the https://github.com/jeduan/cordova-plugin-facebook4, however it opens the login screen, shows my data (see this image:
http://i66.tinypic.com/21ej9k.png) but when I press "continue as ..." nothing happens, Without success, without error. When I click on it back it closes this screen, but it goes without action, when I click back again it gives an alert (object object), I already downloaded the ready model in the XDK templates and the same thing happens.
Giselle_G_Intel
Could you upload the image in this thread. The link can not be accessed. Also, what exactly are you trying to do with the plugin? Have you tried debugging using the Chrome DevTools or another debugging method to see if you're getting any errors? >https://software.intel.com/en-us/xdk/docs/using-remote-chrome-devtools-to-debug-android-cordova-apps<
Ronaldo_M_
I found the solution: The key hash that I created using openssl did not work right, and following some forums suggested to change by what is informed on the device when the error occurs. I also revoked all permissions, erased the application's access permission on facebook, and tried logging in and out several times and it worked perfectly now. Thank you
Thank you, for your help Giselle.
Giselle_G_Intel
Oh that's great to hear! Glad it is working now!
