Software Archive
Read-only legacy content
17060 Discussions
Does the realsense camera support micro USB3.0?
涛_季_
Hi,everyone!
Can I use an OTG to connect the camera to micro USB3.0?
samontab
Valued Contributor II
I guess the only way of finding out will be to just try it, and report back :)
Colleen_C_Intel
Does your PC have a micro USB3 port (split into two pieces)?  The early dev IVCam cameras had that connector on the camera end (before the newer ones with attached cables), so it's likely it might work. But no guarantee.
涛_季_
Hi,Colleen Culbertson
Yes,it has a micro USB3 port (split into two pieces).
忠杰_朱_
我尝试使用OTG失败了,我用的R200
