Software Archive
Read-only legacy content
17060 Discussions
Download is not working inside iframe
Ajith_j_
Hi All,
I want to show an external url  eg(http://codzz.com/mob.aspx) inside iframe and there is a button to download file on click, But the download button dose not work inside the iframe..
Is there any solution to fix this error?
Thanks in Advance
Ajith
Ajith_j_
Thanks for your reply, Please find my below code. it works fine in emulator and not in devices.
Sample downloaded from https://github.com/gomobile/sample-url-app/blob/master/www/index.html
<!DOCTYPE html>
<html>
* Please see the included README.md file for license terms and conditions.
<head>
<link rel="stylesheet" type="text/css" href="app_framework/css/af.ui.min.css">
<link rel="stylesheet" type="text/css" href="app_framework/css/icons.min.css">
<meta charset="UTF-8">
<title>Blank App Designer Cordova Web App Project Template</title>
<meta http-equiv="Content-type" content="text/html; charset=utf-8">
* The "meta viewport" tag (below) helps your app size appropriately to a device's ideal viewport.
* Note that Windows device viewports work better when initialized using the @viewport CSS rule.
* For a quick overview of "meta viewport" and @viewport, see this article:
* http://webdesign.tutsplus.com/tutorials/htmlcss-tutorials/quick-tip-dont-forget-the-viewport-meta-tag
* To see how it works, try your app on a real device with and without a "meta viewport" tag.
* Additional useful references include:
* http://www.quirksmode.org/mobile/viewports.html
* http://www.quirksmode.org/mobile/metaviewport/devices.html
* https://developer.apple.com/library/safari/documentation/AppleApplications/Reference/SafariHTMLRef/Articles/MetaTags.html
<!-- <meta name="viewport" content="width=device-width, minimum-scale=1, initial-scale=1"> -->
<meta name="viewport" content="width=device-width, minimum-scale=1, initial-scale=1, user-scalable=no">
<!-- <meta name="viewport" content="width=device-width, initial-scale=1, user-scalable=yes, minimum-scale=1, maximum-scale=2"> -->
<style>
/* following three (cascaded) are equivalent to above three meta viewport statements */
/* see http://www.quirksmode.org/blog/archives/2014/05/html5_dev_conf.html */
/* see http://dev.w3.org/csswg/css-device-adapt/ */
@-ms-viewport { width: 100vw ; min-zoom: 100% ; zoom: 100% ; } @viewport { width: 100vw ; min-zoom: 100% zoom: 100% ; }
@-ms-viewport { user-zoom: fixed ; min-zoom: 100% ; } @viewport { user-zoom: fixed ; min-zoom: 100% ; }
/*@-ms-viewport { user-zoom: zoom ; min-zoom: 100% ; max-zoom: 200% ; } @viewport { user-zoom: zoom ; min-zoom: 100% ; max-zoom: 200% ; }*/
</style>
<link rel="stylesheet" href="css/app.css">
<link rel="stylesheet" type="text/css" href="css/index_main.less.css" class="main-less">
<!-- IMPORTANT: Do not include a weinre script tag as part of your release builds! -->
<!-- Place your remote debugging (weinre) script URL from the Test tab here, if it does not work below -->
<!-- <script src="http://debug-software.intel.com/target/target-script-min.js#insertabiglongfunkynumberfromthexdkstesttab"></script> -->
<!-- Recommended location for your JavaScript libraries -->
<!-- These library references (below) are just examples to give you the general idea... -->
<!-- <script src="lib/mc/hammer.js"></script> -->
<!-- <script src="lib/ft/fastclick.js"></script> -->
<!-- Uncomment this script element if you convert your "Cordova web app" to a "Standard HTML5 web app" -->
<script type="text/javascript" id="xdkJSdevBrowser_">
window.dev = window.dev || {} ; // object used by init-dev.js, which detects various ready events
dev.BROWSER = 500 ; // msecs, in non-Cordova app we don't care about "deviceready" events
</script>
* cordova.js is a phantom lib for "Cordova HTML5 web app," it does nothing in a "Standard HTML5 web app"
* Seeing a "Failed to load resource: net::ERR_FILE_NOT_FOUND" message caused by this "cordova.js" script?
* The cordova.js script is required if you convert your "Standard HTML5" project into a "Cordova" project.
* You can safely ignore the error or comment out this line if you will not be developing a Cordova app.
<script src="cordova.js" id="xdkJScordova_"></script>
<script src="js/app.js"></script>
<!-- for your event code, see README and file comments for details -->
<script src="js/init-app.js"></script>
<!-- for your init code, see README and file comments for details -->
<script src="xdk/init-dev.js"></script>
<!-- normalizes device and document ready events, see file for details -->
<script src="js/main.js"></script>
You may substitute jQuery for the App Framework selector library.
See http://app-framework-software.intel.com/documentation.php#afui/afui_jquery
<script type="application/javascript" src="app_framework/appframework.js"></script>
<script type="application/javascript" src="app_framework/appframework.ui.js"></script>
</head>
<body id="afui" onload="onDocLoad()">
<!-- Place your remote debugging (weinre) script URL from the Test tab here, if it does not work above -->
<div id="content" class="uwrap">
<div class="upage vertical-col left panel" id="mainpage" data-header="none" data-footer="none">
<div class="widget uib_w_1 d-margins iframe-size" data-uib="media/iframe" data-ver="0">
<iframe seamless="seamless" id="IDZ_iFrame" src="http://codzz.com/mob.aspx"></iframe>
</div>
</div>
</div>
</body>
</html>
Ajith_j_
No, It dosent work. I have tried AppBrowser plugin too.
     <script src="cordova.js"></script>
    <script>
        function openwin(){
            window.open('http://codzz.com/mob.aspx', '_blank', '');
    </script>      <button onclick="openwin()">window open</button>
Again I have added header in my aspx page, still same problem.
  string fileName = "mmmmm.mp3";
            string filePath = Server.MapPath("~/mmmmm.mp3");
            Response.Clear();
            Response.ClearHeaders();
            Response.AddHeader("Access-Control-Allow-Origin", "*");
            Response.AppendHeader("Access-Control-Allow-Methods", "OPTIONS,POST,GET");
            Response.AppendHeader("Access-Control-Allow-Headers", "X-File-Name,X-File-Type,X-File-Size");
            Response.ContentType = "audio/mpeg";
            Response.AddHeader("content-disposition", "attachment; filename=" + fileName);
            Response.WriteFile(filePath);
            Response.Flush();
            Response.End();
gbengaadaramodu
Gabriele,
please, kindly show the project sample that work for iframe. cos i am still finding difficulty using iframe.
thank you.
Gbenga
