From a software application point of view, the two pipes of the Intel 82855GM Graphics Controller are exposed to the system simple as two separate controllers (just like inserting two PCI controllers into a desktop system).
You can render two separate frame buffers, just like you would if you had two physical discrete adapters.
However, as you say, the LVDS (local flat panel) is limited to one of those controllers. The other controller would have its output based on whatever DVO solution your motherboard has. (i.e. external DVI Flat Panel, TV-Out, etc.)
Hi Nick
I have a similar problem.
I want to drive 2 x LVDS large 19" displays direct from an Intel graphics chipset but do not know if there is an Intelchipset to support my requirements.
The 19" LVDS displays are 48 bit and need 2 channel LVDS to support this.
Can the DVO support 48 bitor 24 bit LVDSor would I need 2 DVO to support this requirement?
Is there an Intel graphics card with this highgraphics performance?
Wayno
