Software Archive
Read-only legacy content
17060 Discussions
Eclipse for 32-bit Linux?
Tamilselvan_S_
I see the Eclipse provided at https://software.intel.com/en-us/node/532593 is meant for 64-bit OS.
I'm running 32-bit Linux. Could anyone help me out to install Eclipse dev kit?
Thanks in advance.
Matthias_H_Intel
32-bit host is currently not supported. So it would require some manual work. You could for instance try 32-bit QtCreator and use the 32-bit cross toolchain coming with the 32-bit Arduino IDE (e.g. following https://communities.intel.com/message/261262#261262). ;
Tamilselvan_S_
Thanks for your rapid reply matthias-hahn. I'll give a try.
samontab
Valued Contributor II
If you don't need Qt SDK, you could follow this tutorial that uses Qt Creator and CMake for your projects:
https://software.intel.com/en-us/forums/topic/542253
