I would like to use node.js and Intel XDK IoT Edition IDE and believe I need a network connection in addition to my 2 Edison/PC USB connections.
WiFi is recommended as a serial connection, but when I run "configure_edison --wifi" I do not get a list of networks to choose from. I get the prompt to rescan or manually input a hidden SSID.
My PC sees several networks and is connected to one.
What should I try next?
Phil
- Tags:
- Internet of Things
Can you check the version of the build in Edison?
root@edison:~# cat /etc/version
weekly-120
Please follow the tutorial Intel® Edison: Getting Started – WiFi*.
You can also try an alternative method using wpa_supplicant to get connected - http://www.intel.com/support/edison/sb/CS-035234.htm.
If you don't need internet connectivity and would just want to connect the board to the PC you can enable Ethernet Over USB.
I had only tried hitting 0 once, I found that subsequently pressing 0 caused the rescan to find the networks - I connected OK
Yeah sometimes you may need to rescan to see the available networks. But I believe it is not the case with the latest image. Are you running the latest build on your device?
What is the latest build?
Thanks!
Phil
weekly-120
You can download the latest image from http://www.intel.com/support/edison/sb/CS-035180.htm.
