Software Archive
Read-only legacy content
17060 Discussions
Emulator Differences from Actual App
Nick_F_2
New Contributor III
HI
I have some buttons that render correctly on the emulator except for iPhone 5 where the buttons remain as a blue/white outlined button.
Rakshith_K_Intel
Looks like you are using appframework, it applies themes based on the os version, for iOS7 and higher you should see the blue/white outline.
If you want to fix the theme, then do the following:
$.afui.useOSThemes=false;
<div id="afui" class="ios"></div>
more information here: http://app-framework-software.intel.com/documentation.php#afui/afui_themes
Nick_F_2
New Contributor III
Thanks for your reply.
In the emulator the iPhone 3GS, 4S, 6 and 6 Plus all display the buttons are nicely rendered as per my theme.png image, but the iPhone 5 will only display the buttons as my no-theme image.
Once the applications is deployed to the device it renders correctly as per theme.png.
