Software Archive
Read-only legacy content
17060 Discussions
Erro ao gerar o Build para IOS
Rodrigo_Bastos
Olá pessoal, fiz um app pelo intel xdk e gerei o build para o android sem problemas (inclusive já subi o mesmo na Play Store), porém não consigo gerar o build para o IOS de jeito nenhum, retornando sempre o mesmo erro.
Se alguém puder ajudar, eu agradeço.
Segue o erro abaixo:
** BUILD FAILED **
The following build commands failed:
    CompileC build/CnLS.build/Release-iphoneos/CnLS.build/Objects-normal/armv7/FacebookConnectPlugin.o CnLS/Plugins/phonegap-facebook-plugin/FacebookConnectPlugin.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
(1 failure)
ERROR building one of the platforms: Error code 65 for command: xcodebuild with args: -xcconfig,.../CnLS/platforms/ios/cordova/build-release.xcconfig,-project,CnLS.xcodeproj,ARCHS=armv7 arm64,-target,CnLS,-configuration,Release,-sdk,iphoneos,build,VALID_ARCHS=armv7 arm64,CONFIGURATION_BUILD_DIR=.../CnLS/platforms/ios/build/device,SHARED_PRECOMPS_DIR=.../CnLS/platforms/ios/build/sharedpch
You may not have the required environment or OS to build this project
Error: Error code 65 for command: xcodebuild with args: -xcconfig,.../CnLS/platforms/ios/cordova/build-release.xcconfig,-project,CnLS.xcodeproj,ARCHS=armv7 arm64,-target,CnLS,-configuration,Release,-sdk,iphoneos,build,VALID_ARCHS=armv7 arm64,CONFIGURATION_BUILD_DIR=.../CnLS/platforms/ios/build/device,SHARED_PRECOMPS_DIR=.../CnLS/platforms/ios/build/sharedpch
Hamilton_Tenório_da_
Valued Contributor I
Olhei a documentação do plugin e achei isso:
<< --- Cordova Registry Warning [iOS]
*Installing this plugin directly from Cordova Registry results in Xcode using a broken FacebookSDK.framework, this is because the current publish procedure to NPM breaks symlinks CB-6092. Please install the plugin through a locally cloned copy or re-add the FacebookSDK.framework to Xcode after installation.*
Você fez a inclusão através de uma cópia como citado?
@Rodrigo> não sei se o caso é o mesmo, mas eu tive problema semelhante na semana passada. O que fiz foi mudar a ordem de alguns plugins direto pelo arquivo .XDK. Aí passou a funcionar. Tente isso.
Rodrigo_Bastos
Olá Hamilton, obrigado pela resposta.
Eu desinstalei alguns plugins e consegui gerar o build, porém um desses plugins que desisntalei foi o do facebook connect e descobri que o erro está nele. O problema é que vou precisar desse plugin no app.
Att
@Rodrigo,
Uma tentativa: insira novamente este plugin. Ele vai para o final do arquivo .XDK dentro do bloco do iOS. Acesso o arquivo por um editor e coloque-o no início do bloco (acerte as vírgulas de continuação dos campos). Veja se isso faz ele funcionar.
Rodrigo_Bastos
Não deu certo mesmo. Tentei gerar esse build hoje o dia todo. :(
humberto_A_
estou com o mesmo problema onde esta o pessoal da intel nesse momento importante para o atendimento ao developer
Sem o plugin do Facebook compila? Eu fiz um teste de compilação iOS agora e passou normal (The Build Was Successful!).
Você tentou pegar uma versão anterior do plugin?
Rodrigo_Bastos
Sem o plugin do facebook ele compila sim. Mudei a versão do plugin agora e vou testar. Já posto o resultado aqui.
Rodrigo_Bastos
Nâo deu certo de novo. Ta complicado esse buid.
