Software Archive
Read-only legacy content
17061 Discussions
Error 1:The type or namespace name 'PXCMSenseManager' could not be found
Mona_J_
I am trying to follow this tutorial for a simple HelloWorld in Visual Studio 2013 Community Edition but I get the following error in MainWindow.xaml.cs file:
Error    1    The type or namespace name 'PXCMSenseManager' could not be found (are you missing a using directive or an assembly reference?)    c:\users\mona\documents\visual studio 2013\projects\wpf1\wpf1\mainwindow.xaml.cs    15    17    wpf1
Do you know how to fix it?
Here's the code for that file:
using System;
using System.Windows;
using System.Windows.Media;
using System.Threading;
using System.Drawing;
namespace wpf1
    /// <summary>
    /// Interaction logic for MainWindow.xaml
    /// </summary>
    public partial class MainWindow : Window
        private Thread processingThread;
        private PXCMSenseManager senseManager;
        private PXCMHandModule hand;
        private PXCMHandConfiguration handConfig;
        private PXCMHandData handData;
        private PXCMHandData.GestureData gestureData;
        private bool handWaving;
        private bool handTrigger;
        private int msgTimer;
        public MainWindow()
            InitializeComponent();
            handWaving = false;
            handTrigger = false;
            msgTimer = 0;
            // Instantiate and initialize the SenseManager
            senseManager = PXCMSenseManager.CreateInstance();
            senseManager.EnableStream(PXCMCapture.StreamType.STREAM_TYPE_COLOR, 640, 480, 30);
            senseManager.EnableHand();
            senseManager.Init();
            // Configure the Hand Module
            hand = senseManager.QueryHand();
            handConfig = hand.CreateActiveConfiguration();
            handConfig.EnableGesture("wave");
            handConfig.EnableAllAlerts();
            handConfig.ApplyChanges();
            // Start the worker thread
            processingThread = new Thread(new ThreadStart(ProcessingThread));
            processingThread.Start();
        private void Window_Loaded(object sender, RoutedEventArgs e)
            lblMessage.Content = "(Wave Your Hand)";
        private void Window_Closing(object sender, System.ComponentModel.CancelEventArgs e)
            processingThread.Abort();
            if (handData != null) handData.Dispose();
            handConfig.Dispose();
            senseManager.Dispose();
        private void ProcessingThread()
            // Start AcquireFrame/ReleaseFrame loop
            while (senseManager.AcquireFrame(true) >= pxcmStatus.PXCM_STATUS_NO_ERROR)
                PXCMCapture.Sample sample = senseManager.QuerySample();
                Bitmap colorBitmap;
                PXCMImage.ImageData colorData;
                // Get color image data
                sample.color.AcquireAccess(PXCMImage.Access.ACCESS_READ, PXCMImage.PixelFormat.PIXEL_FORMAT_RGB24, out colorData);
                colorBitmap = colorData.ToBitmap(0, sample.color.info.width, sample.color.info.height);
                // Retrieve gesture data
                if (hand != null)
                    // Retrieve the most recent processed data
                    handData = hand.CreateOutput();
                    handData.Update();
                    handWaving = handData.IsGestureFired("wave", out gestureData);
                // Update the user interface
                UpdateUI(colorBitmap);
                // Release the frame
                colorBitmap.Dispose();
                sample.color.ReleaseAccess(colorData);
                senseManager.ReleaseFrame();
        private void UpdateUI(Bitmap bitmap)
            this.Dispatcher.Invoke(System.Windows.Threading.DispatcherPriority.Normal, new Action(delegate()
                if (bitmap != null)
                    // Mirror the color stream Image control
                    imgColorStream.RenderTransformOrigin = new System.Windows.Point(0.5, 0.5);
                    ScaleTransform mainTransform = new ScaleTransform();
                    mainTransform.ScaleX = -1;
                    mainTransform.ScaleY = 1;
                    imgColorStream.RenderTransform = mainTransform;
                    // Display the color stream
                    imgColorStream.Source = ConvertBitmap.BitmapToBitmapSource(bitmap);
                    // Update the screen message
                    if (handWaving)
                        lblMessage.Content = "Hello World!";
                        handTrigger = true;
                    // Reset the screen message after ~50 frames
                    if (handTrigger)
                        msgTimer++;
                        if (msgTimer >= 50)
                            msgTimer = 0;
Also I have attached my project files in a zip format. Can you please tell me if I have missing configuration or what is the fix?
Mona Jalal.
Mona_J_
Well the solution is to select only one (x64) from the References when you right click on it and select Browse.
