Software Archive
Read-only legacy content
Error #10052, Parallel Studio XE 2017 Intel Fortran Compiler
pietro_g_
I downloaded and installed the 30-days trial Fortran and C++ intel compiler version.
I tried to compile a dummy Fortran code in Visual Studio 2015, and I get the following errors:
error #10052: could not checkout FLEXlm license
Error A license for Comp-FW is not available (-157,424).
The Microsoft C++ support is installed as part of VS 2015. I already rebooted my laptop. The INTEL_LICENCE_FILE env variable has been  set up during the installation, but it points to an empty folder.
Could you please help me addressing the issue?
Thank you,
Pietro
Jennifer_D_Intel
It looks like the compiler is having a problem accessing the license in trusted storage.  Can you copy the license file I emailed to you into the folder specified in INTEL_LICENSE_FILE and try again?
Jennifer
pietro_g_
Hello Jennifer,
Thank you for the quick reply.
I copied the file in the folder and now it compiles correctly.
Thank you!
Pietro
