Software Archive
Read-only legacy content
17060 Discussions
Error: A license for Comp-CL is not available now (-15,570,115)
yongbei_ma_
Friends,
this is error what I got when I type icc -v:
Error: A license for Comp-CL is not available now (-15,570,115).
A connection to the license server could not be made.  You should
make sure that your license daemon process is running: both an
lmgrd process and an INTEL process should be running
if your license limits you to a specified number of licenses in use
at a time.  Also, check to see if the wrong port@host or the wrong
license file is being used, or if the port or hostname in the license
file has changed.
License file(s) used were (in this order):
    1.  Trusted Storage
**  2.  /software/intel/compilers_and_libraries_2017.4.196/linux/licenses
**  3.  /opt/intel/licenses/*******.lic
**  4.  /root/intel/licenses
**  5.  /software/intel/compilers_and_libraries_2017.4.196/linux/bin/intel64/../../Licenses
**  6.  /root/Licenses
**  7.  /Users/Shared/Library/Application Support/Intel/Licenses
**  8.  /software/intel/compilers_and_libraries_2017.4.196/linux/bin/intel64/*******.lic
**  9.  /software/intel/compilers_and_libraries_2017.4.196/linux/bin/intel64/*******.lic
Please visit http://software.intel.com/sites/support/ if you require technical assistance.
icc: error #10052: could not checkout FLEXlm license
I follow the instruction here:
https://software.intel.com/en-us/articles/how-to-find-host-id-for-floating-licenses
this article only show how to find hostname and hostID and not show how to find the port.
Devorah_H_Intel
Port # 28518 by default.
Are you able to connect to the server from the client?
Please provide the Serial number of the license via private message (use Send Author a Message link)
yongbei_ma_
This issue has been solved when I install Intel software license manager.
