Software Archive
Read-only legacy content
17060 Discussions
Error Building ios - intel xdk 2727
Samuel_S_3
The app that I developed had its build for android ok , however when I perform the build for ios glitch and shows where the error , even in the log below says that the build was successful, excuse language mistakes , I'm using google translator (Pt -BR)
Calling plugman.fetch on plugin ".../cachedPlugins.ydveGt.tmp/cache.RxrJjI.pl/cordova-plugin-statusbar"
Copying plugin ".../cachedPlugins.ydveGt.tmp/cache.RxrJjI.pl/cordova-plugin-statusbar" => ".../Sicredi/plugins/cordova-plugin-statusbar"
Calling plugman.install on plugin ".../Sicredi/plugins/cordova-plugin-statusbar" for platform "ios" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.ydveGt.tmp/cache.RxrJjI.pl/cordova-plugin-statusbar":{"filepath":".../cachedPlugins.ydveGt.tmp/cache.RxrJjI.pl/cordova-plugin-statusbar/plugin.xml","dir":".../cachedPlugins.ydveGt.tmp/cache.RxrJjI.pl/cordova-plugin-statusbar","_et":{"_root":{"_id":39,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:rim":"http://www.blackberry.com/ns/widgets","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-statusbar","version":"1.0.0"},"text":"\n    ","tail":null,"_children":[{"_id":40,"tag":"name","attrib":{},"text":"StatusBar","tail":"\n    ","_children":[]},{"_id":41,"tag":"description","attrib":{},"text":"Cordova StatusBar Plugin","tail":"\n    ","_children":[]},{"_id":42,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":43,"tag":"keywords","attrib":{},"text":"cordova,statusbar","tail":"\n\n    ","_children":[]},{"_id":44,"tag":"engines","attrib":{},"text":"\n            ","tail":"\n\n    ","_children":[{"_id":45,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":46,"tag":"js-module","attrib":{"src":"www/statusbar.js","name":"statusbar"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":47,"tag":"clobbers","attrib":{"target":"window.StatusBar"},"text":"","tail":"\n    ","_children":[]}]},{"_id":48,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":49,"tag":"source-file","attrib":{"src":"src/android/StatusBar.java","target-dir":"src/org/apache/cordova/statusbar"},"text":"","tail":"\n\n        ","_children":[]},{"_id":50,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n    ","_children":[{"_id":51,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n        ","_children":[{"_id":52,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.statusbar.StatusBar"},"text":"","tail":"\n                ","_children":[]},{"_id":53,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]}]},{"_id":54,"tag":"platform","attrib":{"name":"ios"},"text":"\n\n        ","tail":"\n\n    \n    ","_children":[{"_id":55,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":56,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n            ","_children":[{"_id":57,"tag":"param","attrib":{"name":"ios-package","value":"CDVStatusBar"},"text":"","tail":"\n                ","_children":[]},{"_id":58,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]},{"_id":59,"tag":"preference","attrib":{"name":"StatusBarOverlaysWebView","value":"true"},"text":"","tail":"\n            ","_children":[]},{"_id":60,"tag":"preference","attrib":{"name":"StatusBarStyle","value":"lightcontent"},"text":"","tail":"\n        ","_children":[]}]},{"_id":61,"tag":"header-file","attrib":{"src":"src/ios/CDVStatusBar.h"},"text":"","tail":"\n        ","_children":[]},{"_id":62,"tag":"source-file","attrib":{"src":"src/ios/CDVStatusBar.m"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":63,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":64,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":65,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n        ","_children":[{"_id":66,"tag":"param","attrib":{"name":"wp-package","value":"StatusBar"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":67,"tag":"source-file","attrib":{"src":"src/wp/StatusBar.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":68,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":69,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":70,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n        ","_children":[{"_id":71,"tag":"param","attrib":{"name":"wp-package","value":"StatusBar"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":72,"tag":"source-file","attrib":{"src":"src/wp/StatusBar.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":73,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n","_children":[{"_id":74,"tag":"js-module","attrib":{"src":"src/windows/StatusBarProxy.js","name":"StatusBarProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":75,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-statusbar","version":"1.0.0","name":"StatusBar","description":"Cordova StatusBar Plugin","license":"Apache 2.0","keywords":["cordova","statusbar"]},".../Sicredi/plugins/cordova-plugin-statusbar":{"filepath":".../Sicredi/plugins/cordova-plugin-statusbar/plugin.xml","dir":".../Sicredi/plugins/cordova-plugin-statusbar","_et":{"_root":{"_id":76,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:rim":"http://www.blackberry.com/ns/widgets","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-statusbar","version":"1.0.0"},"text":"\n    ","tail":null,"_children":[{"_id":77,"tag":"name","attrib":{},"text":"StatusBar","tail":"\n    ","_children":[]},{"_id":78,"tag":"description","attrib":{},"text":"Cordova StatusBar Plugin","tail":"\n    ","_children":[]},{"_id":79,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":80,"tag":"keywords","attrib":{},"text":"cordova,statusbar","tail":"\n\n    ","_children":[]},{"_id":81,"tag":"engines","attrib":{},"text":"\n            ","tail":"\n\n    ","_children":[{"_id":82,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":83,"tag":"js-module","attrib":{"src":"www/statusbar.js","name":"statusbar"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":84,"tag":"clobbers","attrib":{"target":"window.StatusBar"},"text":"","tail":"\n    ","_children":[]}]},{"_id":85,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":86,"tag":"source-file","attrib":{"src":"src/android/StatusBar.java","target-dir":"src/org/apache/cordova/statusbar"},"text":"","tail":"\n\n        ","_children":[]},{"_id":87,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n    ","_children":[{"_id":88,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n        ","_children":[{"_id":89,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.statusbar.StatusBar"},"text":"","tail":"\n                ","_children":[]},{"_id":90,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]}]},{"_id":91,"tag":"platform","attrib":{"name":"ios"},"text":"\n\n        ","tail":"\n\n    \n    ","_children":[{"_id":92,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":93,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n            ","_children":[{"_id":94,"tag":"param","attrib":{"name":"ios-package","value":"CDVStatusBar"},"text":"","tail":"\n                ","_children":[]},{"_id":95,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]},{"_id":96,"tag":"preference","attrib":{"name":"StatusBarOverlaysWebView","value":"true"},"text":"","tail":"\n            ","_children":[]},{"_id":97,"tag":"preference","attrib":{"name":"StatusBarStyle","value":"lightcontent"},"text":"","tail":"\n        ","_children":[]}]},{"_id":98,"tag":"header-file","attrib":{"src":"src/ios/CDVStatusBar.h"},"text":"","tail":"\n        ","_children":[]},{"_id":99,"tag":"source-file","attrib":{"src":"src/ios/CDVStatusBar.m"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":100,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":101,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":102,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n        ","_children":[{"_id":103,"tag":"param","attrib":{"name":"wp-package","value":"StatusBar"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":104,"tag":"source-file","attrib":{"src":"src/wp/StatusBar.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":105,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":106,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":107,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n        ","_children":[{"_id":108,"tag":"param","attrib":{"name":"wp-package","value":"StatusBar"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":109,"tag":"source-file","attrib":{"src":"src/wp/StatusBar.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":110,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n","_children":[{"_id":111,"tag":"js-module","attrib":{"src":"src/windows/StatusBarProxy.js","name":"StatusBarProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":112,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-statusbar","version":"1.0.0","name":"StatusBar","description":"Cordova StatusBar Plugin","license":"Apache 2.0","keywords":["cordova","statusbar"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-statusbar" for ios
Running command: .../Sicredi/platforms/ios/cordova/version
Command finished with error code 0: .../Sicredi/platforms/ios/cordova/version
Install start for "cordova-plugin-statusbar" on ios.
Beginning processing of action stack for ios project...
Parsing ios project files...
Action stack processing complete.
Writing out ios project files...
Preparing ios project
Processing configuration changes for plugins.
Iterating over installed plugins: [ 'cordova-plugin-statusbar' ]
Writing out cordova_plugins.js...
Install complete for cordova-plugin-statusbar on ios.
Calling plugman.fetch on plugin ".../cachedPlugins.ydveGt.tmp/cache.0no1bI.pl/cordova-plugin-device"
Copying plugin ".../cachedPlugins.ydveGt.tmp/cache.0no1bI.pl/cordova-plugin-device" => ".../Sicredi/plugins/cordova-plugin-device"
Calling plugman.install on plugin ".../Sicredi/plugins/cordova-plugin-device" for platform "ios" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.ydveGt.tmp/cache.0no1bI.pl/cordova-plugin-device":{"filepath":".../cachedPlugins.ydveGt.tmp/cache.0no1bI.pl/cordova-plugin-device/plugin.xml","dir":".../cachedPlugins.ydveGt.tmp/cache.0no1bI.pl/cordova-plugin-device","_et":{"_root":{"_id":39,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:rim":"http://www.blackberry.com/ns/widgets","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-device","version":"1.0.1"},"text":"\n    ","tail":null,"_children":[{"_id":40,"tag":"name","attrib":{},"text":"Device","tail":"\n    ","_children":[]},{"_id":41,"tag":"description","attrib":{},"text":"Cordova Device Plugin","tail":"\n    ","_children":[]},{"_id":42,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":43,"tag":"keywords","attrib":{},"text":"cordova,device","tail":"\n    ","_children":[]},{"_id":44,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-device.git","tail":"\n    ","_children":[]},{"_id":45,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320648","tail":"\n\n    ","_children":[]},{"_id":46,"tag":"js-module","attrib":{"src":"www/device.js","name":"device"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":47,"tag":"clobbers","attrib":{"target":"device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":48,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":49,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":50,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":51,"tag":"param","attrib":{"name":"firefoxos-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":52,"tag":"js-module","attrib":{"src":"src/firefoxos/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":53,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":54,"tag":"platform","attrib":{"name":"tizen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":55,"tag":"js-module","attrib":{"src":"src/tizen/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":56,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":57,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":58,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":59,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":60,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.device.Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":61,"tag":"source-file","attrib":{"src":"src/android/Device.java","target-dir":"src/org/apache/cordova/device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":62,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n    \n    \n    ","_children":[{"_id":63,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":64,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":65,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.device.Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":66,"tag":"source-file","attrib":{"src":"src/android/Device.java","target-dir":"src/org/apache/cordova/device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":67,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":68,"tag":"header-file","attrib":{"src":"src/ubuntu/device.h"},"text":"","tail":"\n        ","_children":[]},{"_id":69,"tag":"source-file","attrib":{"src":"src/ubuntu/device.cpp"},"text":"","tail":"\n        ","_children":[]},{"_id":70,"tag":"js-module","attrib":{"src":"src/ubuntu/device.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":71,"tag":"merges","attrib":{"target":"device"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":72,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":73,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":74,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":75,"tag":"param","attrib":{"name":"ios-package","value":"CDVDevice"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":76,"tag":"header-file","attrib":{"src":"src/ios/CDVDevice.h"},"text":"","tail":"\n        ","_children":[]},{"_id":77,"tag":"source-file","attrib":{"src":"src/ios/CDVDevice.m"},"text":"","tail":"\n    ","_children":[]}]},{"_id":78,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":79,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"Device"},"text":"","tail":"\n        ","_children":[]},{"_id":80,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n        ","_children":[{"_id":81,"tag":"feature","attrib":{"name":"Device","value":"Device"},"text":"","tail":"\n        ","_children":[]}]},{"_id":82,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget/rim:permissions"},"text":"\n            ","tail":"\n    ","_children":[{"_id":83,"tag":"rim:permit","attrib":{},"text":"read_device_identifying_information","tail":"\n        ","_children":[]}]}]},{"_id":84,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":85,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":86,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":87,"tag":"param","attrib":{"name":"wp-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":88,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":89,"tag":"Capability","attrib":{"Name":"ID_CAP_IDENTITY_DEVICE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":90,"tag":"source-file","attrib":{"src":"src/wp/Device.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":91,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":92,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":93,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":94,"tag":"param","attrib":{"name":"wp-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":95,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":96,"tag":"Capability","attrib":{"Name":"ID_CAP_IDENTITY_DEVICE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":97,"tag":"source-file","attrib":{"src":"src/wp/Device.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":98,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":99,"tag":"js-module","attrib":{"src":"src/windows/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":100,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":101,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n\n","_children":[{"_id":102,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":103,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":104,"tag":"param","attrib":{"name":"browser-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":105,"tag":"js-module","attrib":{"src":"src/browser/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":106,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-device","version":"1.0.1","name":"Device","description":"Cordova Device Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-device.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320648","keywords":["cordova","device"]},".../Sicredi/plugins/cordova-plugin-device":{"filepath":".../Sicredi/plugins/cordova-plugin-device/plugin.xml","dir":".../Sicredi/plugins/cordova-plugin-device","_et":{"_root":{"_id":107,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:rim":"http://www.blackberry.com/ns/widgets","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-device","version":"1.0.1"},"text":"\n    ","tail":null,"_children":[{"_id":108,"tag":"name","attrib":{},"text":"Device","tail":"\n    ","_children":[]},{"_id":109,"tag":"description","attrib":{},"text":"Cordova Device Plugin","tail":"\n    ","_children":[]},{"_id":110,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":111,"tag":"keywords","attrib":{},"text":"cordova,device","tail":"\n    ","_children":[]},{"_id":112,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-device.git","tail":"\n    ","_children":[]},{"_id":113,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320648","tail":"\n\n    ","_children":[]},{"_id":114,"tag":"js-module","attrib":{"src":"www/device.js","name":"device"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":115,"tag":"clobbers","attrib":{"target":"device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":116,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":117,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":118,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":119,"tag":"param","attrib":{"name":"firefoxos-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":120,"tag":"js-module","attrib":{"src":"src/firefoxos/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":121,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":122,"tag":"platform","attrib":{"name":"tizen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":123,"tag":"js-module","attrib":{"src":"src/tizen/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":124,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":125,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":126,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":127,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":128,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.device.Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":129,"tag":"source-file","attrib":{"src":"src/android/Device.java","target-dir":"src/org/apache/cordova/device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":130,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n    \n    \n    ","_children":[{"_id":131,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":132,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":133,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.device.Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":134,"tag":"source-file","attrib":{"src":"src/android/Device.java","target-dir":"src/org/apache/cordova/device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":135,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":136,"tag":"header-file","attrib":{"src":"src/ubuntu/device.h"},"text":"","tail":"\n        ","_children":[]},{"_id":137,"tag":"source-file","attrib":{"src":"src/ubuntu/device.cpp"},"text":"","tail":"\n        ","_children":[]},{"_id":138,"tag":"js-module","attrib":{"src":"src/ubuntu/device.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":139,"tag":"merges","attrib":{"target":"device"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":140,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":141,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":142,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":143,"tag":"param","attrib":{"name":"ios-package","value":"CDVDevice"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":144,"tag":"header-file","attrib":{"src":"src/ios/CDVDevice.h"},"text":"","tail":"\n        ","_children":[]},{"_id":145,"tag":"source-file","attrib":{"src":"src/ios/CDVDevice.m"},"text":"","tail":"\n    ","_children":[]}]},{"_id":146,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":147,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"Device"},"text":"","tail":"\n        ","_children":[]},{"_id":148,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n        ","_children":[{"_id":149,"tag":"feature","attrib":{"name":"Device","value":"Device"},"text":"","tail":"\n        ","_children":[]}]},{"_id":150,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget/rim:permissions"},"text":"\n            ","tail":"\n    ","_children":[{"_id":151,"tag":"rim:permit","attrib":{},"text":"read_device_identifying_information","tail":"\n        ","_children":[]}]}]},{"_id":152,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":153,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":154,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":155,"tag":"param","attrib":{"name":"wp-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":156,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":157,"tag":"Capability","attrib":{"Name":"ID_CAP_IDENTITY_DEVICE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":158,"tag":"source-file","attrib":{"src":"src/wp/Device.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":159,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":160,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":161,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":162,"tag":"param","attrib":{"name":"wp-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":163,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":164,"tag":"Capability","attrib":{"Name":"ID_CAP_IDENTITY_DEVICE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":165,"tag":"source-file","attrib":{"src":"src/wp/Device.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":166,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":167,"tag":"js-module","attrib":{"src":"src/windows/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":168,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":169,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n\n","_children":[{"_id":170,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":171,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":172,"tag":"param","attrib":{"name":"browser-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":173,"tag":"js-module","attrib":{"src":"src/browser/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":174,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-device","version":"1.0.1","name":"Device","description":"Cordova Device Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-device.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320648","keywords":["cordova","device"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-device" for ios
Install start for "cordova-plugin-device" on ios.
Iterating over installed plugins: [ 'cordova-plugin-statusbar', 'cordova-plugin-device' ]
Install complete for cordova-plugin-device on ios.
Calling plugman.fetch on plugin ".../cachedPlugins.ydveGt.tmp/cache.8yNyen.pl/cordova-plugin-splashscreen"
Copying plugin ".../cachedPlugins.ydveGt.tmp/cache.8yNyen.pl/cordova-plugin-splashscreen" => ".../Sicredi/plugins/cordova-plugin-splashscreen"
Calling plugman.install on plugin ".../Sicredi/plugins/cordova-plugin-splashscreen" for platform "ios" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.ydveGt.tmp/cache.8yNyen.pl/cordova-plugin-splashscreen":{"filepath":".../cachedPlugins.ydveGt.tmp/cache.8yNyen.pl/cordova-plugin-splashscreen/plugin.xml","dir":".../cachedPlugins.ydveGt.tmp/cache.8yNyen.pl/cordova-plugin-splashscreen","_et":{"_root":{"_id":39,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-splashscreen","version":"2.1.0"},"text":"\n    ","tail":null,"_children":[{"_id":40,"tag":"name","attrib":{},"text":"Splashscreen","tail":"\n    ","_children":[]},{"_id":41,"tag":"description","attrib":{},"text":"Cordova Splashscreen Plugin","tail":"\n    ","_children":[]},{"_id":42,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":43,"tag":"keywords","attrib":{},"text":"cordova,splashscreen","tail":"\n    ","_children":[]},{"_id":44,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-splashscreen.git","tail":"\n    ","_children":[]},{"_id":45,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320653","tail":"\n\n    ","_children":[]},{"_id":46,"tag":"engines","attrib":{},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":47,"tag":"engine","attrib":{"name":"cordova-android","version":">=3.6.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":48,"tag":"js-module","attrib":{"src":"www/splashscreen.js","name":"SplashScreen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":49,"tag":"clobbers","attrib":{"target":"navigator.splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":50,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":51,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":52,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n                ","tail":"\n        ","_children":[{"_id":53,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.splashscreen.SplashScreen"},"text":"","tail":"\n                ","_children":[]},{"_id":54,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":55,"tag":"source-file","attrib":{"src":"src/android/SplashScreen.java","target-dir":"src/org/apache/cordova/splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":56,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":57,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":58,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n            ","tail":"\n        ","_children":[{"_id":59,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.splashscreen.SplashScreen"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":60,"tag":"source-file","attrib":{"src":"src/android/SplashScreen.java","target-dir":"src/org/apache/cordova/splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":61,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":62,"tag":"header-file","attrib":{"src":"src/ubuntu/splashscreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":63,"tag":"source-file","attrib":{"src":"src/ubuntu/splashscreen.cpp"},"text":"","tail":"\n    ","_children":[]}]},{"_id":64,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":65,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n\t\t    ","tail":"\n\n        ","_children":[{"_id":66,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n\t\t\t    ","tail":"\n        ","_children":[{"_id":67,"tag":"param","attrib":{"name":"ios-package","value":"CDVSplashScreen"},"text":"","tail":"\n\t\t\t    ","_children":[]},{"_id":68,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n\t\t    ","_children":[]}]}]},{"_id":69,"tag":"header-file","attrib":{"src":"src/ios/CDVSplashScreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":70,"tag":"source-file","attrib":{"src":"src/ios/CDVSplashScreen.m"},"text":"","tail":"\n        ","_children":[]},{"_id":71,"tag":"header-file","attrib":{"src":"src/ios/CDVViewController+SplashScreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":72,"tag":"source-file","attrib":{"src":"src/ios/CDVViewController+SplashScreen.m"},"text":"","tail":"\n\n\t    ","_children":[]},{"_id":73,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\n    ","_children":[]}]},{"_id":74,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":75,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"SplashScreen"},"text":"","tail":"\n        ","_children":[]},{"_id":76,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n    ","_children":[{"_id":77,"tag":"feature","attrib":{"name":"SplashScreen","value":"SplashScreen"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":78,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":79,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":80,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n                ","tail":"\n        ","_children":[{"_id":81,"tag":"param","attrib":{"name":"wp-package","value":"SplashScreen"},"text":"","tail":"\n                ","_children":[]},{"_id":82,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":83,"tag":"source-file","attrib":{"src":"src/wp/SplashScreen.cs"},"text":"","tail":"\n        ","_children":[]},{"_id":84,"tag":"source-file","attrib":{"src":"src/wp/ResolutionHelper.cs"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":85,"tag":"platform","attrib":{"name":"windows8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":86,"tag":"js-module","attrib":{"src":"www/windows/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":87,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":88,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":89,"tag":"js-module","attrib":{"src":"www/windows/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":90,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":91,"tag":"platform","attrib":{"name":"tizen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":92,"tag":"js-module","attrib":{"src":"src/tizen/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":93,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":94,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n","_children":[{"_id":95,"tag":"js-module","attrib":{"src":"src/browser/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":96,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-splashscreen","version":"2.1.0","name":"Splashscreen","description":"Cordova Splashscreen Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-splashscreen.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320653","keywords":["cordova","splashscreen"]},".../Sicredi/plugins/cordova-plugin-splashscreen":{"filepath":".../Sicredi/plugins/cordova-plugin-splashscreen/plugin.xml","dir":".../Sicredi/plugins/cordova-plugin-splashscreen","_et":{"_root":{"_id":97,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-splashscreen","version":"2.1.0"},"text":"\n    ","tail":null,"_children":[{"_id":98,"tag":"name","attrib":{},"text":"Splashscreen","tail":"\n    ","_children":[]},{"_id":99,"tag":"description","attrib":{},"text":"Cordova Splashscreen Plugin","tail":"\n    ","_children":[]},{"_id":100,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":101,"tag":"keywords","attrib":{},"text":"cordova,splashscreen","tail":"\n    ","_children":[]},{"_id":102,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-splashscreen.git","tail":"\n    ","_children":[]},{"_id":103,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320653","tail":"\n\n    ","_children":[]},{"_id":104,"tag":"engines","attrib":{},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":105,"tag":"engine","attrib":{"name":"cordova-android","version":">=3.6.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":106,"tag":"js-module","attrib":{"src":"www/splashscreen.js","name":"SplashScreen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":107,"tag":"clobbers","attrib":{"target":"navigator.splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":108,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":109,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":110,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n                ","tail":"\n        ","_children":[{"_id":111,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.splashscreen.SplashScreen"},"text":"","tail":"\n                ","_children":[]},{"_id":112,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":113,"tag":"source-file","attrib":{"src":"src/android/SplashScreen.java","target-dir":"src/org/apache/cordova/splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":114,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":115,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":116,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n            ","tail":"\n        ","_children":[{"_id":117,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.splashscreen.SplashScreen"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":118,"tag":"source-file","attrib":{"src":"src/android/SplashScreen.java","target-dir":"src/org/apache/cordova/splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":119,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":120,"tag":"header-file","attrib":{"src":"src/ubuntu/splashscreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":121,"tag":"source-file","attrib":{"src":"src/ubuntu/splashscreen.cpp"},"text":"","tail":"\n    ","_children":[]}]},{"_id":122,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":123,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n\t\t    ","tail":"\n\n        ","_children":[{"_id":124,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n\t\t\t    ","tail":"\n        ","_children":[{"_id":125,"tag":"param","attrib":{"name":"ios-package","value":"CDVSplashScreen"},"text":"","tail":"\n\t\t\t    ","_children":[]},{"_id":126,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n\t\t    ","_children":[]}]}]},{"_id":127,"tag":"header-file","attrib":{"src":"src/ios/CDVSplashScreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":128,"tag":"source-file","attrib":{"src":"src/ios/CDVSplashScreen.m"},"text":"","tail":"\n        ","_children":[]},{"_id":129,"tag":"header-file","attrib":{"src":"src/ios/CDVViewController+SplashScreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":130,"tag":"source-file","attrib":{"src":"src/ios/CDVViewController+SplashScreen.m"},"text":"","tail":"\n\n\t    ","_children":[]},{"_id":131,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\n    ","_children":[]}]},{"_id":132,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":133,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"SplashScreen"},"text":"","tail":"\n        ","_children":[]},{"_id":134,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n    ","_children":[{"_id":135,"tag":"feature","attrib":{"name":"SplashScreen","value":"SplashScreen"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":136,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":137,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":138,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n                ","tail":"\n        ","_children":[{"_id":139,"tag":"param","attrib":{"name":"wp-package","value":"SplashScreen"},"text":"","tail":"\n                ","_children":[]},{"_id":140,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":141,"tag":"source-file","attrib":{"src":"src/wp/SplashScreen.cs"},"text":"","tail":"\n        ","_children":[]},{"_id":142,"tag":"source-file","attrib":{"src":"src/wp/ResolutionHelper.cs"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":143,"tag":"platform","attrib":{"name":"windows8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":144,"tag":"js-module","attrib":{"src":"www/windows/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":145,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":146,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":147,"tag":"js-module","attrib":{"src":"www/windows/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":148,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":149,"tag":"platform","attrib":{"name":"tizen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":150,"tag":"js-module","attrib":{"src":"src/tizen/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":151,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":152,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n","_children":[{"_id":153,"tag":"js-module","attrib":{"src":"src/browser/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":154,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-splashscreen","version":"2.1.0","name":"Splashscreen","description":"Cordova Splashscreen Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-splashscreen.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320653","keywords":["cordova","splashscreen"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-splashscreen" for ios
Install start for "cordova-plugin-splashscreen" on ios.
  'cordova-plugin-device',
  'cordova-plugin-splashscreen' ]
Install complete for cordova-plugin-splashscreen on ios.
Generating config.xml from defaults for platform "ios"
Calling plugman.prepare for platform "ios"
Wrote out iOS Bundle Identifier to "br.com.dijex.appmetas"
Wrote out iOS Bundle Version to "1.0.1"
Copying icon from .../Sicredi/www/images/icones---metas-60x.png to .../Sicredi/platforms/ios/Sicredi/Resources/icons/icon-60.png
Copying icon from .../Sicredi/www/images/icones---metas-120x.png to .../Sicredi/platforms/ios/Sicredi/Resources/icons/icon-60@2x.png
Copying icon from .../Sicredi/www/images/icones---metas-180x.png to .../Sicredi/platforms/ios/Sicredi/Resources/icons/icon-60@3x.png
Copying icon from .../Sicredi/www/images/icones---metas-76x.png to .../Sicredi/platforms/ios/Sicredi/Resources/icons/icon-76.png
Copying icon from .../Sicredi/www/images/icones---metas-152x.png to .../Sicredi/platforms/ios/Sicredi/Resources/icons/icon-76@2x.png
Copying splash from .../Sicredi/www/images/imgs/Sicredi--320x480px.png to .../Sicredi/platforms/ios/Sicredi/Resources/splash/Default~iphone.png
Copying splash from .../Sicredi/www/images/imgs/Sicredi--640x960px.png to .../Sicredi/platforms/ios/Sicredi/Resources/splash/Default@2x~iphone.png
Copying splash from .../Sicredi/www/images/imgs/Sicredi---768x1024px.png to .../Sicredi/platforms/ios/Sicredi/Resources/splash/Default-Portrait~ipad.png
Copying splash from .../Sicredi/www/images/imgs/Sicredi--1536x2048px.png to .../Sicredi/platforms/ios/Sicredi/Resources/splash/Default-Portrait@2x~ipad.png
Copying splash from .../Sicredi/www/images/imgs/Sicredi--640x1136px.png to .../Sicredi/platforms/ios/Sicredi/Resources/splash/Default-568h@2x~iphone.png
Copying splash from .../Sicredi/www/images/imgs/Sicredi--750x1334px.png to .../Sicredi/platforms/ios/Sicredi/Resources/splash/Default-667h.png
Copying splash from .../Sicredi/www/images/imgs/Sicredi--1242x2208px.png to .../Sicredi/platforms/ios/Sicredi/Resources/splash/Default-736h.png
Wrote out iOS Product Name and updated XCode project file names from "Sicredi" to "Sicredi App Metas".
************* Processing the main config.xml file (after_prepare)  *****************
App Directory = [.../Sicredi]
Will process and update the following config files:
    Config.xml = [.../Sicredi/config.xml]
Namespaces:
    prefix/uri ''/'http://www.w3.org/ns/widgets'
    prefix/uri 'intelxdk'/'http://xdk.intel.com/ns/v1'
Name of the app is [Sicredi App Metas]
Updating full app name to [Sicredi App Metas]
Processing preference permissions
Updating the versionName
Setting [CFBundleShortVersionString] to 1.0.1
Processing debuggable
Processing config file values
Saving config.xml to [.../Sicredi/config.xml]
Saving info.plist to [.../Sicredi/platforms/ios/Sicredi App Metas/Sicredi App Metas-Info.plist]
************* Completed processing the main config.xml file (after_prepare)  *****************
Running command: .../Sicredi/platforms/ios/cordova/build --release --device
Building project  : .../Sicredi/platforms/ios/Sicredi App Metas.xcodeproj
	Configuration : Release
	Platform      : device
Build settings from command line:
    ARCHS = armv7 armv7s arm64
    CONFIGURATION_BUILD_DIR = .../Sicredi/platforms/ios/build/device
    SDKROOT = iphoneos8.0
    SHARED_PRECOMPS_DIR = .../Sicredi/platforms/ios/build/sharedpch
    VALID_ARCHS = armv7 armv7s arm64
Build settings from configuration file '.../Sicredi/platforms/ios/cordova/build-release.xcconfig':
    CODE_SIGN_IDENTITY = iPhone Distribution
    IPHONEOS_DEPLOYMENT_TARGET = 6
    PROVISIONING_PROFILE = 9d84ddf0-3837-404c-9a70-7412052f67cf
=== BUILD TARGET CordovaLib OF PROJECT CordovaLib WITH CONFIGURATION Release ===
Check dependencies
Write auxiliary files
/bin/mkdir -p .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build
write-file .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap
/bin/mkdir -p .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas
write-file .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch.pch.hash-criteria
write-file .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap
/bin/mkdir -p .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci
write-file .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch.pch.hash-criteria
/bin/mkdir -p .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr
write-file .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch.pch.hash-criteria
/bin/mkdir -p .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64
write-file .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/Cordova.LinkFileList
/bin/mkdir -p .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7
write-file .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/Cordova.LinkFileList
write-file .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap
write-file .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova.hmap
/bin/mkdir -p .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s
write-file .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/Cordova.LinkFileList
write-file .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-non-framework-target-headers.hmap
write-file .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap
CpHeader Classes/NSDictionary+Extensions.h .../Sicredi/platforms/ios/build/device/include/Cordova/NSDictionary+Extensions.h
    cd .../Sicredi/platforms/ios/CordovaLib
    export PATH="/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin:/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/local/git/bin:/Developer/android-sdk-macosx/tools:/usr/local/ant/bin"
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/NSDictionary+Extensions.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVPlugin.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDVPlugin.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDVPlugin.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVInvokedUrlCommand.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDVInvokedUrlCommand.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDVInvokedUrlCommand.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVPluginResult.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDVPluginResult.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDVPluginResult.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVDebug.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDVDebug.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDVDebug.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/NSData+Base64.h .../Sicredi/platforms/ios/build/device/include/Cordova/NSData+Base64.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/NSData+Base64.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/NSMutableArray+QueueAdditions.h .../Sicredi/platforms/ios/build/device/include/Cordova/NSMutableArray+QueueAdditions.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/NSMutableArray+QueueAdditions.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVWhitelist.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDVWhitelist.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDVWhitelist.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVViewController.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDVViewController.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDVViewController.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVCommandDelegate.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDVCommandDelegate.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDVCommandDelegate.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDV.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDV.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDV.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVURLProtocol.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDVURLProtocol.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDVURLProtocol.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVAvailability.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDVAvailability.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDVAvailability.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVAvailabilityDeprecated.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDVAvailabilityDeprecated.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDVAvailabilityDeprecated.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVLocalStorage.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDVLocalStorage.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDVLocalStorage.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVCommandQueue.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDVCommandQueue.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDVCommandQueue.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/NSArray+Comparisons.h .../Sicredi/platforms/ios/build/device/include/Cordova/NSArray+Comparisons.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/NSArray+Comparisons.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/UIDevice+Extensions.h .../Sicredi/platforms/ios/build/device/include/Cordova/UIDevice+Extensions.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/UIDevice+Extensions.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVCommandDelegateImpl.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDVCommandDelegateImpl.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDVCommandDelegateImpl.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVShared.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDVShared.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDVShared.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVUserAgentUtil.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDVUserAgentUtil.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDVUserAgentUtil.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVScreenOrientationDelegate.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDVScreenOrientationDelegate.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDVScreenOrientationDelegate.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVConfigParser.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDVConfigParser.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDVConfigParser.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVJSON.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDVJSON.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDVJSON.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVWebViewDelegate.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDVWebViewDelegate.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDVWebViewDelegate.h .../Sicredi/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVTimer.h .../Sicredi/platforms/ios/build/device/include/Cordova/CDVTimer.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../Sicredi/platforms/ios/CordovaLib/Classes/CDVTimer.h .../Sicredi/platforms/ios/build/device/include/Cordova
ProcessPCH .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch.pch CordovaLib_Prefix.pch normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    export LANG=en_US.US-ASCII
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c-header -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -MD -MT dependencies -MF .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch.d -c .../Sicredi/platforms/ios/CordovaLib/CordovaLib_Prefix.pch -o .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch.pch --serialize-diagnostics .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch.dia
ProcessPCH .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch.pch CordovaLib_Prefix.pch normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c-header -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -MD -MT dependencies -MF .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch.d -c .../Sicredi/platforms/ios/CordovaLib/CordovaLib_Prefix.pch -o .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch.pch --serialize-diagnostics .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch.dia
ProcessPCH .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch.pch CordovaLib_Prefix.pch normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c-header -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -MD -MT dependencies -MF .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch.d -c .../Sicredi/platforms/ios/CordovaLib/CordovaLib_Prefix.pch -o .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch.pch --serialize-diagnostics .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch.dia
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.o Classes/CDVInvokedUrlCommand.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVInvokedUrlCommand.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+Extensions.o Classes/NSDictionary+Extensions.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+Extensions.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+Extensions.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/NSDictionary+Extensions.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+Extensions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSData+Base64.o Classes/NSData+Base64.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSData+Base64.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSData+Base64.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/NSData+Base64.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSData+Base64.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.o Classes/CDVPluginResult.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVPluginResult.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.o Classes/CDVPlugin.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVPlugin.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.o Classes/NSMutableArray+QueueAdditions.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/NSMutableArray+QueueAdditions.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.o Classes/CDVWhitelist.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVWhitelist.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.o Classes/CDVURLProtocol.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVURLProtocol.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.o Classes/CDVViewController.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVViewController.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.o Classes/CDVLocalStorage.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVLocalStorage.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSArray+Comparisons.o Classes/NSArray+Comparisons.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSArray+Comparisons.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSArray+Comparisons.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/NSArray+Comparisons.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSArray+Comparisons.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/UIDevice+Extensions.o Classes/UIDevice+Extensions.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/UIDevice+Extensions.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/UIDevice+Extensions.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/UIDevice+Extensions.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/UIDevice+Extensions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.o Classes/CDVCommandQueue.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVCommandQueue.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.o Classes/CDVJSON_private.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVJSON_private.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.o Classes/CDVCommandDelegateImpl.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    cd .../Sicredi/platforms/ios/CordovaLib
    export PATH="/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin:/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/local/git/bin:/Developer/android-sdk-macosx/tools:/usr/local/ant/bin"
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVCommandDelegateImpl.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.o Classes/CDVConfigParser.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVConfigParser.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON.o Classes/CDVJSON.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVJSON.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.o Classes/CDVUserAgentUtil.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVUserAgentUtil.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.o Classes/CDVHandleOpenURL.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    export LANG=en_US.US-ASCII
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVHandleOpenURL.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWebViewDelegate.o Classes/CDVWebViewDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWebViewDelegate.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWebViewDelegate.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVWebViewDelegate.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWebViewDelegate.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.o Classes/CDVTimer.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-gzkoceigpjvozcfgtbsyepujpvas/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVTimer.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSDictionary+Extensions.o Classes/NSDictionary+Extensions.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSDictionary+Extensions.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSDictionary+Extensions.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/NSDictionary+Extensions.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSDictionary+Extensions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVInvokedUrlCommand.o Classes/CDVInvokedUrlCommand.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVInvokedUrlCommand.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVInvokedUrlCommand.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVInvokedUrlCommand.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVInvokedUrlCommand.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSData+Base64.o Classes/NSData+Base64.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSData+Base64.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSData+Base64.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/NSData+Base64.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSData+Base64.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPluginResult.o Classes/CDVPluginResult.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPluginResult.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPluginResult.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVPluginResult.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPluginResult.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPlugin.o Classes/CDVPlugin.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPlugin.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPlugin.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVPlugin.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPlugin.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSMutableArray+QueueAdditions.o Classes/NSMutableArray+QueueAdditions.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSMutableArray+QueueAdditions.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSMutableArray+QueueAdditions.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/NSMutableArray+QueueAdditions.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSMutableArray+QueueAdditions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWhitelist.o Classes/CDVWhitelist.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWhitelist.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWhitelist.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVWhitelist.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWhitelist.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVURLProtocol.o Classes/CDVURLProtocol.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVURLProtocol.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVURLProtocol.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVURLProtocol.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVURLProtocol.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVViewController.o Classes/CDVViewController.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVViewController.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVViewController.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVViewController.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVViewController.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVLocalStorage.o Classes/CDVLocalStorage.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVLocalStorage.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVLocalStorage.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVLocalStorage.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVLocalStorage.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/UIDevice+Extensions.o Classes/UIDevice+Extensions.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/UIDevice+Extensions.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/UIDevice+Extensions.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/UIDevice+Extensions.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/UIDevice+Extensions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSArray+Comparisons.o Classes/NSArray+Comparisons.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSArray+Comparisons.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSArray+Comparisons.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/NSArray+Comparisons.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSArray+Comparisons.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandQueue.o Classes/CDVCommandQueue.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandQueue.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandQueue.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVCommandQueue.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandQueue.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVJSON_private.o Classes/CDVJSON_private.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVJSON_private.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVJSON_private.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVJSON_private.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVJSON_private.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandDelegateImpl.o Classes/CDVCommandDelegateImpl.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    cd .../Sicredi/platforms/ios/CordovaLib
    export PATH="/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin:/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/local/git/bin:/Developer/android-sdk-macosx/tools:/usr/local/ant/bin"
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandDelegateImpl.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandDelegateImpl.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVCommandDelegateImpl.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandDelegateImpl.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVConfigParser.o Classes/CDVConfigParser.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVConfigParser.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVConfigParser.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVConfigParser.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVConfigParser.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVJSON.o Classes/CDVJSON.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVJSON.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVJSON.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVJSON.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVJSON.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVUserAgentUtil.o Classes/CDVUserAgentUtil.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVUserAgentUtil.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVUserAgentUtil.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVUserAgentUtil.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVUserAgentUtil.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVHandleOpenURL.o Classes/CDVHandleOpenURL.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    export LANG=en_US.US-ASCII
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVHandleOpenURL.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVHandleOpenURL.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVHandleOpenURL.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVHandleOpenURL.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWebViewDelegate.o Classes/CDVWebViewDelegate.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWebViewDelegate.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWebViewDelegate.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVWebViewDelegate.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWebViewDelegate.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVTimer.o Classes/CDVTimer.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-djsaxyrdljoqrvcdnnszpkrjckci/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVTimer.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVTimer.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVTimer.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVTimer.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+Extensions.o Classes/NSDictionary+Extensions.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+Extensions.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+Extensions.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/NSDictionary+Extensions.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+Extensions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.o Classes/CDVInvokedUrlCommand.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVInvokedUrlCommand.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSData+Base64.o Classes/NSData+Base64.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSData+Base64.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSData+Base64.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/NSData+Base64.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSData+Base64.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.o Classes/CDVPluginResult.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVPluginResult.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.o Classes/CDVPlugin.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVPlugin.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.o Classes/NSMutableArray+QueueAdditions.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/NSMutableArray+QueueAdditions.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.o Classes/CDVWhitelist.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVWhitelist.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.o Classes/CDVURLProtocol.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVURLProtocol.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.o Classes/CDVViewController.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVViewController.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.o Classes/CDVLocalStorage.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVLocalStorage.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/UIDevice+Extensions.o Classes/UIDevice+Extensions.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/UIDevice+Extensions.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/UIDevice+Extensions.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/UIDevice+Extensions.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/UIDevice+Extensions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSArray+Comparisons.o Classes/NSArray+Comparisons.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSArray+Comparisons.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSArray+Comparisons.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/NSArray+Comparisons.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSArray+Comparisons.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.o Classes/CDVCommandQueue.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVCommandQueue.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.o Classes/CDVJSON_private.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVJSON_private.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.o Classes/CDVCommandDelegateImpl.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    cd .../Sicredi/platforms/ios/CordovaLib
    export PATH="/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin:/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/local/git/bin:/Developer/android-sdk-macosx/tools:/usr/local/ant/bin"
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVCommandDelegateImpl.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.o Classes/CDVConfigParser.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVConfigParser.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON.o Classes/CDVJSON.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVJSON.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.o Classes/CDVUserAgentUtil.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVUserAgentUtil.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.o Classes/CDVHandleOpenURL.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    export LANG=en_US.US-ASCII
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVHandleOpenURL.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWebViewDelegate.o Classes/CDVWebViewDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWebViewDelegate.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWebViewDelegate.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVWebViewDelegate.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWebViewDelegate.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.o Classes/CDVTimer.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/CordovaLib_Prefix-fgmvryohjzrenzfoevgfkmqxlusr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.d --serialize-diagnostics .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.dia -c .../Sicredi/platforms/ios/CordovaLib/Classes/CDVTimer.m -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.o
Libtool build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a normal arm64
    export IPHONEOS_DEPLOYMENT_TARGET=6
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/libtool -static -arch_only arm64 -syslibroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -L.../Sicredi/platforms/ios/build/device -filelist .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/Cordova.LinkFileList -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a
Libtool build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a normal armv7
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/libtool -static -arch_only armv7 -syslibroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -L.../Sicredi/platforms/ios/build/device -filelist .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/Cordova.LinkFileList -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a
Libtool build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/libCordova.a normal armv7s
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/libtool -static -arch_only armv7s -syslibroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -L.../Sicredi/platforms/ios/build/device -filelist .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/Cordova.LinkFileList -o .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/libCordova.a
CreateUniversalBinary .../Sicredi/platforms/ios/build/device/libCordova.a normal armv7\ armv7s\ arm64
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/libtool -static .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/libCordova.a .../Sicredi/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a -o .../Sicredi/platforms/ios/build/device/libCordova.a
=== BUILD TARGET Sicredi App Metas OF PROJECT Sicredi App Metas WITH CONFIGURATION Release ===
Check dependencies
Write auxiliary files
/bin/mkdir -p .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s
write-file .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/Sicredi\ App\ Metas\ App\ Metas.LinkFileList
/bin/mkdir -p .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64
write-file .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/Sicredi\ App\ Metas\ App\ Metas.LinkFileList
write-file .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/Sicredi\ App\ Metas\ App\ Metas.LinkFileList
/bin/mkdir -p .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-fvnxnzxmrylfgkbxqkdoeqrxzlxq
write-file .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-fvnxnzxmrylfgkbxqkdoeqrxzlxq/Sicredi\ App\ Metas-Prefix.pch.pch.hash-criteria
/bin/mkdir -p .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-blivkolxpdfgzacwrucbzdzjvqbj
write-file .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-blivkolxpdfgzacwrucbzdzjvqbj/Sicredi\ App\ Metas-Prefix.pch.pch.hash-criteria
/bin/mkdir -p .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-guzqcomaptyzfcckihmtokdzexsk
write-file .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-guzqcomaptyzfcckihmtokdzexsk/Sicredi\ App\ Metas-Prefix.pch.pch.hash-criteria
write-file .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Script-304B58A110DAC018002A0835.sh
chmod 0755 .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Script-304B58A110DAC018002A0835.sh
write-file .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap
write-file .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-non-framework-target-headers.hmap
write-file .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap
write-file .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap
write-file .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas.hmap
write-file .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap
Create product structure
/bin/mkdir -p .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app
CpResource /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk/ResourceRules.plist build/device/Sicredi\ App\ Metas\ App\ Metas.app/ResourceRules.plist
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk/ResourceRules.plist .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app
PhaseScriptExecution Copy\ www\ directory build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Script-304B58A110DAC018002A0835.sh
    /bin/sh -c \".../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Script-304B58A110DAC018002A0835.sh\"
real	0m0.735s
user	0m0.300s
sys	0m0.432s
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-76.png Sicredi\ App\ Metas/Resources/icons/icon-76.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/icons/icon-76.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-76.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-72.png Sicredi\ App\ Metas/Resources/icons/icon-72.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/icons/icon-72.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-72.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-40@2x.png Sicredi\ App\ Metas/Resources/icons/icon-40@2x.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/icons/icon-40@2x.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-40@2x.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/Default-736h.png Sicredi\ App\ Metas/Resources/splash/Default-736h.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/splash/Default-736h.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/Default-736h.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon.png Sicredi\ App\ Metas/Resources/icons/icon.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/icons/icon.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon@2x.png Sicredi\ App\ Metas/Resources/icons/icon@2x.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/icons/icon@2x.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon@2x.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-50.png Sicredi\ App\ Metas/Resources/icons/icon-50.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/icons/icon-50.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-50.png
CompileXIB Sicredi\ App\ Metas/Classes/MainViewController.xib
    export XCODE_DEVELOPER_USR_PATH=/Applications/Xcode.app/Contents/Developer/usr/bin/..
    /Applications/Xcode.app/Contents/Developer/usr/bin/ibtool --target-device iphone --target-device ipad --errors --warnings --notices --module Sicredi_App_Metas_App_Metas --minimum-deployment-target 6 --output-partial-info-plist .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/MainViewController-PartialInfo.plist --auto-activate-custom-fonts --output-format human-readable-text --compile .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/MainViewController.nib .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Classes/MainViewController.xib
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-60@2x.png Sicredi\ App\ Metas/Resources/icons/icon-60@2x.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/icons/icon-60@2x.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-60@2x.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-small.png Sicredi\ App\ Metas/Resources/icons/icon-small.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/icons/icon-small.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-small.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/Default-Landscape@2x~ipad.png Sicredi\ App\ Metas/Resources/splash/Default-Landscape@2x~ipad.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/splash/Default-Landscape@2x~ipad.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/Default-Landscape@2x~ipad.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/Default-Portrait@2x~ipad.png Sicredi\ App\ Metas/Resources/splash/Default-Portrait@2x~ipad.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/splash/Default-Portrait@2x~ipad.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/Default-Portrait@2x~ipad.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/Default-Landscape~ipad.png Sicredi\ App\ Metas/Resources/splash/Default-Landscape~ipad.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/splash/Default-Landscape~ipad.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/Default-Landscape~ipad.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-small@2x.png Sicredi\ App\ Metas/Resources/icons/icon-small@2x.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/icons/icon-small@2x.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-small@2x.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/Default-Portrait~ipad.png Sicredi\ App\ Metas/Resources/splash/Default-Portrait~ipad.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/splash/Default-Portrait~ipad.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/Default-Portrait~ipad.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/Default-667h.png Sicredi\ App\ Metas/Resources/splash/Default-667h.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/splash/Default-667h.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/Default-667h.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-40.png Sicredi\ App\ Metas/Resources/icons/icon-40.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/icons/icon-40.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-40.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/Default@2x~iphone.png Sicredi\ App\ Metas/Resources/splash/Default@2x~iphone.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/splash/Default@2x~iphone.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/Default@2x~iphone.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-60.png Sicredi\ App\ Metas/Resources/icons/icon-60.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/icons/icon-60.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-60.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/Default~iphone.png Sicredi\ App\ Metas/Resources/splash/Default~iphone.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/splash/Default~iphone.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/Default~iphone.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/Default-568h@2x~iphone.png Sicredi\ App\ Metas/Resources/splash/Default-568h@2x~iphone.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/splash/Default-568h@2x~iphone.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/Default-568h@2x~iphone.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/Default-Landscape-736h.png Sicredi\ App\ Metas/Resources/splash/Default-Landscape-736h.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/splash/Default-Landscape-736h.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/Default-Landscape-736h.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-60@3x.png Sicredi\ App\ Metas/Resources/icons/icon-60@3x.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/icons/icon-60@3x.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-60@3x.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-50@2x.png Sicredi\ App\ Metas/Resources/icons/icon-50@2x.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/icons/icon-50@2x.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-50@2x.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-76@2x.png Sicredi\ App\ Metas/Resources/icons/icon-76@2x.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/icons/icon-76@2x.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-76@2x.png
CopyPNGFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-72@2x.png Sicredi\ App\ Metas/Resources/icons/icon-72@2x.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Resources/icons/icon-72@2x.png .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/icon-72@2x.png
ProcessInfoPlistFile build/device/Sicredi\ App\ Metas\ App\ Metas.app/Info.plist Sicredi\ App\ Metas/Sicredi\ App\ Metas-Info.plist
    builtin-infoPlistUtility .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Sicredi\ App\ Metas-Info.plist -genpkginfo .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/PkgInfo -expandbuildsettings -format binary -platform iphoneos -resourcerulesfile .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/ResourceRules.plist -additionalcontentfile .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/MainViewController-PartialInfo.plist -o .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/Info.plist
ProcessPCH build/sharedpch/Sicredi\ App\ Metas-Prefix-blivkolxpdfgzacwrucbzdzjvqbj/Sicredi\ App\ Metas-Prefix.pch.pch Sicredi\ App\ Metas/Sicredi\ App\ Metas-Prefix.pch normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c-header -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -MD -MT dependencies -MF .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-blivkolxpdfgzacwrucbzdzjvqbj/Sicredi\ App\ Metas-Prefix.pch.d -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Sicredi\ App\ Metas-Prefix.pch -o .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-blivkolxpdfgzacwrucbzdzjvqbj/Sicredi\ App\ Metas-Prefix.pch.pch --serialize-diagnostics .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-blivkolxpdfgzacwrucbzdzjvqbj/Sicredi\ App\ Metas-Prefix.pch.dia
ProcessPCH build/sharedpch/Sicredi\ App\ Metas-Prefix-guzqcomaptyzfcckihmtokdzexsk/Sicredi\ App\ Metas-Prefix.pch.pch Sicredi\ App\ Metas/Sicredi\ App\ Metas-Prefix.pch normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c-header -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -MD -MT dependencies -MF .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-guzqcomaptyzfcckihmtokdzexsk/Sicredi\ App\ Metas-Prefix.pch.d -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Sicredi\ App\ Metas-Prefix.pch -o .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-guzqcomaptyzfcckihmtokdzexsk/Sicredi\ App\ Metas-Prefix.pch.pch --serialize-diagnostics .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-guzqcomaptyzfcckihmtokdzexsk/Sicredi\ App\ Metas-Prefix.pch.dia
ProcessPCH build/sharedpch/Sicredi\ App\ Metas-Prefix-fvnxnzxmrylfgkbxqkdoeqrxzlxq/Sicredi\ App\ Metas-Prefix.pch.pch Sicredi\ App\ Metas/Sicredi\ App\ Metas-Prefix.pch normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c-header -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -MD -MT dependencies -MF .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-fvnxnzxmrylfgkbxqkdoeqrxzlxq/Sicredi\ App\ Metas-Prefix.pch.d -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Sicredi\ App\ Metas-Prefix.pch -o .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-fvnxnzxmrylfgkbxqkdoeqrxzlxq/Sicredi\ App\ Metas-Prefix.pch.pch --serialize-diagnostics .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-fvnxnzxmrylfgkbxqkdoeqrxzlxq/Sicredi\ App\ Metas-Prefix.pch.dia
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/AppDelegate.o Sicredi\ App\ Metas/Classes/AppDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-blivkolxpdfgzacwrucbzdzjvqbj/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/AppDelegate.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/AppDelegate.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Classes/AppDelegate.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/AppDelegate.o
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/main.o Sicredi\ App\ Metas/main.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-blivkolxpdfgzacwrucbzdzjvqbj/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/main.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/main.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/main.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/main.o
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/MainViewController.o Sicredi\ App\ Metas/Classes/MainViewController.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-blivkolxpdfgzacwrucbzdzjvqbj/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/MainViewController.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/MainViewController.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Classes/MainViewController.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/MainViewController.o
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/CDVStatusBar.o Sicredi\ App\ Metas/Plugins/cordova-plugin-statusbar/CDVStatusBar.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-blivkolxpdfgzacwrucbzdzjvqbj/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/CDVStatusBar.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/CDVStatusBar.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Plugins/cordova-plugin-statusbar/CDVStatusBar.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/CDVStatusBar.o
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/CDVDevice.o Sicredi\ App\ Metas/Plugins/cordova-plugin-device/CDVDevice.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    cd .../Sicredi/platforms/ios
    export PATH="/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin:/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/local/git/bin:/Developer/android-sdk-macosx/tools:/usr/local/ant/bin"
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-blivkolxpdfgzacwrucbzdzjvqbj/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/CDVDevice.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/CDVDevice.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Plugins/cordova-plugin-device/CDVDevice.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/CDVDevice.o
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/CDVSplashScreen.o Sicredi\ App\ Metas/Plugins/cordova-plugin-splashscreen/CDVSplashScreen.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-blivkolxpdfgzacwrucbzdzjvqbj/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/CDVSplashScreen.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/CDVSplashScreen.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Plugins/cordova-plugin-splashscreen/CDVSplashScreen.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/CDVSplashScreen.o
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/CDVViewController+SplashScreen.o Sicredi\ App\ Metas/Plugins/cordova-plugin-splashscreen/CDVViewController+SplashScreen.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/armv7 -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-blivkolxpdfgzacwrucbzdzjvqbj/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/CDVViewController+SplashScreen.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/CDVViewController+SplashScreen.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Plugins/cordova-plugin-splashscreen/CDVViewController+SplashScreen.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/CDVViewController+SplashScreen.o
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/main.o Sicredi\ App\ Metas/main.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-guzqcomaptyzfcckihmtokdzexsk/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/main.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/main.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/main.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/main.o
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/AppDelegate.o Sicredi\ App\ Metas/Classes/AppDelegate.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    export LANG=en_US.US-ASCII
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-guzqcomaptyzfcckihmtokdzexsk/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/AppDelegate.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/AppDelegate.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Classes/AppDelegate.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/AppDelegate.o
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/MainViewController.o Sicredi\ App\ Metas/Classes/MainViewController.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-guzqcomaptyzfcckihmtokdzexsk/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/MainViewController.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/MainViewController.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Classes/MainViewController.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/MainViewController.o
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/CDVStatusBar.o Sicredi\ App\ Metas/Plugins/cordova-plugin-statusbar/CDVStatusBar.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-guzqcomaptyzfcckihmtokdzexsk/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/CDVStatusBar.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/CDVStatusBar.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Plugins/cordova-plugin-statusbar/CDVStatusBar.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/CDVStatusBar.o
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/CDVDevice.o Sicredi\ App\ Metas/Plugins/cordova-plugin-device/CDVDevice.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-guzqcomaptyzfcckihmtokdzexsk/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/CDVDevice.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/CDVDevice.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Plugins/cordova-plugin-device/CDVDevice.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/CDVDevice.o
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/CDVSplashScreen.o Sicredi\ App\ Metas/Plugins/cordova-plugin-splashscreen/CDVSplashScreen.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-guzqcomaptyzfcckihmtokdzexsk/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/CDVSplashScreen.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/CDVSplashScreen.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Plugins/cordova-plugin-splashscreen/CDVSplashScreen.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/CDVSplashScreen.o
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/CDVViewController+SplashScreen.o Sicredi\ App\ Metas/Plugins/cordova-plugin-splashscreen/CDVViewController+SplashScreen.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/armv7s -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-guzqcomaptyzfcckihmtokdzexsk/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/CDVViewController+SplashScreen.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/CDVViewController+SplashScreen.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Plugins/cordova-plugin-splashscreen/CDVViewController+SplashScreen.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/CDVViewController+SplashScreen.o
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/main.o Sicredi\ App\ Metas/main.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-fvnxnzxmrylfgkbxqkdoeqrxzlxq/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/main.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/main.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/main.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/main.o
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/AppDelegate.o Sicredi\ App\ Metas/Classes/AppDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-fvnxnzxmrylfgkbxqkdoeqrxzlxq/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/AppDelegate.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/AppDelegate.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Classes/AppDelegate.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/AppDelegate.o
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/MainViewController.o Sicredi\ App\ Metas/Classes/MainViewController.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-fvnxnzxmrylfgkbxqkdoeqrxzlxq/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/MainViewController.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/MainViewController.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Classes/MainViewController.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/MainViewController.o
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/CDVStatusBar.o Sicredi\ App\ Metas/Plugins/cordova-plugin-statusbar/CDVStatusBar.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-fvnxnzxmrylfgkbxqkdoeqrxzlxq/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/CDVStatusBar.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/CDVStatusBar.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Plugins/cordova-plugin-statusbar/CDVStatusBar.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/CDVStatusBar.o
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/CDVDevice.o Sicredi\ App\ Metas/Plugins/cordova-plugin-device/CDVDevice.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-fvnxnzxmrylfgkbxqkdoeqrxzlxq/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/CDVDevice.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/CDVDevice.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Plugins/cordova-plugin-device/CDVDevice.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/CDVDevice.o
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/CDVSplashScreen.o Sicredi\ App\ Metas/Plugins/cordova-plugin-splashscreen/CDVSplashScreen.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-fvnxnzxmrylfgkbxqkdoeqrxzlxq/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/CDVSplashScreen.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/CDVSplashScreen.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Plugins/cordova-plugin-splashscreen/CDVSplashScreen.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/CDVSplashScreen.o
CompileC build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/CDVViewController+SplashScreen.o Sicredi\ App\ Metas/Plugins/cordova-plugin-splashscreen/CDVViewController+SplashScreen.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-generated-files.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-own-target-headers.hmap -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-all-target-headers.hmap -iquote .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas-project-headers.hmap -I.../Sicredi/platforms/ios/build/device/include -I.../Sicredi/platforms/ios/build/device/usr/local/lib/include -I.../Sicredi/platforms/ios/build/UninstalledProducts/include -I.../Sicredi/platforms/ios/build/device -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources/arm64 -I.../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/DerivedSources -F.../Sicredi/platforms/ios/build/device -include .../Sicredi/platforms/ios/build/sharedpch/Sicredi\ App\ Metas-Prefix-fvnxnzxmrylfgkbxqkdoeqrxzlxq/Sicredi\ App\ Metas-Prefix.pch -MMD -MT dependencies -MF .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/CDVViewController+SplashScreen.d --serialize-diagnostics .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/CDVViewController+SplashScreen.dia -c .../Sicredi/platforms/ios/Sicredi\ App\ Metas/Plugins/cordova-plugin-splashscreen/CDVViewController+SplashScreen.m -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/CDVViewController+SplashScreen.o
Ld build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/Sicredi\ App\ Metas\ App\ Metas normal armv7
    export IPHONEOS_DEPLOYMENT_TARGET=6
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -arch armv7 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -L.../Sicredi/platforms/ios/build/device -F.../Sicredi/platforms/ios/build/device -filelist .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/Sicredi\ App\ Metas\ App\ Metas.LinkFileList -dead_strip -weak_framework CoreFoundation -weak_framework UIKit -weak_framework AVFoundation -weak_framework CoreMedia -weak-lSystem -ObjC -fobjc-arc -fobjc-link-runtime -miphoneos-version-min=6 -framework AssetsLibrary .../Sicredi/platforms/ios/build/device/libCordova.a -framework CoreGraphics -framework MobileCoreServices -Xlinker -dependency_info -Xlinker .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/Sicredi\ App\ Metas\ App\ Metas_dependency_info.dat -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/Sicredi\ App\ Metas\ App\ Metas
Ld build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/Sicredi\ App\ Metas\ App\ Metas normal arm64
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -arch arm64 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -L.../Sicredi/platforms/ios/build/device -F.../Sicredi/platforms/ios/build/device -filelist .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/Sicredi\ App\ Metas\ App\ Metas.LinkFileList -dead_strip -weak_framework CoreFoundation -weak_framework UIKit -weak_framework AVFoundation -weak_framework CoreMedia -weak-lSystem -ObjC -fobjc-arc -fobjc-link-runtime -miphoneos-version-min=6 -framework AssetsLibrary .../Sicredi/platforms/ios/build/device/libCordova.a -framework CoreGraphics -framework MobileCoreServices -Xlinker -dependency_info -Xlinker .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/Sicredi\ App\ Metas\ App\ Metas_dependency_info.dat -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/Sicredi\ App\ Metas\ App\ Metas
Ld build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/Sicredi\ App\ Metas\ App\ Metas normal armv7s
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -arch armv7s -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -L.../Sicredi/platforms/ios/build/device -F.../Sicredi/platforms/ios/build/device -filelist .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/Sicredi\ App\ Metas\ App\ Metas.LinkFileList -dead_strip -weak_framework CoreFoundation -weak_framework UIKit -weak_framework AVFoundation -weak_framework CoreMedia -weak-lSystem -ObjC -fobjc-arc -fobjc-link-runtime -miphoneos-version-min=6 -framework AssetsLibrary .../Sicredi/platforms/ios/build/device/libCordova.a -framework CoreGraphics -framework MobileCoreServices -Xlinker -dependency_info -Xlinker .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/Sicredi\ App\ Metas\ App\ Metas_dependency_info.dat -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/Sicredi\ App\ Metas\ App\ Metas
CreateUniversalBinary build/device/Sicredi\ App\ Metas\ App\ Metas.app/Sicredi\ App\ Metas\ App\ Metas normal armv7\ armv7s\ arm64
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/lipo -create .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7/Sicredi\ App\ Metas\ App\ Metas .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/armv7s/Sicredi\ App\ Metas\ App\ Metas .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Objects-normal/arm64/Sicredi\ App\ Metas\ App\ Metas -output .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/Sicredi\ App\ Metas\ App\ Metas
GenerateDSYMFile build/device/Sicredi\ App\ Metas\ App\ Metas.app.dSYM build/device/Sicredi\ App\ Metas\ App\ Metas.app/Sicredi\ App\ Metas\ App\ Metas
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/dsymutil .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/Sicredi\ App\ Metas\ App\ Metas -o .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app.dSYM
ProcessProductPackaging /Users/builduser/Library/MobileDevice/Provisioning\ Profiles/Sicredi_App_Metas.mobileprovision.144987066432.mobileprovision build/device/Sicredi\ App\ Metas\ App\ Metas.app/embedded.mobileprovision
    cd .../Sicredi/platforms/ios
    export PATH="/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin:/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/local/git/bin:/Developer/android-sdk-macosx/tools:/usr/local/ant/bin"
    builtin-productPackagingUtility /Users/builduser/Library/MobileDevice/Provisioning\ Profiles/Sicredi_App_Metas.mobileprovision.144987066432.mobileprovision -o .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/embedded.mobileprovision
Touch build/device/Sicredi\ App\ Metas\ App\ Metas.app
    /usr/bin/touch -c .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app
ProcessProductPackaging /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk/Entitlements.plist build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas.app.xcent
    builtin-productPackagingUtility /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk/Entitlements.plist -entitlements -format xml -o .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas.app.xcent
CodeSign build/device/Sicredi\ App\ Metas\ App\ Metas.app
    export CODESIGN_ALLOCATE=/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/codesign_allocate
Signing Identity:     "iPhone Distribution: Lucas Garcia Arf (NFS34UNL7B)"
Provisioning Profile: "Sicredi App Metas"
                      (9d84ddf0-3837-404c-9a70-7412052f67cf)
    /usr/bin/codesign --force --sign 68B54207AAD02FA5C4629725E9D77B143D89CEDA --resource-rules=.../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app/ResourceRules.plist --entitlements .../Sicredi/platforms/ios/build/Sicredi\ App\ Metas.build/Release-iphoneos/Sicredi\ App\ Metas.build/Sicredi\ App\ Metas\ App\ Metas.app.xcent .../Sicredi/platforms/ios/build/device/Sicredi\ App\ Metas\ App\ Metas.app
** BUILD SUCCEEDED **
Command finished with error code 0: .../Sicredi/platforms/ios/cordova/build --release,--device
PaulF_IntelCorp
Sorry, but I don't understand what you mean by "the build for ios glitch and shows where the error" in your post. Can you post your question in your native language, instead of English.
Also, please do not past long build logs into your posts, they are very difficult to read that way, please attach them using the "Attach Media" button below the edit window.
Samuel_S_3
The application has the build successfully for android, but for ios glitch , and the log does not say what failure is , however the logo says that the build was successful
PaulF_IntelCorp
Samuel, please post an image showing what you mean. And post a detailed explanation in Portuguese, it will be easier for me to understand a detailed post in your native language.
Samuel_S_3
O problema era o nome, ou seja, Tinha alterado o nome do projeto.
PaulF_IntelCorp
Glad you found the solution!
