Software Archive
Read-only legacy content
17060 Discussions
client SQL to control DB
paolo_c_
I have an error in my app wher I read DB.
Can I controll my DB with some client SQL? I find my DB in android device?
This is un exctract of my code
var db = openDatabase('mydb1', '1.0', 'Test DB', 2 * 1024 * 1024);
        var sCombo;
        var sComboSet;
        var sComboGioca;
        var partitaId = gPartitaAperta;
        db.transaction(function (tx) {
            var sql = 'SELECT p.nome FROM partita p WHERE p.id = ' + partitaId;
etc.....
Rakshith_K_Intel
What is the error message you are seeing? and what android device/version are you using to test?
paolo_c_
Android 4.4.2 but it is not important
Maybe I explained bad
I have errors due to data incorrectly inserted
I need a tool sql to access and control the data I recorded
I installed sql editor, but I do not know where to find my DB on the device
PaulF_IntelCorp
That's going to be tough. Did you use the SQLite plugin to implement your SQL database? If so, you can inspect that plugin's source code to determine the name and location of the DB file and maybe extract that file from a device using something like Astro. Or, you might have to modify your app to retrieve and mail the DB file from your device. In any event, if you believe you have put bad data in the DB and you have the app installed on many devices, you'll probably have to issue a new version of the app that, on first run, reads the bad DB, fixes it, and stores the fixes back...
