Software Archive
Read-only legacy content
17060 Discussions
google maps iframe
nicolas_r_
hi i have some problems with google maps embed on Iframe i use like 10 on my app on the preview they work fine also in the emulator but when i build the apk and try on my phone sometimes they din't apear and there is just a blank space others they are not well centered some advised to fix that?
<style>
                    .wrapper {
                        position: relative;
                        padding-bottom: 165%; // This is the aspect ratio
                        height: 0;
                        overflow: hidden;
                    .wrapper iframe {
                        position: absolute;
                        top: 0;
                        left: 0;
                        width: 100% !important;
                        height: 93% !important;
                </style>
                <div id="mapa_2" class="upage-content vertical-col left hidden">
                    <div class="wrapper">
                        <iframe src="http://mapbuildr.com/frame/hc0v2v" frameborder="0"></iframe>
                    </div>
                </div>
Rakshith_K_Intel
Some old android devices dont initialize height and width immediately, try loading map after Cordova deviceready event is fired, here is sample code I tested, this loads the iframe src after deviceready event is fired:
<!DOCTYPE html>
<html lang="en">
<head>
    <meta charset="UTF-8">
    <meta name="viewport" content="width=device-width, initial-scale=1, user-scalable=no">
    <style>
        .wrapper {
            position: relative;
            height: 0;
            overflow: hidden;
        .wrapper iframe {
            position: absolute;
            top: 0;
            left: 0;
    </style>
    <script src="cordova.js"></script>
    <script>
        document.addEventListener("deviceready", function(){
            document.getElementById("map").src = "http://mapbuildr.com/frame/hc0v2v";
        }, false);
    </script>
</head>
<body>
            <iframe id="map" src="" frameborder="0"></iframe>
        </div>
    </div>
</body>
</html>
nicolas_r_
ty so much at least in emulate works fine now i have to edit for other maps on the apk and try on my phone =)
