Software Archive
Read-only legacy content
17060 Discussions
Error Creating Project - cannot read property 'lenght'
andre_m_3
When I try to create a project with App Designer I get this error message:
Error Creating Project: Type Error: Cannot read property 'Lenght' of undefined
The project its created but don't enable App Designer, just code editor mode.
I'm using windows 7, 64 bits.
Chris_P_Intel
What version of the XDK are you using? And what is the exact type of project you are creating?
I have version 3491 and I tried creating a HTML 5 + Cordova project based off the Blank template and it worked fine.
andre_m_3
Its the last one, I'm trying to create the template version basic HTML5 with App designer support.
Justin_N_
I have a similar error, using the latest SDK - version 3491
I was trying to create a project based on a 'Tab view app' template.
Justin_N_
This may be interesting to whoever is debugging this ...
When I had that error, the framework showed my project folder as 'secondApp', but was displaying my first app. When I removed both apps (deleted them from disk) and went through the wizard to create an app from the same template, it worked ok.
