Software Archive
Read-only legacy content
17061 Discussions
Error: Plugin "Cordova sqlite storage plugin" failed to install.
Rodrigo_M_1
New Contributor II
Hi there,
I'm trying to use the that comes already with Intel XDK in the Plugin Management located in the "Featured Plugins" --> "SQLite Native Storage" Version 0.7.11.
The thing is I'm able to add the plugin without problem, but wen I try to compile for iOS I got a error message.
I was able to add the plugin locally after download, but I would like to report this error!
Follow the error:
The build failed. An error occurred while building the application. Verify your build assets are correct and try again.
Build Log:
Building a Cordova 4.1.2 application.
The application name is "Texboxes"
The package name is "com.rmartins.DataGrid"
Will use the provisioning profile for "adhoc"
Plugin "org.apache.cordova.device" (0.2.13) installed.
Plugin "org.apache.cordova.splashscreen" (0.3.5) installed.
Amrita_C_Intel
I recreated the scenario and I was able to build successfully. If you can provide the .zip file of your project I can try building.
Rodrigo_M_1
New Contributor II
Hi Amrita, I sent to you a message with a sample code attached!
Thanks!
Amrita_C_Intel
I have replied you.
Kevin_L_3
I'm reporting the same issue on iOS builds, as of this morning, I'm getting the same error message. Error: Plugin "Cordova sqlite storage plugin" failed to install (version 0.7.14). Android Crosswalk build was successful. Have been using CLI Version 5.1.1 all along as well.
Rodrigo_M_1
New Contributor II
I just tested my application, and I got the problem with SQLite version: 0.7.14 on Cordova CLI Version 5.1.1
I have changed the Cordova CLI to 4.1.2 and I was able to compile.
So the problem is a compatibility with cordova CLI 5.1.1!
The build failed.
Build Log:
  • Building a Cordova 5.1.1 application.
  • The application name is "MFSiOsMobile"
  • The package name is "com.rmartins.DataGrid"
  • Will use the provisioning profile for "adhoc"
  • Error: Plugin "Device" failed to install.
  • Error: Plugin "Network Information" failed to install.
  • Error: Plugin "Notification" failed to install.
  • Error: Plugin "Cordova sqlite storage plugin" failed to install.
  • Plugin "cordova-plugin-splashscreen" (2.1.0) installed.
  • Plugin "intel.xdk.device" (2.0.1) installed.
  • Plugin "intel.xdk.contacts" (1.2.3) installed.
Kevin_L_3
As an update: I was able to build with 0.7.15-pre Ok on iOS, CLI 5.1.1.
Rodrigo_M_1
New Contributor II
Where did you get the 0.7.15 version ? I have tried to remove and add the SQLite plugin, but the last version is 0.7.14!
PaulF_IntelCorp
Rodrigo -- the plugin versions shown in the featured list are those that were available at the time the list was assembled. If you want to use a version of a plugin that is not shown in the featured list you can do so by simply adding the plugin using the third-party plugin dialog, rather than the featured list dialog.
Follow the documentation link for more details about that plugin:
Rodrigo_M_1
New Contributor II
Hi Paul, thanks for your reply! I Already know that, and I have checked the documentation already that the 0.7.14 is the latest of 8 releases.
By the way I note that the link to the gitHub repository some files has been changed 14 days ago...
I just don't understand why the SQLite 0.7.14 just start having this problem on  cordova CLI 5.1.1 between yesterday and today...
Actually I was working yesterday without problem!
I'll use the third-Party for now until get it fixed!
Thanks guys!
Best Regards!
Michael_O_2
Dear Rodrigo.
Remove the plugin and use this:
var db = openDatabase('mydb', '1.0', 'Test DB', 2 * 1024 * 1024);
db.transaction(function (tx) {
   tx.executeSql('CREATE TABLE IF NOT EXISTS LOGS (id unique, log)');
The in-built HTML5 Web SQL functionality can suffice for sqlite plugin.
Another advantage if using this is the reduction in your file size.
