Software Archive
Read-only legacy content
17060 Discussions
Problems with listview on IOS
Diego_Calp
Valued Contributor I
Hi all, first post. I´m working with XDK from several months and think it's great.
XDK Version 2807, my problems are, if the listview items exceed the screen size, don`t scroll to last items.
And items don't respond to clicks when are linked to show another page.
Only on IOs, testing it with App Preview or as a web app uploades to server and opening it with Safari on IPhone. Tested with App Framework 3 and Bootstrap.
Thanks, regards
Diego
Rakshith_K_Intel
Please give more details on how you created the listview or share the index.html contents
I was able to create a simple listview and scroll worked on iOS AppPreview, here is what I did, let me know how you are doing:
  1. Create new project, select Bootstrap
  2. Drag ListView, it will create 3 list view items
  3. Drag and drop list view items to it, until there are enough to scroll
  4. Test on iOS App Preview and check for scroll
Diego_Calp
Hi, thanks for your quick reply.
You are right, scroll works ok with bootstrap. But I can't make a list item link to open a new page.
Here is a project, created as Standar HTML5 only with Bootstrap as fw, what I did is:
Drag and drop a list view into main page
Added several individual list items
Create a new page, add a header
Link firs item action to open second page.
Thanks, regards
Diego
<!DOCTYPE html>
<html>
  * Please see the included README.md file for license terms and conditions.
    <head>
        <meta charset="UTF-8">
        <link rel="stylesheet" type="text/css" href="bootstrap/css/bootstrap.min.css">
        <title>Blank App Designer Packaged Web App Project Template</title>
        <meta http-equiv="Content-type" content="text/html; charset=utf-8">
  * The "meta viewport" tag (below) helps your app size appropriately to a device's ideal viewport.
  * Note that Windows device viewports work better when initialized using the @viewport CSS rule.
  * For a quick overview of "meta viewport" and @viewport, see this article:
  *   http://webdesign.tutsplus.com/tutorials/htmlcss-tutorials/quick-tip-dont-forget-the-viewport-meta-tag
  * To see how it works, try your app on a real device with and without a "meta viewport" tag.
  * Additional useful references include:
  *   http://www.quirksmode.org/mobile/viewports.html
  *   http://www.quirksmode.org/mobile/metaviewport/devices.html
  *   https://developer.apple.com/library/safari/documentation/AppleApplications/Reference/SafariHTMLRef/Articles/MetaTags.html
        <!-- <meta name="viewport" content="width=device-width, minimum-scale=1, initial-scale=1"> -->
        <meta name="viewport" content="width=device-width, minimum-scale=1, initial-scale=1, user-scalable=no">
        <!-- <meta name="viewport" content="width=device-width, initial-scale=1, user-scalable=yes, minimum-scale=1, maximum-scale=2"> -->
        <style>
            /* following three (cascaded) are equivalent to above three meta viewport statements */
            /* see http://www.quirksmode.org/blog/archives/2014/05/html5_dev_conf.html */
            /* see http://dev.w3.org/csswg/css-device-adapt/ */
                @-ms-viewport { width: 100vw ; min-zoom: 100% ; zoom: 100% ; }          @viewport { width: 100vw ; min-zoom: 100% zoom: 100% ; }
                @-ms-viewport { user-zoom: fixed ; min-zoom: 100% ; }                   @viewport { user-zoom: fixed ; min-zoom: 100% ; }
                /*@-ms-viewport { user-zoom: zoom ; min-zoom: 100% ; max-zoom: 200% ; }   @viewport { user-zoom: zoom ; min-zoom: 100% ; max-zoom: 200% ; }*/
        </style>
        <link rel="stylesheet" href="css/app.css">
        <link rel="stylesheet" type="text/css" href="css/index_main.less.css" class="main-less">
        <!-- IMPORTANT: Do not include a weinre script tag as part of your release builds! -->
        <!-- Place your remote debugging (weinre) script URL from the Test tab here, if it does not work below -->
        <!-- <script src="http://debug-software.intel.com/target/target-script-min.js#insertabiglongfunkynumberfromthexdkstesttab"></script> -->
        <!-- Recommended location for your JavaScript libraries -->
        <!-- These library references (below) are just examples to give you the general idea... -->
        <!-- <script src="lib/mc/hammer.js"></script> -->
        <!-- <script src="lib/ft/fastclick.js"></script> -->
  * cordova.js is a phantom lib for "Cordova HTML5 web app," it does nothing in a "Standard HTML5 web app"
  * Seeing a "Failed to load resource: net::ERR_FILE_NOT_FOUND" message caused by this "cordova.js" script?
  * The cordova.js script is required if you convert your "Standard HTML5" project into a "Cordova" project.
  * You can safely ignore the error or comment out this line if you will not be developing a Cordova app.
        <script src="cordova.js" id="xdkJScordova_"></script>
        <script src="js/app.js"></script>
        <!-- for your event code, see README and file comments for details -->
        <script src="js/init-app.js"></script>
        <!-- for your init code, see README and file comments for details -->
        <script src="xdk/init-dev.js"></script>
        <!-- normalizes device and document ready events, see file for details -->
        <script type="application/javascript" src="lib/jquery.min.js"></script>
        <script type="application/javascript" src="bootstrap/js/bootstrap.min.js"></script>
        <script type="application/javascript" src="marginal/marginal-position.min.js"></script>
        <script type="application/javascript" src="js/index_user_scripts.js"></script>
        <script type="application/javascript" src="xdk/ad/bs_subpage.js"></script>
    </head>
    <body>
        <!-- Place your remote debugging (weinre) script URL from the Test tab here, if it does not work above -->
        <div class="upage vertical-col left" id="mainpage">
            <div class="list-group widget uib_w_1 d-margins" data-uib="twitter%20bootstrap/list_group" data-ver="1">
                <a class="list-group-item allow-badge widget uib_w_2" data-uib="twitter%20bootstrap/list_item" data-ver="1">
                    <h4 class="list-group-item-heading">Heading</h4>
                    <p class="list-group-item-text">List item</p>
                </a>
                <a class="list-group-item allow-badge widget uib_w_3" data-uib="twitter%20bootstrap/list_item" data-ver="1">
                </a>
                <a class="list-group-item allow-badge widget uib_w_10 d-margins" data-uib="twitter%20bootstrap/list_item" data-ver="1">
                </a>
                <a class="list-group-item allow-badge widget uib_w_9 d-margins" data-uib="twitter%20bootstrap/list_item" data-ver="1">
                </a>
                <a class="list-group-item allow-badge widget uib_w_8 d-margins" data-uib="twitter%20bootstrap/list_item" data-ver="1">
                </a>
                <a class="list-group-item allow-badge widget uib_w_7 d-margins" data-uib="twitter%20bootstrap/list_item" data-ver="1">
                </a>
                <a class="list-group-item allow-badge widget uib_w_6 d-margins" data-uib="twitter%20bootstrap/list_item" data-ver="1">
                </a>
                <a class="list-group-item allow-badge widget uib_w_5 d-margins" data-uib="twitter%20bootstrap/list_item" data-ver="1">
                </a>
                <a class="list-group-item allow-badge widget uib_w_4" data-uib="twitter%20bootstrap/list_item" data-ver="1">
                </a>
            </div>
        </div>
        <div class="upage hidden" id="uib_page_1">
            <div class="upage-outer">
                <div class="uib-header header-bg container-group inner-element uib_w_11" data-uib="layout/header" data-ver="0">
                    <h2>New page</h2>
                    <div class="widget-container wrapping-col single-centered"></div>
                    <div class="widget-container content-area horiz-area wrapping-col left"></div>
                    <div class="widget-container content-area horiz-area wrapping-col right"></div>
                </div>
                <div class="upage-content ac0 content-area vertical-col left"></div>
            </div>
        </div>
    </body>
</html>
Chris_P_Intel
Hmm. If you link a list item to a page using the Interactivity pane, then the href on the list item is supposed to be set for you. But I don't see it.
The quick fix is to use the properties pane and set the href of the list item in question to   #    .  Then it should start working.
Diego_Calp
Hi Chris,
This sample project is working correctly on emulator and App Preview in Android devices. XDK is linking the item action through the click event in index_user_scripts.js file, here is de code snippet:
    /* listitem  List item */
    $(document).on("click", ".uib_w_2", function(evt)
         /*global activate_page */
         activate_page("#uib_page_1");
Your suggestion worked. Using the # link to pages from list items makes it work on App Emulator in my iPhone.
I hope Intel solves the event issue, for example, I need to make some actions before show the new page, using the # complicates this.
Thanks you all,
Diego
