Software Archive
Read-only legacy content
17060 Discussions
Error: Plugin "com.phonegap.plugins.facebookconnect" failed to install.
Marco_M_
Hi it's two days I'm getting this error while executing the build (android and ios)
Previously the build was successful and the plugin worked correctly.
Please help!!!
marco
Elroy_A_Intel
Did you set the cordova version CLI to a version equal to 3.5 or higher? Are you still experiencing these messages?
Note: This plugin was recently updated 4 days ago according to the Apache Cordova Plugin Registry which may explain your issue with this new version.
Midhun_M_
Is there any update on this? I'm getting same error when I try to install phonegap-facebook-plugin 0.12.0
Build Log:
  • Error: Plugin Facebook Connect failed to install.
