Hi it's two days I'm getting this error while executing the build (android and ios)
Error: Plugin "com.phonegap.plugins.facebookconnect" failed to install.
Previously the build was successful and the plugin worked correctly.
Please help!!!
marco
- Tags:
- HTML5
- Intel® XDK
Did you set the cordova version CLI to a version equal to 3.5 or higher? Are you still experiencing these messages?
Note: This plugin was recently updated 4 days ago according to the Apache Cordova Plugin Registry which may explain your issue with this new version.
Is there any update on this? I'm getting same error when I try to install phonegap-facebook-plugin 0.12.0
Build Log:
- Error: Plugin Facebook Connect failed to install.
