Software Archive
Read-only legacy content
Error Uploading to Edison
toadaze
My Edison seems to be successfully connected to XDK, but when I try to do an install/build the "Onboard LED Blink" sample, I get this error:
Clean and Build project. This may take a few minutes.
Fetching packages using NPM: Installing
UPLOADING: Uploading project bundle to IoT device.
ERROR:Error extracting update - Error: Command failed: x node_modules/
x icon.png: Write failed
x main.js: Write failed
x package.json: Write failed
x README.md: Write failed
x test4.xdk: Write failed
x test4.xdke: Write failed
bsdtar: Error exit delayed from previous errors.
Also, when I try to make sure MRAA and UPM libraries are loaded with this instruction:
echo "src maa-upm http://iotdk.intel.com/repos/1.1/intelgalactic" > /etc/opkg/intel-iotdk.conf
I get this error:
"sh: write error: No space left on device"
Does anyone have any ideas?
Swati_S_Intel1
Most likely your Edison partition has run out of disk space.
You can check from your Edison console by running the command "df -h /"
It will show 100% used. If that's the case, please clean the logs under /var/log/journal directory.
We are working towards providing auto clear the logs. But in the meanwhile you can manually do it.
Go to /var/log/journal directory. Run "du -sh *", it will show you bunch of directories.
Remove all or some of them to create more disk space.
use rm -rf * to clean all the directories under journal. Do not remove journal directory.
Swati
Swati_S_Intel1
Swati
toadaze
Swati
Yes, that was the problem.  All OK now after removing all directories under /var/log/journal.
Thanks!
vaibhav_w_
Using Intel galileo Gen2... /dev/root 100% usage
there is no directory /var/log/journal directory ... where and how to clean the disk space..?
Vaibhav
Elroy_A_Intel
I recommend running the following command in an attempt to free up space.
rm -rf /var/tmp
