Software Archive
Read-only legacy content
17060 Discussions
Error code 65 for command: xcodebuild
Iginio_V_
Hi, I'm italian and this is my first time on the forum.
I work with Win 10 and this it's a build failed to iOS application file
I have update a Intel XDK to build 3240, so I have converted my previous App to Android build and I have update all plugins.
I read some replay to other tickets (same this error) and I Removing Intel® XDK Local Data on Windows 10 but the last test was building an IOS app failed and the logs are:
** BUILD FAILED **
Building a Cordova 5.1.1 application.
Using platform cordova-ios 3.8.0.
The application name is "Allevamento Newstarwood"
The package name is "app.newstarwood"
Plugin "cordova-plugin-screen-orientation" (1.4.0) installed.
Plugin "cordova-plugin-statusbar" (2.0.0) installed.
Plugin "cordova-plugin-device" (1.1.0) installed.
Plugin "cordova-plugin-network-information" (1.1.0) installed.
Plugin "cordova-plugin-x-socialsharing" (5.0.12) installed.
Plugin "cordova-plugin-fullscreen" (1.1.0) installed.
Targeting iOS version 7.0.
Error: A build error occurred. Check the build log.
The following build commands failed:
	CodeSign build/device/Allevamento\ Newstarwood.app
(1 failure)
Error code 65 for command: xcodebuild with args: -xcconfig,.../newstarwood/platforms/ios/cordova/build-release.xcconfig,-project,Allevamento Newstarwood.xcodeproj,ARCHS=armv7 arm64,-target,Allevamento Newstarwood,-configuration,Release,-sdk,iphoneos,build,VALID_ARCHS=armv7 arm64,CONFIGURATION_BUILD_DIR=.../newstarwood/platforms/ios/build/device,SHARED_PRECOMPS_DIR=.../newstarwood/platforms/ios/build/sharedpch
Command finished with error code 2: .../newstarwood/platforms/ios/cordova/build --release,--device
ERROR building one of the platforms: Error: .../newstarwood/platforms/ios/cordova/build: Command failed with exit code 2
You may not have the required environment or OS to build this project
    at ChildProcess.whenDone (.../cordova/cordova-cli/5.1.1/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:134:23)
    at emitTwo (events.js:87:13)
    at ChildProcess.emit (events.js:172:7)
    at maybeClose (internal/child_process.js:821:16)
    at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
Help me, please
John_H_Intel2
At the bottom of the log file, you will see this line:
6E1C58E1F285CA4A3F654E20EA4F7E22AE166B0A: no identity found
You have a problem with your certificate and/or provisioning profile.
John_H_Intel2
Please save your entire build log to a txt file and attach it to the thread for us to assist you.
Iginio_V_
Hi John,
I attach a complete build log in a text file.
John_H_Intel2
Iginio_V_
Hi John,
I read "Creating an Apple iOS* Distribution Certificate and P12 File with Intel® XDK" and I solved my problem!
Thanks so much!
