Software Archive
Read-only legacy content
17060 Discussions
Error codes for xeon phi
Xiaoxin_T_
I meet the following error when running some sample codes: "offload error: cannot start process on the device 0 (error code 9)"
Does anyone know how to solve this problem? Is there a way to find out the meaning of different error codes?
Loc_N_Intel
Hi Xiaoxin,
It seems like to need to start the MPSS stack before you can run your offload code:
% service mpss start
For the meaning of all error codes, let me do some research and get back to you. Thanks.
Loc_N_Intel
I find the List of Run-Time Error Messages here http://software.intel.com/en-us/node/464618  . In the above case, it seems like  your coprocessor is not available yet, you need to bring it up. Thank you.
Xiaoxin_T_
Thanks for your response :-)
But both "service mpss start" and "micctrl -w" show that the device is online. Does that mean the service has been started?
loc-nguyen (Intel) wrote:
Hi Xiaoxin,
Loc_N_Intel
Hi Xiaoxin,
That is interesting. Could you tell me the MPSS version, the compiler version and where you get the sample code? I will reproduce the problem. Thank you.
Xiaoxin_T_
[xiaoxin.tang@compute-phi-d1-002-p ~]$ micinfo
MicInfo Utility Log
Created Wed Nov 6 14:34:21 2013
System Info
HOST OS : Linux
OS Version : 2.6.32-279.el6.x86_64
Driver Version : 6720-15
MPSS Version : 2.1.6720-15
Host Physical Memory : 132132 MB
Device No: 0, Device Name: mic0
Version
Flash Version : 2.1.03.0386
SMC Firmware Version : 1.15.4830
SMC Boot Loader Version : 1.8.4326
uOS Version : 2.6.38.8-g2593b11
Device Serial Number : ADKC24200590
Board
Vendor ID : 0x8086
Device ID : 0x2250
Subsystem ID : 0x2500
Coprocessor Stepping ID : 3
PCIe Width : Insufficient Privileges
PCIe Speed : Insufficient Privileges
PCIe Max payload size : Insufficient Privileges
PCIe Max read req size : Insufficient Privileges
Coprocessor Model : 0x01
Coprocessor Model Ext : 0x00
Coprocessor Type : 0x00
Coprocessor Family : 0x0b
Coprocessor Family Ext : 0x00
Coprocessor Stepping : B1
Board SKU : B1PRQ-5110P
ECC Mode : Enabled
SMC HW Revision : Product 225W Passive CS
Cores
Total No of Active Cores : 60
Voltage : 1010000 uV
Frequency : 1052631 kHz
Thermal
Fan Speed Control : N/A
Fan RPM : N/A
Fan PWM : N/A
Die Temp : 61 C
GDDR
GDDR Vendor : Elpida
GDDR Version : 0x1
GDDR Density : 2048 Mb
GDDR Size : 7936 MB
GDDR Technology : GDDR5
GDDR Speed : 5.000000 GT/s
GDDR Frequency : 2500000 kHz
GDDR Voltage : 1501000 uV
[xiaoxin.tang@compute-phi-d1-002-p ~]$ icc --version
icc (ICC) 13.0.1 20121010
Copyright (C) 1985-2012 Intel Corporation. All rights reserved.
The sample codes are contained in the compiler (Samples/en_US/C++/mic_samples). All of them failed with the same problem.
Xiaoxin
Hi Xiaoxin,
Loc_N_Intel
Your MPSS 2.1 is current but your compiler is a bit old. I compiled and ran all the MIC sample code in ../Samples/en_US/C++/mic_samples without any problem. I am not sure what causes the COI timeout in your system.
The information about PCIe in your system (shown in micinfo) is  not usual:
- Can you try to reflash your coprocessor? (micflash)
- If possible, get and install the new version of the Intel Composer 2013 SP1
By the way, I learned that the error codes are found in /opt/intel/mic/coi/include/COIResult_common.h (for MPSS 2.1) and in /usr/include/intel-coi/common/COIResult_common.h (for MPSS 3.1), but not sure how this COI timeout (COI_TIME_OUT_REACHED) problem occured.
Xiaoxin_T_
Thanks loc-nguyen :-)
I met the problem when I was using a public machine. After building the Xeon Phi environment and installing the latest MPSS on my own machine, the problem never appeaers again.
