Software Archive
Read-only legacy content
17060 Discussions
Error contacting remote build servers
Rafael_F_3
Hi there,
I did everything Paul already suggested in others threads, but it still doesn't work. Names in my .xdk and .xdke are 001, test, etc. I mean simple names without spaces. Of course I have internet connection.
Rafael
Shahab_L_Intel
Hi Rafael,
Is this a consistent problem for all the apps you have, for example if you just get a sample app and try to build it you get the same issue?  If so there's a good chance it could be your firewall or proxy.  If you can try removing the proxy and connecting on a different network (e.g. home network or wifi hotspot) to see if you can connect that way.
Rafael_F_3
Hi Shahab,
I imported a template, tried  to build it and I got the same problem. The last chance I have is to change of network but I am not very sure if it'll work or not.
Thanks for your feedback!
Rafael
