Software Archive
Read-only legacy content
17060 Discussions
Error log... garbage? fact? bug?
Phil_P___Pete_
I understand the message... or at least I think I do but I'm a little concerned about the garbage characters...
Check dependencies
Code Sign error: Provisioning profile does not match bundle identifier: The provisioning profile specified in your build settings (“ios adhoc provisioning profile”) has an AppID of “com.app_name.mobileios” which does not match your bundle identifier “N9CGYB9H99.com.app_name.mobileios”.
** BUILD FAILED **
PaulF_IntelCorp
Those garbage characters are normal in that message. Your mobile provisioning file does not match your cert, usually the easiest way to deal with this is to just download a new set of Apple certs and use those. Sometimes it means the App ID in your certs does not match the one in your app.
PaulF_IntelCorp
Phil_P___Pete_
I knew what it meant... fixed it in the app, got a good build but was just concerned about the garbage characters... just seems like some very sloppy programming or ....
PaulF_IntelCorp
The message is generated by the Cordova CLI build system, it's not a message we generate, we're simply passing back a filtered version of the Cordova CLI build process.
