Software Archive
Read-only legacy content
17060 Discussions
[Error] mic0: State failed - non existent MIC device
Munasinghe__Indula
I have a system with Intel Xeon Phi 3120A coprocessor running with Intel Pentium Gold G5400 processor on a Asus Z370P motherboard with Above 4G decoding enabled. The system was working fine. After an unexpected power cut the coprocessor is not identified by the system. I do not know if the coprocessor is damaged. The coprocessor, blue LED is working as usual and so does the cooling fan.
When I entered, micctrl -s following result is shown,
[root@localhost ~]# micctrl -s
When I do miccheck,
[root@localhost ~]# miccheck
MicCheck 3.8.3-1
Copyright (c) 2016, Intel Corporation.
Executing default tests for host
  Test 0: Check number of devices the OS sees in the system ... pass
  Test 1: Check mic driver is loaded ... fail
    mic driver not loaded
Status: FAIL
Failure: mic driver not loaded
When I do lspci,
[root@localhost ~]# lspci
01:00.0 Co-processor: Intel Corporation Xeon Phi coprocessor 3120 series (rev 20)
I already tried re-installing the MPSS 3.8.3 and it didn't work. The system was working fine with MPSS 3.8.3. It seems the MIC driver is not loaded. But I do not know how to re-install it on the system.
I'm very new to these type of systems though I got the system to working state with the help of this forum and the instruction manuals.
Could you please explain how to resolve this problem?
JJK
New Contributor III
Which OS are you using? And more specifically, which kernel version (post the output of 'uname -a')?
It could very well be that you are running RHEL/CentOS 7 and have received a kernel update for which Intel has not published a mic driver version.
HTH,
JJK
Munasinghe__Indula
Thank you for the reply.
After searching many forums until your reply, I also beginning to worry that this might be the issue. My kernel is 3.10.0-1062 which is CentOS 7.7. What is the latest CentOS version that MPSS supports ?
Loc_N_Intel
Hi Indula,
MPSS has many release versions. If you use MPSS 3.8 (the latest release version), it supports RedHat 7.3.
Munasinghe__Indula
Hi Nguyen,
Thank you for your Answer.
JJK
New Contributor III
You should upgrade to MPSS 3.8.6 to address CVE-2020-0563
As for the RHEL/CentOS kernel version:  I use CentOS 7.7 + mpss 3.8.6 + a patched mpss-modules package and it runs fine. You can find my patches to the mpss-modules package at
  https://www.nikhef.nl/~janjust/mpss/
including a pre-built package for the 3.10.0-1062 kernel.
HTH,
JJK
Munasinghe__Indula
Hi
My problem is not solved. I reinstalled CentOS 7.3. But I can't get to rebuild the mpss rpm files.
The bash is as follows.
[root@localhost src]# ls
dapl-2.1.9-2.glibc2.12.src.rpm  mpss-modules-3.8.6-1.src.rpm
libibscif-1.0.0-1.el6.src.rpm   ofed-driver-1.0.0-1.el6.src.rpm
[root@localhost src]# rpmbuild --rebuild mpss-modules*.src.rpm
Installing mpss-modules-3.8.6-1.src.rpm
warning: user qb_user does not exist - using root
warning: group qb_user does not exist - using root
Executing(%prep): /bin/sh -e /var/tmp/rpm-tmp.ipFa6b
+ umask 022
+ cd /root/rpmbuild/BUILD
+ rm -rf mpss-modules-3.8.6
+ /usr/bin/mkdir -p mpss-modules-3.8.6
+ cd mpss-modules-3.8.6
+ /usr/bin/bzip2 -dc /root/rpmbuild/SOURCES/mpss-modules-3.8.6.tar.bz2
+ /usr/bin/tar -xvvf -
drwxrwxr-x qb_user/qb_user   0 2019-07-25 13:09 ./
-rw-rw-r-- qb_user/qb_user 411 2019-07-01 16:45 ./udev-mic.rules
-rw-rw-r-- qb_user/qb_user  49 2019-07-01 16:45 ./.mpss-metadata
drwxrwxr-x qb_user/qb_user   0 2019-07-01 16:45 ./dma/
-rw-rw-r-- qb_user/qb_user 120 2019-07-01 16:45 ./dma/Kbuild
-rw-rw-r-- qb_user/qb_user 16015 2019-07-01 16:45 ./dma/mic_dma_md.c
-rw-rw-r-- qb_user/qb_user  2151 2019-07-01 16:45 ./dma/mic_sbox_md.c
-rw-rw-r-- qb_user/qb_user 54732 2019-07-01 16:45 ./dma/mic_dma_lib.c
-rw-rw-r-- qb_user/qb_user  3589 2019-07-01 16:45 ./Kbuild
drwxrwxr-x qb_user/qb_user     0 2019-07-01 16:45 ./mpssboot/
-rw-rw-r-- qb_user/qb_user  6910 2019-07-01 16:45 ./mpssboot/mpssboot.c
-rw-rw-r-- qb_user/qb_user    20 2019-07-01 16:45 ./mpssboot/Kbuild
drwxrwxr-x qb_user/qb_user     0 2019-07-01 16:45 ./pm_scif/
-rw-rw-r-- qb_user/qb_user    19 2019-07-01 16:45 ./pm_scif/Kbuild
-rw-rw-r-- qb_user/qb_user 10092 2019-07-01 16:45 ./pm_scif/pm_scif.c
-rw-rw-r-- qb_user/qb_user  2152 2019-07-01 16:45 ./pm_scif/pm_scif.h
drwxrwxr-x qb_user/qb_user     0 2019-07-01 16:45 ./ras/
-rw-rw-r-- qb_user/qb_user 32564 2019-07-01 16:45 ./ras/micras_uncore.c
-rw-rw-r-- qb_user/qb_user   207 2019-07-01 16:45 ./ras/Kbuild
-rw-rw-r-- qb_user/qb_user 68817 2019-07-01 16:45 ./ras/micras_main.c
-rw-rw-r-- qb_user/qb_user 32895 2019-07-01 16:45 ./ras/micras_api.h
-rw-rw-r-- qb_user/qb_user  6557 2019-07-01 16:45 ./ras/monahan.h
-rw-rw-r-- qb_user/qb_user 37460 2019-07-01 16:45 ./ras/micras_knf.c
-rw-rw-r-- qb_user/qb_user 77928 2019-07-01 16:45 ./ras/micras_elog.c
-rw-rw-r-- qb_user/qb_user 69571 2019-07-01 16:45 ./ras/micras_knc.c
-rw-rw-r-- qb_user/qb_user  6491 2019-07-01 16:45 ./ras/Makefile
-rw-rw-r-- qb_user/qb_user 30533 2019-07-01 16:45 ./ras/micras_core.c
-rw-rw-r-- qb_user/qb_user 24090 2019-07-01 16:45 ./ras/micras_common.c
-rw-rw-r-- qb_user/qb_user 28421 2019-07-01 16:45 ./ras/micras_pm.c
-rw-rw-r-- qb_user/qb_user 10224 2019-07-01 16:45 ./ras/micpm_api.h
-rw-rw-r-- qb_user/qb_user 14455 2019-07-01 16:45 ./ras/micras.h
-rw-rw-r-- qb_user/qb_user  4687 2019-07-01 16:45 ./ras/micmca_api.h
drwxrwxr-x qb_user/qb_user     0 2019-07-01 16:45 ./trace_capture/
-rw-rw-r-- qb_user/qb_user    25 2019-07-01 16:45 ./trace_capture/Kbuild
-rw-rw-r-- qb_user/qb_user 10647 2019-07-01 16:45 ./trace_capture/tc_host.c
-rw-rw-r-- qb_user/qb_user  2415 2019-07-01 16:45 ./trace_capture/docapture.c
-rw-rw-r-- qb_user/qb_user  8602 2019-07-01 16:45 ./trace_capture/trace_capture.h
-rw-rw-r-- qb_user/qb_user   569 2019-07-01 16:45 ./trace_capture/Makefile
-rw-rw-r-- qb_user/qb_user  2816 2019-07-01 16:45 ./trace_capture/tc_memcvt.c
-rw-rw-r-- qb_user/qb_user 68560 2019-07-01 16:45 ./trace_capture/trace_capture.c
drwxrwxr-x qb_user/qb_user     0 2019-07-01 16:45 ./micscif/
-rw-rw-r-- qb_user/qb_user 11996 2019-07-01 16:45 ./micscif/micscif_rb.c
-rw-rw-r-- qb_user/qb_user 74401 2019-07-01 16:45 ./micscif/micscif_rma.c
-rw-rw-r-- qb_user/qb_user 16182 2019-07-01 16:45 ./micscif/micscif_va_gen.c
-rw-rw-r-- qb_user/qb_user 16374 2019-07-01 16:45 ./micscif/micscif_rma_list.c
-rw-rw-r-- qb_user/qb_user 31378 2019-07-01 16:45 ./micscif/micscif_debug.c
-rw-rw-r-- qb_user/qb_user 12177 2019-07-01 16:45 ./micscif/micscif_select.c
-rw-rw-r-- qb_user/qb_user 44878 2019-07-01 16:45 ./micscif/micscif_nm.c
-rw-rw-r-- qb_user/qb_user   584 2019-07-01 16:45 ./micscif/Kbuild
-rw-rw-r-- qb_user/qb_user  6661 2019-07-01 16:45 ./micscif/micscif_sysfs.c
-rw-rw-r-- qb_user/qb_user 13498 2019-07-01 16:45 ./micscif/micscif_smpt.c
-rw-rw-r-- qb_user/qb_user 96705 2019-07-01 16:45 ./micscif/micscif_api.c
-rw-rw-r-- qb_user/qb_user 18490 2019-07-01 16:45 ./micscif/micscif_main.c
-rw-rw-r-- qb_user/qb_user  5143 2019-07-01 16:45 ./micscif/micscif_intr.c
-rw-rw-r-- qb_user/qb_user 29259 2019-07-01 16:45 ./micscif/micscif_rma_dma.c
-rw-rw-r-- qb_user/qb_user 12840 2019-07-01 16:45 ./micscif/micscif_fd.c
-rw-rw-r-- qb_user/qb_user 85521 2019-07-01 16:45 ./micscif/micscif_nodeqp.c
-rw-rw-r-- qb_user/qb_user  6601 2019-07-01 16:45 ./micscif/micscif_va_node.c
-rw-rw-r-- qb_user/qb_user  8999 2019-07-01 16:45 ./micscif/micscif_ports.c
-rw-rw-r-- qb_user/qb_user 18092 2019-07-01 16:45 ./COPYING
-rw-rw-r-- qb_user/qb_user  4436 2019-07-01 16:45 ./Makefile
-rwxrwxr-x qb_user/qb_user    88 2019-07-01 16:45 ./mic.modules
drwxrwxr-x qb_user/qb_user     0 2019-07-01 16:45 ./include/
-rw-rw-r-- qb_user/qb_user  6481 2019-07-01 16:45 ./include/scif_ioctl.h
-rw-rw-r-- qb_user/qb_user  3744 2019-07-01 16:45 ./include/micint.h
drwxrwxr-x qb_user/qb_user     0 2019-07-01 16:45 ./include/mic/
-rw-rw-r-- qb_user/qb_user  2515 2019-07-01 16:45 ./include/mic/micscif_kmem_cache.h
-rw-rw-r-- qb_user/qb_user 12511 2019-07-01 16:45 ./include/mic/mic_pm.h
-rw-rw-r-- qb_user/qb_user  4050 2019-07-01 16:45 ./include/mic/micveth.h
-rw-rw-r-- qb_user/qb_user  4823 2019-07-01 16:45 ./include/mic/micvcons.h
-rw-rw-r-- qb_user/qb_user  7461 2019-07-01 16:45 ./include/mic/micveth_dma.h
-rw-rw-r-- qb_user/qb_user  3993 2019-07-01 16:45 ./include/mic/micscif_smpt.h
-rw-rw-r-- qb_user/qb_user  8075 2019-07-01 16:45 ./include/mic/micscif_nm.h
-rw-rw-r-- qb_user/qb_user 27176 2019-07-01 16:45 ./include/mic/micscif_rma.h
-rw-rw-r-- qb_user/qb_user  6156 2019-07-01 16:45 ./include/mic/compl_buf_ring.h
-rw-rw-r-- qb_user/qb_user  6023 2019-07-01 16:45 ./include/mic/io_interface.h
-rw-rw-r-- qb_user/qb_user  4631 2019-07-01 16:45 ./include/mic/bootparams.h
-rw-rw-r-- qb_user/qb_user  9223 2019-07-01 16:45 ./include/mic/micscif_nodeqp.h
-rw-rw-r-- qb_user/qb_user 27016 2019-07-01 16:45 ./include/mic/micscif.h
-rw-rw-r-- qb_user/qb_user  2272 2019-07-01 16:45 ./include/mic/micpsmi.h
-rw-rw-r-- qb_user/qb_user  4292 2019-07-01 16:45 ./include/mic/micbaseaddressdefine.h
-rw-rw-r-- qb_user/qb_user  2517 2019-07-01 16:45 ./include/mic/micveth_common.h
-rw-rw-r-- qb_user/qb_user  3220 2019-07-01 16:45 ./include/mic/micscif_va_gen.h
-rw-rw-r-- qb_user/qb_user  4929 2019-07-01 16:45 ./include/mic/micscif_rma_list.h
-rw-rw-r-- qb_user/qb_user  3120 2019-07-01 16:45 ./include/mic/mic_sbox_md.h
-rw-rw-r-- qb_user/qb_user  2635 2019-07-01 16:45 ./include/mic/mic_virtio.h
-rw-rw-r-- qb_user/qb_user  3835 2019-07-01 16:45 ./include/mic/micscif_va_node.h
-rw-rw-r-- qb_user/qb_user  7775 2019-07-01 16:45 ./include/mic/ringbuffer.h
-rw-rw-r-- qb_user/qb_user  2351 2019-07-01 16:45 ./include/mic/micscif_intr.h
-rw-rw-r-- qb_user/qb_user 14550 2019-07-01 16:45 ./include/mic/mic_dma_md.h
-rw-rw-r-- qb_user/qb_user  2108 2019-07-01 16:45 ./include/mic/micdboxdefine.h
-rw-rw-r-- qb_user/qb_user  7436 2019-07-01 16:45 ./include/mic/mic_dma_lib.h
-rw-rw-r-- qb_user/qb_user  5778 2019-07-01 16:45 ./include/mic/micscif_rb.h
-rw-rw-r-- qb_user/qb_user  7402 2019-07-01 16:45 ./include/mic/micscif_map.h
-rw-rw-r-- qb_user/qb_user 10281 2019-07-01 16:45 ./include/mic/micsboxdefine.h
-rw-rw-r-- qb_user/qb_user  4215 2019-07-01 16:45 ./include/mic/mic_macaddr.h
-rw-rw-r-- qb_user/qb_user  6544 2019-07-01 16:45 ./include/mic/mic_dma_api.h
-rw-rw-r-- qb_user/qb_user  3953 2019-07-01 16:45 ./include/mic_interrupts.h
-rw-rw-r-- qb_user/qb_user 22586 2019-07-01 16:45 ./include/mic_common.h
-rw-rw-r-- qb_user/qb_user 68604 2019-07-01 16:45 ./include/scif.h
drwxrwxr-x qb_user/qb_user     0 2019-07-01 16:45 ./virtio/
-rw-rw-r-- qb_user/qb_user    24 2019-07-01 16:45 ./virtio/Kbuild
-rw-rw-r-- qb_user/qb_user 22334 2019-07-01 16:45 ./virtio/mic_virtblk.c
drwxrwxr-x qb_user/qb_user     0 2019-07-01 16:45 ./vcons/
-rw-rw-r-- qb_user/qb_user    44 2019-07-01 16:45 ./vcons/Kbuild
-rw-rw-r-- qb_user/qb_user  3737 2019-07-01 16:45 ./vcons/hvc_console.h
-rw-rw-r-- qb_user/qb_user  9616 2019-07-01 16:45 ./vcons/hvc_mic.c
drwxrwxr-x qb_user/qb_user     0 2019-07-01 16:45 ./ramoops/
-rw-rw-r-- qb_user/qb_user  4216 2019-07-01 16:45 ./ramoops/ramoops.c
-rw-rw-r-- qb_user/qb_user    19 2019-07-01 16:45 ./ramoops/Kbuild
-rw-rw-r-- qb_user/qb_user  1334 2019-07-01 16:45 ./mic.conf
drwxrwxr-x qb_user/qb_user     0 2019-07-01 16:45 ./host/
-rw-rw-r-- qb_user/qb_user 17157 2019-07-01 16:45 ./host/pm_ioctl.c
-rw-rw-r-- qb_user/qb_user 28523 2019-07-01 16:45 ./host/micscif_pm.c
-rw-rw-r-- qb_user/qb_user 21744 2019-07-01 16:45 ./host/linvnet.c
-rw-rw-r-- qb_user/qb_user  4940 2019-07-01 16:45 ./host/linpsmi.c
-rw-rw-r-- qb_user/qb_user 19188 2019-07-01 16:45 ./host/linvcons.c
-rw-rw-r-- qb_user/qb_user 29774 2019-07-01 16:45 ./host/pm_pcstate.c
-rw-rw-r-- qb_user/qb_user 29536 2019-07-01 16:45 ./host/tools_support.c
-rw-rw-r-- qb_user/qb_user  9705 2019-07-01 16:45 ./host/linscif_host.c
-rw-rw-r-- qb_user/qb_user  1444 2019-07-01 16:45 ./host/Makefile
-rw-rw-r-- qb_user/qb_user 22761 2019-07-01 16:45 ./host/linsysfs.c
drwxrwxr-x qb_user/qb_user     0 2019-07-01 16:45 ./host/vhost/
-rw-rw-r-- qb_user/qb_user  7930 2019-07-01 16:45 ./host/vhost/vhost.h
-rw-rw-r-- qb_user/qb_user 18710 2019-07-01 16:45 ./host/vhost/mic_vhost.c
-rw-rw-r-- qb_user/qb_user 16910 2019-07-01 16:45 ./host/vhost/mic_blk.c
-rw-rw-r-- qb_user/qb_user  6527 2019-07-01 16:45 ./host/linpm.c
-rw-rw-r-- qb_user/qb_user  5404 2019-07-01 16:45 ./host/ioctl.c
-rw-rw-r-- qb_user/qb_user 22242 2019-07-01 16:45 ./host/linux.c
-rw-rw-r-- qb_user/qb_user 22798 2019-07-01 16:45 ./host/vmcore.c
-rw-rw-r-- qb_user/qb_user 53803 2019-07-01 16:45 ./host/uos_download.c
-rw-rw-r-- qb_user/qb_user  5386 2019-07-01 16:45 ./host/acptboot.c
-rw-rw-r-- qb_user/qb_user  6154 2019-07-01 16:45 ./host/micpsmi.c
drwxrwxr-x qb_user/qb_user     0 2019-07-01 16:45 ./vnet/
-rw-rw-r-- qb_user/qb_user    88 2019-07-01 16:45 ./vnet/Kbuild
-rw-rw-r-- qb_user/qb_user  3205 2019-07-01 16:45 ./vnet/mic.h
-rw-rw-r-- qb_user/qb_user 43086 2019-07-01 16:45 ./vnet/micveth_dma.c
-rw-rw-r-- qb_user/qb_user  3320 2019-07-01 16:45 ./vnet/micveth_param.c
-rw-rw-r-- qb_user/qb_user 24018 2019-07-01 16:45 ./vnet/micveth.c
+ STATUS=0
+ '[' 0 -ne 0 ']'
+ /usr/bin/chmod -Rf a+rX,u+w,g-w,o-w .
+ exit 0
Executing(%build): /bin/sh -e /var/tmp/rpm-tmp.i2AIuc
+ umask 022
+ '[' -d modules ']'
+ /usr/bin/make -j4 KERNEL_VERSION=3.10.0-514.el7.x86_64 KERNEL_SRC=/lib/modules/3.10.0-514.el7.x86_64/build CC=gcc 'LD=ld ' MIC_CARD_ARCH=k1om
/usr/bin/make -C /lib/modules/3.10.0-514.el7.x86_64/build M=/root/rpmbuild/BUILD/mpss-modules-3.8.6 modules \
	INSTALL_MOD_PATH=
make: *** /lib/modules/3.10.0-514.el7.x86_64/build: No such file or directory.  Stop.
make: *** [modules] Error 2
error: Bad exit status from /var/tmp/rpm-tmp.i2AIuc (%build)
RPM build errors:
What's a qb_user? I've extracted the files using root.
Munasinghe__Indula
Above problem was recovered after installing gcc in the system.
