Software Archive
Read-only legacy content
17060 Discussions
Error on app-host.js line 1378
Muhammad_Y_Efendi
When I run the app using simulation, I got app-host.jp error on 1378 line. And I need to edit something on my javascript or css file,
and simulation will auto-reload and app works correctly.
But if I upload into smartphone, will get error, it doesn't work correctly.
Please see my attachment file.
What is this error? Does anyone know how to get resolve it ?
PaulF_IntelCorp
I don't think the error message you are showing in the Simulate tab console is relevant, and can be safely ignored (it is a message from the underlying Simulate tab support code). I think the problem you are encountering is due to the prior lines that are referencing a problem in what appear to be part of your index.html file.
Muhammad_Y_Efendi
Hi Paul,
I got resolve for this issue.
I use wordpress, and  try to retrieve the data through JSON API.
The problem was I run out the disk usage on server side.
So when JSON API connected to wordpress API,wordpress couldn't create more files/resources in server side.
Intel XDK is very great tools that give us this error messages.
