Software Archive
Read-only legacy content
17060 Discussions
Error saving service binding
Nikos_F_
Ubuntu 14.04, Intel XDK build version 3357
Every time I try to save the new service method binding ("Create Data Binding" in Explore Services), the IDE throws the following error:
"The service method named common was modified outside the Intel XDK. It will not be overwritten. You can rename the method and save it under a new name."
I'm unable to save new bindings no matter how I rename the method.
Similarly, when I'm trying to delete the method:
Failed to remove the service method code
"The code generated for this service method was not removed from the service-methods.js file. You may remove the code manually if needed. Reason:"
But there is no Reason mentioned.
Maybe there is someone experienced the same problem ?
BR
Nikos
PaulF_IntelCorp
I've asked one of my colleagues to take a closer look.
