Software Archive
Read-only legacy content
17060 Discussions
Error uploading APK (certificate that is not safe)
Alejandro_E_
Hi, when uploading to Google Play receives the following message:
''You uploaded an APK file with a certificate that is not safe. The size of the RSA or DSA key must be at least 2048 bits.''
I do not know how to fix it.
In Build Settings the ''Signed'' It is marked.
Thanks for any help.
Aahedi
I also experienced the same thing. I'm using the latest Intel XDK CLI 5.1.1.
To engineer intel I wonder why?
Please give us a solution.
Filipe_D_
Hi.
The same problem for me.
"Uploaded an APK signed with a certificate unsafe. The size of the RSA or DSA key must be at least 2048 bits."
Any help please?
John_H_Intel2
Are you using the EA edition of the XDK? If so, I recommend using the certificate tool to create a new certificate and build using the new cert.
Filipe_D_
Hi John H.,
Problem solved. I was working with Intel XDK version in 2807 and now downloaded Intel XDK EA Release 2866.
I sent my app to the Google Play and did not give any error.
THANK YOU AND CONGRATULATIONS FOR NEW RELEASE.
Fantastic job of Intel XDK team.
Aahedi
I still have a problem. I previously worked with Intel XDK 2366 then I upgrade to Intel XDK EA 2893 to use the CLI 5.1.1. I still have problems with the certificate google play. If it is the problem in the EA version, then where I should download the latest Intel XDK stable version? Help me
John_H_Intel2
Did you use the certificate tool to create a new certificate, set the app to use the new cert and then upload/build and try to submit the new apk to the play store?
