Software Archive
Read-only legacy content
Error when try to build Android
Muhammad_Y_Efendi
I got this error when tried to build Android, for iOS building is good - no problem. Tried to access this url using browser and got forbidden. https://download.01.org/crosswalk/releases/crosswalk/android/maven2/org/xwalk/xwalk_core_library/maven-metadata.xml a hour ago, it wasn't problem. Muhammad FAILURE: Build failed with an exception. * What went wrong: A problem occurred configuring root project 'android'. > Could not resolve all dependencies for configuration ':_armv7DebugCompile'. > Could not resolve org.xwalk:xwalk_core_library:19+. Required by: :android:unspecified > Failed to list versions for org.xwalk:xwalk_core_library. > Unable to load Maven meta-data from https://download.01.org/crosswalk/releases/crosswalk/android/maven2/org/xwalk/xwalk_core_library/maven-metadata.xml. > Could not GET 'https://download.01.org/crosswalk/releases/crosswalk/android/maven2/org/xwalk/xwalk_core_library/maven-metadata.xml'. Received status code 403 from server: Forbidden * Try: Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output. BUILD FAILED
Igor_E_2
i have the same problem
Taucher
+1
I have the same error.
I tried with Build 3461 and the latest 3759.
Muahammad_Usman_K_
Same issue,
Updating intel xdk. Hope so it will work.
Taucher
https://crosswalk-project.org/  is down also.
I hope they will fix it soon.
Muahammad_Usman_K_
i did update intel xdk, but problem is still there.
Yes, problem is on crosswalk side.
Taucher
Hamilton_Tenório_da_
Valued Contributor I
@Taucher> thanks for the link.
Olga_V_
I have the same problem
Ashok_C_
me too, when the fix expected to be released? Is there any workaround for this?
Taucher
@Hamilton Tenório da Silva > Not at all.
Crosswalk is online now!
Intel XDK Android Crosswalk Builds are working fine again.
PaulF_IntelCorp
This issue is under investigation, we'll post again (via Twitter) when it is fully resolved. In the meantime, the system may experience intermittent failures.
PaulF_IntelCorp
p.s. Based on the original post, this appears to be due to a Maven resource failure, which is outside the control of the XDK.
Muhammad_Y_Efendi
Sweet!
Now, it is good for me also.
Thanks, @Paul, @Taucher, and everybody who has help this issues.
